2009 Taco Lift Options
Discussion in 'Suspension' started by STLTaco09, Dec 17, 2008.
  1. Dec 17, 2008 at 2:34 PM
    STLTaco09
    STLTaco09 [OP] Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    Hello all, new member here. 2009 DC TRD Sport.
    I bought this truck with every intention of lifting it, probably 3". I've researched plenty, and I am aware of my options. The more I read though, the more hesitant I am. People are having drive line vibrations, front diff problems, CV problems, etc - even with lifts as small as Bilstien 5100s set at 1.75" with the rear TSB. Is there any sure-fire way of getting a minor lift without having these issues? Are these issues a result of a poor install (i.e. would a professional installation result in no issues).
    Lastly, if I am concerned with factory warranty, am I better off just putting the whole idea on hold until the warranty expires? I'd rather not battle a dealership 2 years down the road about front diff problems that would have occurred even without the lift...
    I posted this over in TN as well, I'm sure some of you are members at both places. Hopefully nobody minds posting the same question in both forums.
    Thanks for any insight - lots of good info here. Hopefully I'll be able to contribute at some point.
  2. Dec 17, 2008 at 4:52 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    if u want a good 3" setup w/ no issues, get 3" coilovers w/ a diff drop (if 4x4) and new UCA's. the rear would be good w/ 1.5" NEW leaf packs
  3. Dec 18, 2008 at 2:16 PM
    cdnbanker
    cdnbanker Well-Known Member
    do the 09's need the new leaf packs too?
    frig, i will have to get them done.
  4. Dec 18, 2008 at 2:22 PM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Skip the diff drop. On the new trucks it doesn't have as much of an effect as it did on the older models. I have one in my truck and would have been happier without it.
    Driveline vibrations can be helped by installing a center support bearing drop kit on the rear driveshaft to reduce U-joint angles.
    http://toyteclifts.com/index.php?pa...ategory_id=80&option=com_virtuemart&Itemid=53
    Good luck and post pictures!
  5. Dec 18, 2008 at 2:59 PM
    jhodge83
    SC
    17 XLT Sport
    well if u want the rear to be level w/ the front after 3" in the front....then u'll need a 1.5" leaf pack.
    and as for the diff drop, $15-20 is worth the extra piece of mind
  6. Dec 18, 2008 at 3:04 PM
    jhodge83
    SC
    17 XLT Sport
    i installed my allpro over mine w/ no probs
  7. Dec 18, 2008 at 3:18 PM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    +1.
    Very good point, but if you have no plans to install Bud Built skids, then do the diff drop. Then you can take it off later if you DO get the BB skids...
  8. Dec 18, 2008 at 3:44 PM
    LonghornTaco
    Minnesota
    Agreed.
  9. Dec 18, 2008 at 3:54 PM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    flowmaster 40 series, tinted windows, airaid CAI, removed 2nd filter, aries black bull bar
    wow so how much was everyones lifts here?
  10. Dec 18, 2008 at 4:00 PM
    LonghornTaco
    Minnesota
  11. Dec 18, 2008 at 4:10 PM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    wow so got to put down a good amount of money to get a good lift huh
  12. Dec 18, 2008 at 4:13 PM
    LonghornTaco
    Minnesota
    Just put it this way - you get what you pay for. And more money doesn't always mean better, but does more often than not... :)
  13. Dec 18, 2008 at 4:14 PM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    yeah i know what you mean, i want to do it right the first time for sure
  14. Dec 18, 2008 at 4:15 PM
    LonghornTaco
    Minnesota
    New coils, struts, upper control arms and either an AAL or complete leaf pack for the rear.
  15. Dec 18, 2008 at 4:16 PM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    so do i get the 5100's with this as well as the toytec or no
  16. Dec 18, 2008 at 4:18 PM
    LonghornTaco
    Minnesota
    I did.
    My suggestion (gathered from others here) is either the adjustable coilovers on the 5100s or the OME 885 springs and OME shocks. I went with the former...
  17. Dec 18, 2008 at 4:20 PM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    and the coilovers is the lift? and you have the 5100 set at stock right
  18. Dec 18, 2008 at 4:22 PM
    LonghornTaco
    Minnesota
    Bingo.
  19. Dec 18, 2008 at 4:28 PM
    norcalbb11
    norcalbb11 Nor*Cal
    Cali
    09 Taco Sport 4x4
    thanks, sorry i kinda took over this guys thread but i also have a 2009 so figured why not ask questions as well haha
  20. Dec 18, 2008 at 4:29 PM
    LonghornTaco
    Minnesota
    it will probably help him too! :)
