2009 4.0 Gen II Valve adjustment instruction.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sprocketgti3, Jan 14, 2012.
  1. Jan 14, 2012 at 4:10 PM
    sprocketgti3
    sprocketgti3 [OP] Well-Known Member
    Todd
    Sacramento CA
    Prerunner TRD
    TRD Air box TRD Exhaust Rear Swaybar Undercover Bed Cover Additional D-Ring rails installed, refab of oem rails. Steel Side bed lock box. 1" lift kit. Stainless Brake Lines Frt D-ring tie downs 12 VDC power port in rear bed Reinforced tailgate structure DRL cutout switch.
    Im looking for any tech info on 4.O 2009 engine valve adjustment inspection instructions.
  2. Jan 14, 2012 at 4:20 PM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    ummmm.... from my understanding is that there is no real valve adjustment procedure. it has hydraulic lifters, something like that. unless ur looking to adjust the shim bucket to cam -gap.
  3. Jan 14, 2012 at 4:22 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
  4. Jan 14, 2012 at 4:28 PM
    tacobo670
    Ray
    Las Vegas
    wow. just read it. i figured its something like that but damn. unless u really wanna have kids with ur truck or ur just shitting out money then i would rec to do it (at a dealership). thats a really big job.
  5. Jan 14, 2012 at 4:29 PM
    sprocketgti3
    Todd
    Sacramento CA
    Prerunner TRD
    That's what I'm thinking, but the maintenance schedule is requiring this action. Hmm. Just don't want to burn the valves............
  6. Jan 14, 2012 at 4:32 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I seem to remember the way they worded my maintenance schedule is that the "inspection" consists of listening for sounds that would indicate incorrect clearance. I don't have it in front of me right now but I remember thinking that was kind of a joke. I asked my mechanic about valve clearances on this engine and he told me that it should be checked (actually measured), but not needed until over 100K and probably not an issue until 150K. He's a 30 year Toyota guy.
    Also, if you wanted to check it, that shouldn't be a really big deal to pull the valve covers and take measurements. It's only a big deal if it actually needs to be adjusted.
  7. Jan 14, 2012 at 4:35 PM
    sprocketgti3
    Todd
    Sacramento CA
    Prerunner TRD
  8. Jan 14, 2012 at 4:35 PM
    Texoma
    Texoma IG: cwehlin
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    This question has been asked many times. And the answer is, unless your engine is running like trash, there is no need for an adjustment let alone even to check the clearances. If your engine is running like trash, then you should check other things first, like spark plugs, air filter, maf sensor, map sensor, and a few others.
  9. Jan 14, 2012 at 4:36 PM
    tacobo670
    Ray
    Las Vegas
    personally, ive never heard of valve adjustment check (physically) recommended by my dealership. i've only heard of -check for excessive valvetrain noise (which is normal to some degree).
    to actually tear down and measure clearances is big bucks man. i think that unless ur hearing excessive valve noise and the vehicle has over 100k then it might be a good idea to check clearances. other than that i think ur making me money. (IMO)
  10. Jan 14, 2012 at 4:36 PM
    sprocketgti3
    Todd
    Sacramento CA
    Prerunner TRD
    THX to all for the info.
  11. Jan 14, 2012 at 4:40 PM
    sprocketgti3
    Todd
    Sacramento CA
    Prerunner TRD
    I agree. I'm a 100% DIY person(Heavy Equipment Mechanic). Truck runs great. Just keeping my PM up to par.
    THX
  12. Jan 16, 2012 at 10:22 PM
    badger
    badger Well-Known Member
    07 SR5
    Listening for valve noise doesn't make much sense. Noisey valves are loose. Loose valves only affect performance. The loose gap means that the valves do not fully open so the flow of gases is restricted.
    A tight valve on the other hand makes no noise, and it is the one that does engine damage. A slightly tight valve spends less time on the seat, so it has less time to transfer heat. A severely tight valve may not ever actually close, but that case would cause some pretty rough running.
    The only way I can see this type of valve set-up ever tightening though is through valve seat errosion, and that would be a very high mileage thing.
  13. Jan 17, 2012 at 7:06 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    As long as it sounds like a sewing machine leave it alone.Keep using good oil and keep it changed to minimize wear and you should never have a problem with valve adjustment.
