2009 infamous "sticker", you got one?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bryan139, Mar 13, 2009.
Got Sticker?
  1. Yes
    57.2%
  2. No
    42.8%
  1. Aug 22, 2009 at 2:45 PM
    #301
    gologit
    gologit Well-Known Member
    In the redwoods.
    2023 SR5 4x4 long bed
    Nothing major or fancy. Just stuff to make it work better for me. Running boards, seat covers, BakFlip
    Just went out and checked mine. No sticker! New 09 4x4.
  2. Aug 24, 2009 at 6:55 AM
    #302
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    I have an 09 Access cab, SR5, 4x4 with the towing package. It is not a TRD. I also have the 3 leaf spring package. Yellow sticker on the door says 12lb. reduced cary capacity. Truck was made in Cal.
    I am going in for an oil change this coming weekend and am planning to ask about the upgraded package. I hauled some feed out to my deer lease this past weekend and drug one of the mud flaps off. Truck handled like crap with a load. I think I only had around 800 lbs in the truck!
    I am also planning to call Toyota today to see if they can help get mine fixed. I bought a truck, not a car!
  3. Aug 24, 2009 at 8:50 AM
    #303
    paidfor
    Austin, TX
    2013 TRD OR 4x4
    Update: Wrote an email this morning to Toyota describing the problem I was having.
    Then I called them. I told them the whole story again. They put me on hold then came back and said there was a TSB for 06-08 to fix the problem and said they would put it on mine for free. They cautioned me that the ride after the TSB would be rougher. I never even mentioned the TSB while I was on the phone with the lady.
    They gave me a case number and said the dealership would call me in a few days to set up a time to come in and have the work done!!!!
    I won't celebrate until the TSB is done, but it looks like I am about 1/2 way there.
  4. Aug 24, 2009 at 8:53 AM
    #304
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I had the leaf TSB performed on my truck and it really doesn't help out that much with the payload. A load of firewood level with the top of the bed still bottoms out on the bump stops. The leaf packs should be 5 leafs or thicker spring steel in my opinion.
  5. Aug 24, 2009 at 9:25 AM
    #305
    jandrews
    '09 FourDubDee TRD OR
    Got the TSB...it helped with payload to the extent you would expect one extra leaf to help...maybe a couple hundred pounds. I plan on puttin in another AAL with a lift in the not-too-distant future.
  6. Aug 28, 2009 at 2:43 PM
    #306
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Toyota just mailed me a sticker;
    CAUTION: LOAD CARRYING CAPACITY REDUCED
    Modifications to this vehicle have reduced the original capacity by:
    WEIGHT (LBS) WEIGHT (KGS)
    31 14
    VIN#: 1234567......
  7. Aug 28, 2009 at 2:51 PM
    #307
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    hey, another WNYer
    took my sticker off
  8. Aug 29, 2009 at 1:26 PM
    #308
    09sportowner
    09sportowner Well-Known Member
    Texas
    09 Sport
    mine has the sticket, but it says reduced by 16-0lbs. What is the -0? Should I assume it has been reduced by 16lbs. Built in Mexico and has 3 leaf with the same product codes of the 08 TSB. Any ideas?
    Thanks!
  9. Aug 29, 2009 at 2:11 PM
    #309
    satchsd
    satchsd Old Guy Member
    keller texas
    took mine off
  10. Aug 29, 2009 at 4:02 PM
    #310
    tcbe6472
    tcbe6472 Well-Known Member
    Tommy
    Lake Jackson,TX
    09 TRD
    My 09 was built in California and it has the sticker as well, however, mine says 12lbs less than the maximum payload. What is TSB??
  11. Aug 30, 2009 at 5:02 AM
    #311
    Poohey
    Poohey Member
    Jasper, Indiana
    09 4x4 Tacoma DC Silver Streak
    09 Double Cab, 4X4, TRD, Build Date 2/09 in California, Has Hitch & Towing Package, Has 3 leaf rear spring set-up.
    Mine has sticker that says 2kg's or 4lb reduction, looks like it was wrote with a 'Sharpie"
    After 1500 miles I can't say it has any issues, but I have not towed or hauled anything with much weight.
  12. Aug 30, 2009 at 5:08 AM
    #312
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Thats funny! I don't understand the point of the sticker or what the point of it is. Why is it an after-thought (put on by hand and not machine - evident by it's scattered and uneven location). Why do each one of them list a different decreased weight? So it is printed for EACH truck that comes off the line?
    4lbs? whats the point!
  13. Aug 30, 2009 at 8:09 AM
    #313
    sdel82
    sdel82 Active Member
    Northeast
    09 dbl cab
    Got my 09 tsb done. Did it all through e-mail and then recieved a call to schedule install. I never once mentioned the TSB or knowledge of it. Way better ride even without a load. I recommend the tsb or aal on your own. They didnt remove my 290lb sticker. While truck was in shop, I looked under a 2010 and it had 3 leafs. FYI
  14. Aug 30, 2009 at 11:12 AM
    #314
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    From what I understand the sticker has to do with federal compliance with the load rating of the vehicle as it relates to the wheels and tires provided by the manufacturer. It's not related to the spring pack.
    TOYOTA IS RECALLING 27,080 MODEL YEAR 2009 AND 2010 PASSENGER CARS BUILT FROM JUNE 2, 2008 TO MAY 4, 2009. THESE VEHICLES WERE NOT EQUIPPED WITH LOAD CARRYING CAPACITY MODIFICATION LABELS WHICH FAILS TO CONFORM WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 110, "TIRE SELECTION AND RIMS." Consequence:
    [​IMG] INCORRECT LOAD CARRYING CAPACITY MODIFICATION LABELS COULD RESULT IN THE VEHICLE BEING OVERLOADED, INCREASING THE RISK OF A CRASH. Remedy:
    [​IMG] TOYOTA WILL NOTIFY OWNERS AND PROVIDE THEM WITH A NEW, ACCURATE LABEL TO BE INSTALLED OVER THE INACCURATE LABEL FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR ABOUT AUGUST 31, 2009. OWNERS MAY CONTACT TOYOTA AT 1-888-270-9371.
    Another note from my own experience. I picked up a yard of bark today. I have an '09 DBL Cab LB V6 4x4 SR5. The truck handled the load without issue. The rear hardly squatted. Now bark isn't as heavy as a yard of dirt or rock but it seems alot of people were complaining about the ride with a few hundred pounds in the bed.
  15. Aug 30, 2009 at 1:00 PM
    #315
    corona56
    corona56 Well-Known Member
    Tom
    Boston, MA
    09 DbleCab LB 4x4
    Added fog light mod Added delay wiper mod Alloy rims with BF Goodrich tires
    From reading all of these post, I am pretty sure this sticker has to do with optional equipment and not the spring TSB. Mine says 5lbs. I have no options other than floor mats. My guess is that those mats weight about 5lbs. The folks that have more than 100lbs probably have a hitch and other accessories (larger rims, running boards, skid plates, etc.)
  16. Aug 30, 2009 at 1:11 PM
    #316
    stormyday
    stormyday Well-Known Member
    Morganton, NC
    14 Taco Double Cab Pre-Runner
    Nope. I had the 290. Only options SR-5 and 7 speaker sound.
  17. Aug 30, 2009 at 1:21 PM
    #317
    corona56
    Tom
    Boston, MA
    09 DbleCab LB 4x4
    Hmm. But it can't be the TSB thing either. Why would folks have 5lbs and 16lbs stickers? That wouldn't account for anything. But I have to admit, I can't see the chrome bumpers, painted wheel arches and some convenience options can't be 270lbs. The mystery continues ...
  18. Aug 30, 2009 at 5:18 PM
    #318
    dexterdog
    Oly WA
    2012 F150
    I don't know how the weight modification is determined since there is quite the variation across the board. One thing I can possibly think of is that each production vehicle is weighed and the GVWR is determined and then the payload capacity is figured. The only reason I can see for this to occur is if Toyota pissed off the NHTSA and are requiring them to post exact capacities on each vehicle produced.
  19. Aug 30, 2009 at 5:21 PM
    #319
    dexterdog
    Oly WA
    2012 F150
    That's simple. I doubt two vehicles coming off of the assembly line would weigh the exact same weight.
  20. Aug 30, 2009 at 6:40 PM
    #320
    corona56
    Tom
    Boston, MA
    09 DbleCab LB 4x4
    Yup. If they are really weighing the vehicles to determine actual load. But, the folks that are reporting a sticker with -270lbs can't be explained by that, unless they have 200+lbs of equipment installed.
