2009 NON JBL sub problem (static)
Discussion in 'Audio & Video' started by wizo, Jul 30, 2009.
  1. Jul 30, 2009 at 1:43 PM
    wizo
    wizo [OP] Well-Known Member
    Port St. John, FL
    09 PreRunner 2.7L
    2.5" Walker Evans C/O's, All Pro UCA's,
    I just had my single cd in dash head unit replaced do to intermittent power on and offs. Since then when I have the sub turned on and a FM station selected when the sub "hits" I get static in ALL speakers. I informed the dealer of this but they blame poor radio signal since this does NOT occur with a CD. However I clearly showed them the static or interference ONLY occurs when the sub is on. Unfortunatly they are not willing to investigate further at this time. I also called Toyota directly and was informed since no TSB exist there is nothing they can do.
    Have any of you experienced this.
    By the way the BASS is set to 0.
  2. Aug 22, 2009 at 6:52 PM
    TheTacoManChach
    TheTacoManChach I AM THE GREAT CHACHOLIO!!!
    Brian
    Fayetteville, TX
    2006 Toyota Tacoma Double Cab Prerunner SR5
    Halo Headlights Black W/ LED LED TailLights Bermuda 3rd Brake Black Pioneer/Alpine System Debadge Entire Rebadge Driver Side Door Black Volant CAI Tool Box ARB Front Bumper Flat Black Painted Grill Surround
    i would say... its an 09... you should have bumper to bumper... so show the dealer it has this problem...
    go get one of those fm transmitter things for portable mp3 players or cd players
    where you set the station on the transmitter and your radio and it picks it up
    then show them with that where its perfectly clear until the bass hits hard...
    if they don't want to fix it... then... get their boss... and their boss... and so on and so forth
  3. Aug 22, 2009 at 7:55 PM
    jlvhrse
    jlvhrse Well-Known Member
    Jen
    SoCal SGV
    2009 TRD Sport 4X4 Long Bed
    LSK front and rear LT and stuff
    Hmmm I think I had a problem similar to this and the plug from the amp to the subs wasn't pushed in ALL the way... did you check the wire connections?
