2009 sat radio help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JMike, Apr 2, 2009.
  1. Apr 2, 2009 at 9:16 AM
    JMike
    JMike [OP] Member
    I have the pre wire and antenna hooked up already on my truck. I would like to know what all do I need for my sat radio to work? Do I need to by a recever etc.....
    Thanks for the Help :D
  2. Apr 2, 2009 at 9:34 AM
    JTech
    JTech Well-Known Member
    Phoenix, Arizona
    Silver 09 Double Cab 4x4 Sr5 Off-Road
    Locking Bed Boxes, built in air compressor, Husky Liners(not really a mod but I love them)
    Mine just worked when i pressed the sat button. My truck is apparently and anomaly because I am not paying for XM and have had it for over 4 months.
  3. Apr 2, 2009 at 9:58 AM
    JMike
    JMike [OP] Member
    MUST BE NICE.
    I have the sat button on my deck and the antenna on the top. I just want to know what I have to do to get it working?
    P.S Is it Xm or Sirius?
    Thanks
  4. Apr 2, 2009 at 10:11 AM
    GoBlueFan
    GoBlueFan Well-Known Member
    Jon
    Bossier City, LA
    08 SR5 PreRunner
    Step bars, billet grill with custom TOYOTA, MB Quart RSI 216 components, Hifonics ZXi 4410, RAAMmat deadened doors/back wall/roof covered with ensolite , 24" Magnaflow muffler, hand polished stock exhaust tip, tinted, OEM TRD Bilstiens all around with 1/4" spacers up front to level it out. Sport wheels added.
    Ask your dealer service center. They will know.
  5. Apr 2, 2009 at 10:46 AM
    Slab
    Slab Active Member
    West Virginia
    09 TRD Off road double cab
    do you plan to install sirius or xm?
  6. Apr 2, 2009 at 10:49 AM
    JMike
    JMike [OP] Member
    Which one do you recomend? Which one is better?
  7. Apr 2, 2009 at 10:55 AM
    Slab
    Slab Active Member
    West Virginia
    I have Sirius, but it just depends on your preference. If I had to start over, I would probably go with XM. XM has MLB and you can add the Sirius stuff by adding the best of Sirius package. baseball isn't letting Sirius add mlb to it's best of XM package. They are both owned by the same company now.
    If you add Sirius, here are the instructions:
    http://www.tacomaworld.com/forum/audio-video/28731-sirius-factory-radio-install-2009-tacoma.html
    If you add XM, here are the instructions:
    http://www.tacomaworld.com/forum/audio-video/22644-09-xm-radio-install.html
    It's pretty easy. you need to make sure you have a compatible tuner, a wiring harness for the factory tuner and a wiring harness to get to the factory sharkfin antenna.
    Another option is to replace the factory head unit, if you go that route, your best bet is to just call Crutchfield and let them walk you through what you need. It's not hard either.
  8. Apr 2, 2009 at 11:36 AM
    SurfnWolf
    SurfnWolf Well-Known Member
    Fayetteville NC
    2006 Tacoma Prerunner Double Cab
    Do the 2009 Sat reciever that are Stock fit into the 05-08 Tacomas?
  9. Apr 2, 2009 at 11:46 AM
    09TRD
    09TRD it is what it is
    Oakwood GA
    09 TRD Off Road
    Not yet,
    You have to get the tuner and wiring harness. It cost around $325 for both from the dealer, not installed. I would check ebay/craigslist first. It is XM.
  10. Apr 2, 2009 at 12:03 PM
    Slab
    Slab Active Member
    West Virginia
    There are OEM Toyota XM and Sirius receivers for 05-08s. they are more than likely the same as the '09 except the instructions. Plus the '09 has a sharkfin sat antenna
