2009 Aux port volume
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluntchisel, Feb 17, 2009.
  1. Feb 18, 2009 at 8:26 AM
    TheProphet
    TheProphet Active Member
    Canada,Quebec
    trd
    westin pull bar/off-road light Bf goodrich All-terrains for winter with oem mag wheels moto metal 16*9 / hankook dynapro MT for summer 2500k nokya hyper yellow narva h4 headlight diff breather mod inverter 400w mod l.e.d for the cab 4*4 illuminated switch mod l.e.d bed light mod
    I have the same problem for the Aux. The aux port was not amplifier enough by the the stereo :S
  2. Feb 18, 2009 at 2:13 PM
    Liam1234
    Liam1234 Well-Known Member
    Massachusetts
    2021 DC, LB, TRD Sport, 4x4, Magnetic Grey, leather sunroof.
    Using both my ipod and my daughters ipod we had to make sure the volume is turned up high on the ipod. The radio is as loud with the ipod as it is regular.
  3. Feb 18, 2009 at 2:16 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    It might help to get a Belkin iPod stand for your car... My buddy has one and it has no problem with the stereo
  4. Sep 26, 2009 at 3:30 PM
    HL Audio
    HL Audio New Member
    Charleston, SC
    2011 Double Cab Prerunner
    I've noticed this in my truck, it sucks... I think Toyota is covering their asses from people blowing the factory paper speakers.
    Don't bother adjusting your mp3 library or adding a pre-amp. This will only ruin the sound quality. Mp3s are bad enough quality already. Don't ruin them anymore.
    The best method, in my opinion, is to get an aftermarket receiver and tie into the existing factory aux jack if you have the funds. If not, then I guess you won't be able to rock out as loud.
    IPODs and other MP3 players are more than capable of going will go waaay above a line level signal from their headphone output. They are made to amplify headphones. Usually about 3/4 of the vol is a line level signal on any IPOD.
  5. Sep 26, 2009 at 3:58 PM
    JKD
    JKD Well-Known Member
    Mine is the same. The Aux input is useless, because my battery life on any MP3 player is going to be crap playing at max volume all the time.
    I am going to build a small stereo preamplifier so I can have the MP3 player at a sane output level and still hear it on the stereo (when set to a normal volume level).
  6. Sep 26, 2009 at 4:10 PM
    HL Audio
    HL Audio New Member
    Charleston, SC
    Good luck!
    Let me know how that goes.
  7. Sep 26, 2009 at 4:30 PM
    JKD
    Yeah, I'll post here when I get it done. It'll probably be a while, I have other projects on the bench right now.
    The goal will be putting in an MP3 CD and checking the volume level, then playing the same song at 1/2 volume on the iPod, and turning up the preamp until it equals the volume when played from the CD.
  8. Sep 26, 2009 at 6:03 PM
    Railtech
    Railtech Active Member
    Alpharetta, GA
    09 TRD Sport DC 4x4
    I have the same issue, using aux and the volume on the ipod on max. It seemed OK. Wanting to reduce the wiring mess of the ipod, power and aux cord. I bought a PXAMG, it works really well sorts the songs, playlists and the like. Pretty handy device, problem is the line out on the bottom of the ipod is not volume adjustable like the headphone out. So the issue remains. I emailed PXAMG support for any ideas.
    I did a good bit of searching and ran across the software called mp3gain. It makes a reversible change on your library and can increase the volume of the mp3. I have a pretty significant library and it took several hours to accomplish.
    I boosted the standard output of my mp3s to 95db. This did improve the volume issue somewhat. But I do find myself bumping off the VOLUME MAX on the radio frequently. Keep in mind you can boost your mp3s to the point they are degraded. You can back the changes out. Use the adjust max DB without clipping.
    I am content (not happy) with the results for now. But it leaves me with two choices replace all the stock speakers and run a small 400 watt amp. Or replace the headunit with something with more power and lose my steering wheel controls....
    What is pathetic is I have the PXAMG in my wife's 06 Odyssey and it will rock your socks off with no adjustment to the mp3s necessary. And that is with the Honda headunit and 6 speaker system. I am very dissapointed with the stock headunits power.
  9. Oct 17, 2009 at 3:38 AM
    taco430
    taco430 Member
    Northeast
    2010 Tacoma DC TRD Sport
    XM Skid Plate Tube Steps Exhaust tip
    I have the same issue with my 2010 D/C, low volume. I use the same setup in the AUX port in my Chevy and it works just fine, plenty of volume. It is definitely something with the Toyota factory head unit. Maybe something Toyota needs to address.....after paying 33k for the vehicle. Embarrasing....it works on a Chevy!
  10. Oct 17, 2009 at 6:41 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Yea mine isn't loud either, I don't really use it much though. It's not that I can't hear anything, you just have to have the volume maxed out if you're on the highway. The aux port on my previous car was the same way. The volume for XM is the same way.
  11. Jul 25, 2012 at 6:17 AM
    river rat
    river rat Tool Geek
    Midwest
    '11 Timberland Mica regular cab.
    Same problem here on my '11with OEM single disc/XM stereo. It needs a pre-amp. I just got an '02 Jeep Wrangler with an aftermarket Sony stereo (Of, course because the originals always get stolen with a soft-top and no car alarm...LOL).
    It has a setting for input level for its AUX jack. I wish the Taco had that feature. I gave up on the iPod in the Taco and just burn CDs of the same music I have on the iPod and use the iPod on the Jeep where I can crank it up.
    cheers,
    Rob
  12. Jul 25, 2012 at 6:39 AM
    jprovence
    jprovence Well-Known Member
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    On my ipod, I have a 30 pin charger AUX cable. It sends a line out signal from the ipod, so volume on the ipod doesn't affect the truck. Having the radio do all the amplification and bypassing the ipods poor headphone amp.
