2009 Clutch Pedal Squeak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tonyplanet, Jul 1, 2009.
  1. Jul 1, 2009 at 6:13 PM
    tonyplanet
    tonyplanet [OP] Well-Known Member
    Glendora, CA
    09 Tacoma 4x4 TRD Off-Road
    enough to get me there
    :mad:
    After 6k miles, I start hearing clutch pedal squeak. Especially when you gradually release the clutch. Search the forums, and found out that this was common on the 05 and 06. TSB for this for 05-06', but no 09' ?
    You would think toyota would have solved this problem. Is anyone else experiencing this on their 09'? Some say it may be linked to the hot weather, maybe so. It's been getting warmer here in SoCal. But, that shouldn't be an excuse to put on a crappy plastic/composite clutch pedal.
  2. Jul 1, 2009 at 6:16 PM
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    Mine does it as well. 08. Just try to get the TSB done anyway, just a thought...
    Not much you can really do.
  3. Jul 8, 2009 at 6:30 PM
    40204ever
    40204ever Well-Known Member
    Caldwell, TX
    4x4 taco racing development
    my pedal started squeaking last week. I am going to buy some silicone spray. What do y'all think.
  4. Jul 9, 2009 at 4:20 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The clutch pedal squeek has been a problem ever since the tacomas came out in 95.5 - and Yeah...they obviously haven't fixed it yet. :rolleyes:
    I replaced my clutch pedal bushing on my 96 about 3X in 5 years (I have a writeup on how to change it on the 96)
  5. Jul 9, 2009 at 5:35 AM
    hans2
    hans2 Member
    My '09 5-speed does it in hot weather. Is it true that the TSB doesn't completely fix it?
  6. Jul 9, 2009 at 3:45 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    My dealer did the clutch pedal squeak TSB on my '09 back in February. Haven't heard a peep from it since.
  7. Jul 9, 2009 at 3:51 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    05 TRD Sport 4x4 SR5 V6
    Garage Fabbed +2 LT, FOA 2.5 RR w/ Comp Adj, 35 XMTs on Level 8s, 50T Spring Under w/ 13" Shackles, Elite Front Bumper, AP Rear, Retrofitted, Wicked Flow, Custom Roof Rack, Custom Sliders, Custom Scratches, 12" JL and an Audiopipe amp.
    Does having a tsb done cost anything from the dealer? Cause my clutch pedal speaks too :|
  8. Jul 9, 2009 at 3:52 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    FWIW my service manager said they can carry the TSB issued for the 05-06 trucks to the 07-09s if there is an issue. I'd take it in and explain your issue to them. Chances are you will get a new clutch assembly.
  9. Jul 9, 2009 at 3:53 PM
    SC4333
    Grant
    San Antonio, TX
    No, the TSB is covered by the manufacture if the truck is still under warranty.
  10. Jul 9, 2009 at 3:55 PM
    Carson
    Carson
    Modesto, California
    Thanks, i bought mine used so it has some other type of warrenty, idk if they will still cover it.
  11. Jul 9, 2009 at 4:05 PM
    SC4333
    Grant
    San Antonio, TX
    probably not, but it wouldn't hurt to try.
    Look around and there is a procedural write up on this very TSB. If you are mechanically inclined at all, you should probably be able to tackle the job by yourself.
  12. Dec 1, 2009 at 7:40 PM
    dingchavez24
    dingchavez24 Active Member
    Charlotte, NC
    09 Manual TRD Sport SR5
    Current: URD Short Shifter, Flyeyes, CB, Billy's rear bumper
    Can anyone better define this "squeak" in the clutch petal. My 09 4DR TRD sport clutch has more of an "achy" sound to it when depressing/releasing the clutch slowly. I relate the sound more to an achy door hinge in an old house rather than a "squeak". Can anyone confirm whether this is similar to what they're hearing and if this is cured by the squeaky clutch TSB?
  13. Dec 1, 2009 at 7:43 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    Mine sounds more like a creaking door but sometimes it is a squeak. it does it at random and sometimes for the duration of a day and then goes away only to come back again later
  14. Dec 1, 2009 at 7:46 PM
    dingchavez24
    Charlotte, NC
    Per previous messages in this thread, mine seems to be somewhat temperature dependent but very random. Almost too random to approach a dealership to have the issue fixed via the TSB. Does anyone else have input to this subject before I go in for my suspension TSB?
  15. Dec 1, 2009 at 9:27 PM
    tonyplanet
    Glendora, CA
    The TSB doesn't apply to the 09 model years. When I brought my truck in the second time, the dealer just took apart the clutch pedal assembly and greased some more with a heavier duty grease. The first time they just greased the clutch pedal without removing/dissassembling it; which only lasted for 1.5 months before the squeaking came back. Been three weeks so far, without any issues. Keeping fingers crossed.
  16. Dec 1, 2009 at 9:55 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    mine does it to but over the rear doors rattling and all the other shit that rattles, the squeak doesnt bother me the most. just turn the music up and enjoy the tunes :thumbsup:
