2009 squeaking when moving up front
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xwillx93, Nov 6, 2011.
  1. Nov 6, 2011 at 5:46 AM
    xwillx93
    xwillx93 [OP] Well-Known Member
    Will
    Stuart, FL
    09 Tacoma
    MBRP "Cool Duals" dual side swept exhaust, Volant Intake, Blacked Out Tail lights, Touchscreen Kenwood DDx616 with a 10" Kicker CVR in a custom Box, 2 Kicker Comp 6" Speakers, Removed front and rear mud flaps, Weathertech Floormats, Kobalt Slim Toolbox, Chevrolet Air compressor
    I have an 09 reg cab 2.7l. Lately ive been noticing when i drive, im getting a consistent squeaking noise that seems to be coming from the front. Not entirley sure what it is, but i noticed the other windy day...when i closed my door and walked away, the wind picked up shaking the truck. and it was still squeaking. Nothing too major but, itd be nice to figure out what it is!
  2. Nov 6, 2011 at 6:26 AM
    spithead051
    spithead051 Well-Known Member
    Patrick
    Fairfax, VA
    09 AC 4x4 OR S/C'ed!
    Supercharger, ICON 2.5VS w/ CDC, TRD T/X Pro Wheels, 255/85/R16 BFG MT KM2's, APEX three hoop bumper, Smittybilt X20 Comp Gen 2, Allpro IFS skid, All-Pro Sliders, Dynomax exhaust, aFe Stage 2 si, URD 2.85 stealth pulley, Oil pressure, oil temperature, boost, A/F ratio gauges, Devil horns, WO seat covers
    Sub'd. I've got the same issue with my 09 AC V6 4x4. I think it might be the front bushings on the suspension components but I haven't had the time to really poke around
  3. Nov 6, 2011 at 1:05 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    On my 09 AC it's the body mount to the left of the driver's side foglight recess (when looking into the lower grille opening). It squeaks like crazy after it rains; I hit it with WD40 and it quiets down until it rains again.
    I tried actual lubricants, like lithium spray, breakfree CLP, teflon stuff, graphite, and oddly enough the WD lasts the longest. One of these days I'm just going to pull the bumper off, jack up the body a bit, and pull/clean/grease that bushing thoroughly.
  4. Nov 6, 2011 at 1:20 PM
    Tac 2009
    Tac 2009 Well-Known Member
    black 09 SR5
    another windshield issue? inside or outside the cabin?
  5. Nov 6, 2011 at 1:23 PM
    GeauxTigers
    GeauxTigers //TRD
    Caleb
    Sterlington, Louisiana
    '14 TRD DCSB Off-Road 4x4
    265/70/17 BFG KO2/17"x7" Pro Sema Wheels/OME 884/Bilstein 5100 front & rear/HeadStrong 1/4" TP spacer/Deaver 1.5"-2" AAL/Mud-Flap delete/Westin Bed mat/UltraGauge/ WeatherTechs/AFE Pro Dry Drop in Filter/debadged/AVS in-channel window visors/color-matched OEM grille/Kicker 6.75" Components in front door/Alpine KTP-445U power pack behind factory head unit/
    mine squeaks too, it didnt start until i put the leveling kit on :crapstorm: and it bothers me so bad! ive sprayed every possible point of contact that i can think of with lithium grease and it still squeaks! ahhh!!!
  6. Mar 19, 2012 at 7:26 PM
    GrEeN WeEnY
    GrEeN WeEnY Member
    Aaron
    Bend, OR
    Sub'd. My '11 RC does the same thing. It's not a huge squeak fot its there at every bump and is annoying.
  7. Mar 19, 2012 at 7:32 PM
    Coma2010
    Coma2010 2012 TRD Off Road Prerunner
    Dustin
    Glendale
    2012 TRD PreRunner Dbl Cab
    Oh yeah and TICK TICK TICK TICK TICK
  8. Mar 19, 2012 at 7:47 PM
    GrEeN WeEnY
    GrEeN WeEnY Member
    Aaron
    Bend, OR
    just letting you know the injectors are still working ;)
  9. Mar 19, 2012 at 7:59 PM
    VanCity4x
    VanCity4x The shit show
    DJ
    BC
    05 Prerunner SAS
    3link 1tons on 40's and sum stuff
    That is the biggest problem Ive had with my Taco. Sounds like shit next to any domestic 5.4L +
    Is it a squeek or squeeling. Check if its the serpintine belts and the idler pully. Otherwise suspension, windshield differential could be cause.
  10. Mar 19, 2012 at 9:03 PM
    GrEeN WeEnY
    GrEeN WeEnY Member
    Aaron
    Bend, OR
    Its a squeak/creak coming from the front left happens on every bump
