2009 Radio in 2008 Tacoma
Discussion in 'Audio & Video' started by mscouch, Jun 28, 2009.
  1. Jun 28, 2009 at 6:46 PM
    mscouch
    mscouch [OP] Member
    Scott
    Auburn, AL
    2015 Tacoma 4 Door Long Bed
    Leer High Rise Shell, Nerf Bars, Westin Brush Guard w/Superwinch 9,500 lbs.
    This is my first post on this forum & I need some help!
    I swapped out the 2008 Toyota factory CD player that came with my Tacoma with a friends 2009 Toyota factory CD/MP3/WMA-SAT compatible radio. The new radio works fine but now I want to add SAT radio via the new stereo if possible. From what I have read on this site I do NOT have the factory prewired SAT antenna to connect to.
    Is it possible to install a SAT antenna along with the SAT radio receiver/harness and if so what parts will I need?
    Thanks
    Scott
  2. Jun 29, 2009 at 12:36 PM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Always working on the stereo, painted the front skid plate black to match the truck, debadged , toy tech ultimate lift kit, light racing UCAs, ARB bumper Looking into a supercharger and new exhaust.
  3. Jun 30, 2009 at 2:28 PM
    mscouch
    mscouch [OP] Member
    Scott
    Auburn, AL
    Thanks for the info. From what I could tell the parts would cost about $200.00.
    Does this sound correct? Do you know which specific part numbers I will need?
    Thanks again for the help!
    Scott
  4. Jul 2, 2009 at 8:15 PM
    danny23
    danny23 Well-Known Member
    Hey man, question about your 09 radio swap. Was it just plug and play to put your 09 radio into your 08 truck? Or did you have to do something special? Thanks
  5. Jul 3, 2009 at 7:47 AM
    mscouch
    mscouch [OP] Member
    Scott
    Auburn, AL
    It was just plug and play. I had no instructions at the time so I just felt around and popped the a/c controls off. I then saw the 4 bolts holding the radio in and I unscrewed them and unplugged the old radio and put the new one in and plugged it in. I tested it before I bolted it back in.
    NO problems whatsoever & it only took 10 minutes.
    Now I just need some help getting the SAT function going!
  6. Jul 8, 2009 at 7:29 AM
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    Are you able to hook up your Ipod and control it from the radio?
  7. Jul 8, 2009 at 7:33 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    No. You can plug it into the aux input though, but you still need to control through the ipod.
