2009 fog light mod
Discussion in 'Lighting' started by cajun1_us, Jan 7, 2009.
  1. Jan 7, 2009 at 4:05 AM
    cajun1_us
    cajun1_us [OP] Member
    Ponchatoula, la
    2007 TRD 4x4
    painted bumper, grile, handles, mirrors, added sport hood, tinted windows, smoked headlamps and taillamps.
    Does anyone know if the fog light mod to turn fog lights on anytime works the same on the 2009.
  2. Jan 7, 2009 at 4:25 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    It should as i wouldn't see any major changes in that area. The mod is cheap enough to try. If it doesn't work, you've wasted only 5 bucks...
    Let us know how it turns out if you do it.
  3. Jan 7, 2009 at 4:55 AM
    cajun1_us
    Ponchatoula, la
    2007 TRD 4x4
    I had it on my 07. So I already have the wire. I'm ordering an 09 this week.
  4. Jan 7, 2009 at 8:06 AM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    YES, IT DOSE WORK on 2009 model. I have this mod on my 09
  5. Mar 5, 2009 at 4:36 AM
    Hornet18
    Hornet18 New Member
    09 PreRunner
    Just got my '09 PreRunner, checked the foglight relay and found one less pin than on my '07 when I did the mod. Not sure how to do the mod on the '09 now and would appreciate any help.
  6. Mar 6, 2009 at 2:43 PM
    DNahas
    DNahas Well-Known Member
    Dallas
    09 DC 4x4 OR
    I just did mine on an 09 and found this thread searching for a problem.
    I did the Mod. The directions did not explan EXACT what blade on the relay to use, so I assume its the one running parallel with the bumper and closer to the rear of the truck.
    Now the problem. I can turn the fogs on and off anytime. Its now seems the dealer option DRL (Daytime running lights) functionality has moved from the inner marker bulbs to the headlights. So what I lost control of is the headlight bulbs now seem to always be on, but more dim than regular low beam.
  7. Mar 6, 2009 at 2:52 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hmmmm, that's really weird. I have an 06' and did the Fog mod a few months ago and just installed the factory DTRL relay last week and works perfect. I'm not sure why it changed over to your headlights?
  8. Mar 6, 2009 at 5:14 PM
    DNahas
    Dallas
    09 DC 4x4 OR
    with the parts being slightly different does anyone have a 2009 electrical FSM?
  9. Mar 6, 2009 at 6:23 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
  10. Mar 7, 2009 at 6:21 AM
    DNahas
    Dallas
    09 DC 4x4 OR
    Never mind, I traced the problem back to an ID 10 T error with the operator. To embarrassed to provide the details of that error code..
    It works great on a 2009, provided you read the directions.
    FWIT, I would still like to find a copy of the 09 FSM so I can find the connection for the backup camera below the dash.
