2009 infamous "sticker", you got one?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bryan139, Mar 13, 2009.
Got Sticker?
  1. Yes
    57.2%
  2. No
    42.8%
  1. Mar 22, 2010 at 10:52 AM
    #381
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    This was the opening post so I thought it was the label in question,
    But The other labels are interesting also.
    I hadn't heard that, I will have to check it out, I am having the T-SB done because I feel the truck "sags" a little too much under load, Thanks Doc
  2. Mar 22, 2010 at 1:33 PM
    #382
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    I have an 08 that was built in Fremont, CA., but can someone clearly explain what TSB is or means?? is it something that I should be concerned about?
    Thanks in advance
  3. Mar 22, 2010 at 1:45 PM
    #383
    zfisher89
    zfisher89 Well-Known Member
    zach
    RVA
    09 Tacoma SR5 4x4
    6" procomp,alcan rear springs, lots more to come
    made in cali no sticker
  4. Mar 22, 2010 at 7:30 PM
    #384
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    A TSB is a Technical Service Bulletin. All car makers use these to communicate with dealers and any auto repair shop. The purpose of a TSB is to convey information for repair technicians. At times, concerns pop up with vehicles. Sometimes they are customer concerns with the feel of the vehicle, noises, paint and body issues and so on. Other times, there are updates to information printed in service material for new parts, techniques and/or procedures to be used. In almost all cases, they are "known fixes" for issues that may have many potential causes. These things can take a lot of time to find and lead to customer and shop frustration. These bulletins are a resource for the shop/dealer/technician and customer to use. If you have a vehicle with a matching concern, you can use the bulletin to verify cause and apply the remedy. Again, they have been around for YEARS with all auto makers. Even aftermarket service information lists these TSBs for use. Many times, it is a sharp technician in the field that finds the root cause and forwarded the information to the manufacturer. They confirm the information and put it out to help other technicians.
    Beyond that there are other sites that offer fixes for vehicles when they are a little older or issues that do not come up while a dealer is seeing them. Sites like Identifix and others. You must be careful with these resources as at times the "fix" can be questionable.
    There is a COMMON misconception. NOT EVERY VEHICLE NEEDS EVERY TSB PERFORMED!!!!!!! A TSB IS NOT A RECALL OR A CAMPAIGN IN ALL CASES!!!!!!! Sorry I shouted but this really bugs me. Many TSBs are there for information. Not all vehicles exhibit the concern and not all customers drive the same way. Some TSBs call for reprogramming of a control unit. In some cases, the driver is not having an issue or they do not feel a "shift delay" that others do. If you program that car without the customer's permission and understanding, you could change how the car drives and the customer will be unhappy. Guess what? You cannot go back to the old program in most cases! Now they are stuck with what was done. How about a brake noise? Not every vehicle will develop the concern. Much could depend on use or driver behavior. There is NO reason to do the work to every car just because. This is where "customer concern" TSBs fall most times. Some customers may like the vehicle just fine as is, while others require something else. Those that need it get it, those that do not.......... That is where the spring TSB falls IMO. Some people that never would have had a concern with how a vehicle operated are not suddenly convinced they have an issue because they hear about it. In some cases it is valid, in others it may not be.
    HTH.
  5. Mar 22, 2010 at 8:02 PM
    #385
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Thank you for the clarification shadow
  6. Mar 23, 2010 at 6:09 PM
    #386
    mjgaddis
    mjgaddis Member
    Honolulu, HI
    09 TRD Sport
    Westin Platinum Oval Step Bars, Westin Ultimate Bull Bar w/ Skid Plate, AFE Pro-Dry S Air Filter
    My 09 originally had the reduced by 290 lbs but I received a replacement sticker in the mail that said it was reduced by 3 lbs.
  7. Mar 27, 2010 at 11:55 AM
    #387
    ASE_MasterTech
    ASE_MasterTech Well-Known Member
    Monmouth County, NJ
    2010 TRD Sport DBL\Cab
    Wet Okole seat covers, Westin Platinum Oval tube steps, Rear spring TSB plus Super Springs, D-Rings in all bed bolts, Tailgate reinforcement mod (for loading Harley)
    It really doesn't matter what bed payload is on a door sticker, the vehicles refer to in the TSB will not perform as specified/advertised in any Toyota issued brochures (online, hardcopy, or owners manual) regarding capacity of interior, plus capacity of bed load, plus capacity of tow hitch load, all combined..
    If you bring this fact to the attention of the Service Manager or Toyota Rep, you will have no issues in obtaining the 4 leaf spring upgrade.
    hope this helps...
  8. Mar 31, 2010 at 2:24 PM
    #388
    zimm52
    zimm52 Well-Known Member
    sneakin up behind you
    2010 PreRunner TRD Off Road
    nothing yet!
    I have one in my truck (2010) and it says that it has been decreased by 0.0 pounds. Whats the point?
  9. Mar 31, 2010 at 2:42 PM
    #389
    ShadowFalken
    Jim
    Maryland
    10 Off Road
    Zimm, ask the Federal Govt. That sticker is there by law as I understand it. It is where they are REQUIRED BY LAW to list the reduction due to DEALER installed options. It is a different sticker we have on our trucks than the RECALL sticker from 2009.
  10. Mar 31, 2010 at 4:14 PM
    #390
    zimm52
    nothing yet!
    ok thanks!
  11. Apr 1, 2010 at 7:39 PM
    #391
    jmed99
    jmed99 Well-Known Member
    SC
    09 DC PreRunner TRD OR
    I have an 09 and do not have the sticker. Will I be getting one?
  12. Apr 14, 2010 at 9:14 PM
    #392
    Ford2Toy
    Ford2Toy Member
    mine says its lowered by 100lbs
  13. Apr 14, 2010 at 10:26 PM
    #393
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    '10 reg cab 4x4 manual. Mine says "-1".
    :pccoffee:
  14. Apr 15, 2010 at 12:36 AM
    #394
    philobeddoe
    philobeddoe ΜΟΛΩΝ ΛΑΒΕ
    - philo
    Nashville, TN
    2010 Gray Tacoma TRD
    Tom Woods Custom Driveshaft
    2010 DC 4x4 Sport made in Mexico, purchased in California, sticker says reduced by 4 lbs.
  15. Apr 21, 2010 at 2:06 PM
    #395
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I have a 2010 DC/LB, sticker says reduced by 0. Seems pointless.
  16. Jun 1, 2010 at 2:44 PM
    #396
    originalthoughts
    originalthoughts Well-Known Member
    Houston
    1997 Land Cruiser
    None, factory diff lockers are great.
    2010 4x4 DBLCB SB. Have the sticker but it has a handwritten 0 on it.
    When I bought it the salesperson had never seen that sticker before.
  17. Jun 1, 2010 at 2:53 PM
    #397
    speedybluetacoma
    speedybluetacoma Member
    Alyssa
    Texas
    10 DC PreRunner SR5
    my '10 (assembled in Cali) has one that says it was lowered by 23 pounds *shrugs*
  18. Jun 6, 2010 at 2:38 PM
    #398
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    Mine says load capacity reduced by 4 lbs. :D
  19. Jun 7, 2010 at 2:35 PM
    #399
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    My '10 TRD Sport 4x4 has a sticker reducing the capacity by 47lb.
    Sounds like random numbers to me lol
  20. Jun 14, 2010 at 12:22 PM
    #400
    cspcrx
    cspcrx Well-Known Member
    21 TRD Sport 4x4 Cement
    Our 09 had one that said reduced 290lbs. We just got a new one in the mail, 4 weeks after have rear spring TSB done, that says reduced 5 lbs.
