2009 Leveling Kit w/ rear block 1"
Discussion in 'Suspension' started by ComaChic, Sep 27, 2009.
  1. Sep 27, 2009 at 6:13 PM
    ComaChic
    ComaChic [OP] Well-Known Member
    New York...not the city!
    06 DCLB TRD Sport V6
    OME 885's w/ Top spacer kit, OME Nitro 90000 Sport and N182, LR UCA's, 2" AAL non TSB, Window tint, K&N Intake, Lights
    Ok so im sure its a question asked and answered a million times but wanted to get something up to date and recommended.
    2009 Tacoma Crew Cab Short Bed.. I wanted to just put some beefier tires on her and perhaps new black wheels. Looking to see what is suggested for an upgrade that will clear easily and not be forcing anything to major. I figures a 2.5" spacer for the front:
    NOW, all I want to know is what will I be seeing short term and long term for problems or driving changes. What size tires fit simply with a nice little offset and what would be overkill tire sizes. I figured a 285/70-17 would be good. I believe i'll be doing 17's for the price as well as they look proportional on the truck.
    Next would be what if any problems would I have putting a 1-2" block in the rear to pick that up a little because I saw a Tacoma with a 2.5 in the front and it looked to saggy in the rear. So probably a 1" block would work just fine.
    Truck is a daily driver and doesn't tow ever. No working or anything.
    I liked the look of the Cooper Zeon tires.. that or a basic all-terrain tire thats good summer/winter. BF's, Coopers, whatever else people seem to like.
    All advise appreciated!!!
    Suggestions on brands and tires needed!!!
    THANKS!
  2. Sep 27, 2009 at 6:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If your looking to stay around 2.5" lift, I would recomend a 32" tall tire (265/70/17), so as to avoid any rubbing issues.
    The Bilstien 5100's offer lift up to 2.5" in the front. Get a set of 4 (2 for the rear), and an Add A Leaf, and you should be good.
  3. Sep 27, 2009 at 6:25 PM
    ComaChic
    I hear ya for the tires thats what im looking for nothing that will rub or be a problem. 265 would probably look just fine. 285 probably would rub I was thinking. They guys truck I saw had 285/60-18's and it looked like they rubbed just a tad but didn't ask.
    So the stock shocks won't reach that lift I guess. Do they make shock extention's like the bigger trucks? Truck is brand new so don't really need new ones yet.
    And you think an add a leaf is better than doin a block? Rather than a block? I figured a leaf would be more money and ride a bit stiffer. Does a new leaf take out that much sag
    Thanks
  4. Sep 27, 2009 at 6:30 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    You should look into the TSB on the rear leaf springs. There is a ton on info on here about it. Basically, they upgrade the 3 leaf pack to a 4 leaf leaf pack. Thus giving a little extra lift in the back. Might want to look at that before doing anything to the rear as it is free (under warranty). Now, so you know the TSB only covers up to 2008 Taco's. However, many members (including myself) have gotten this done on our 2009's. Worth a shot, just read up pretty good so you know how to go about getting done.
    Good luck
  5. Sep 27, 2009 at 6:35 PM
    EmoSlayer
    EmoSlayer METAL!
    Scott
    PA
    TRD Off-Road
    Bilstein 5100s all 4 corners, front set at 0.85 w/ eibach coils metalcast red, driver's side lean spacer, rear tsb leaf pack with tsb aal from toytec, 265/75/16 goodyear wrangler authority, MT Classic III 16x8 4.5bs, LR UCAs
    http://www.toyteclifts.com/index.ph...ategory_id=64&option=com_virtuemart&Itemid=72
    If you are on a budget and don't go off roading this lift would suffice.
    If you plan on running bigger tires on those stock rims, you are going to need wheel spacers, spider traxx makes a good product I hear...
    285/75/16s would be what you're looking for, just would need the spacers along with it and minor trimming in the front wheel wells
  6. Sep 27, 2009 at 6:37 PM
    ComaChic
    Thanks man! Yea not a bit of offroading at all.... unfortunately :(
    But I think i'll get a set of KMC Revolvers in black with new tires and just keep the stockers just in case.
  7. Sep 27, 2009 at 6:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Along with the lift Emoslayer mentioned, your gonna need new shocks, and possibly new UCA's to correct for lost Caster.
  8. Sep 27, 2009 at 7:28 PM
    ComaChic
    Yea that was my biggest concern was if I needed UCA's.. thing is is im not planning on having this long so im not to worried on that stuff. I mean I just wanna know for daily driving it will be fine. Thats what I wanted to knwo is how far do I go before I am stretching that angle of everything.
    I saw something on ebay of course, not the super cheap million made crap kid but one kit had the 2.5 spacers for the front and a block for the rear. I know its a pretty cheesie and ghetto kit but just how bad is it and how much long term am I killing. I feel its just fine for what I need
  9. Sep 27, 2009 at 7:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If its a top plate type spacer, it can eat your ball joints in under 5000 miles. AND, can cause breakage of the front shocks, with a dip in a road, or pot hole.
  10. Sep 27, 2009 at 7:45 PM
    ComaChic
    Thats what I was scared to hear. I figured the same thing.. Dammit.. Sooooo just what is my affordable way to lift this thing or to basically level it. Just to fit some 265's or something beefy on a 17" wheel that sticks out just a hair. Looking for that beefy look over stock.
    THANKS
  11. Sep 27, 2009 at 7:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    See post #2.
  12. Sep 27, 2009 at 7:55 PM
    ComaChic
    Im on it... that was a dumb question haha
  13. Sep 27, 2009 at 8:00 PM
    ComaChic
    So sorry to be such a pain but... back to your first post.. With a new set of 5100's that would pick up my front end alone to fit bigger tires? Or would I need to still do a longer spring or spacer for stock spring.
    As for the rear is it better in any way to do the spring over a block?
  14. Sep 27, 2009 at 8:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The shocks will add the lift, as they have an adjustable spring seat. No spacer needed. An AAL is much better than a block. Blocks tend to exacerbate axel wrap.
  15. Sep 27, 2009 at 8:07 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    :devil: He said, "exacerbate".
    The crazy thing is, Chris nailed the spelling on "exacerbate" but couldn't get "axle" correct.
  16. Sep 27, 2009 at 8:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO!!! Im funny that way. :anonymous:
  17. Sep 27, 2009 at 8:30 PM
    ComaChic
    Haha spelling isn't my think.. Im not a thinker, im a driver - Ricky Bobby
    Anyway.. I know what your saying axle hop sucks. So I will be best doing a new set of Bilsteen 5100's and then an Add A Leaf in the rear for the minor lift I want as well as a good ride.
    NOW heres my last minute hook.. I have a lease and perhaps don't know if i'll buy it out or send it back. With this I can put all the stock stuff right back in and put the stock wheels on and should be good to go right. i don't see why not
    Well THANKS so damn much! Thanks to the website im headin in the right direction.
  18. Sep 27, 2009 at 8:31 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    good catch. I am like that as well.
  19. Sep 27, 2009 at 8:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. Everything c an be returned to stock pretty quickly.
  20. Sep 27, 2009 at 8:50 PM
    ComaChic
    So my question is, is how do these company's sell these leveling/lift kits like the post # 4 or 5 on here without shocks. With longer springs of course you need a longer shock cause it will top out. Just saying... but in the same way how will a new shock pick me up 2 inches or so with a stock spring.... if I pick up the front from the front how does the stock spring reach???
