2009 Taco weird stalling incident
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lovemytaco2020, Jul 25, 2020.
  1. Jul 25, 2020 at 9:23 PM
    lovemytaco2020
    lovemytaco2020 [OP] Member
    2009 Taco V6 4wd
    Mostly just wanted a highly reliable truck that would fit in my garage. Until today, it has been. Hopefully, this is just a small set back...
    TnShooter[QUOTED] likes this.
  2. Jul 25, 2020 at 9:23 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I agree a Tablet or a phone would be a huge pain in the butt.
  3. Jul 25, 2020 at 9:25 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    there are dozens of responses comparing the 2
    simply illustrates folks expectations miss the target
    with coal burning diesels
    stonkin 5-7 litre engine available to ALL
    folk spend 25-65K for a Tacoma only to be DISsatisfied
    as if they are being strong armed or held hostage
    i dont get it
  4. Jul 26, 2020 at 2:58 PM
    lovemytaco2020
    2009 Taco V6 4wd
    Would a bad resistor show up in an error code? I just plugged in the scanner and it is not showing any problems. The truck has been running fine. Maybe I just chalk this one up to a one time deal???
  5. Jul 26, 2020 at 3:03 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    No, it will not show as a code.
    Jimmyh likes this.
  6. Jul 26, 2020 at 7:30 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No code for resistor.
    TnShooter likes this.
  7. Jul 27, 2020 at 8:56 AM
    lovemytaco2020
    2009 Taco V6 4wd
    If the part is fairly inexpensive, should I just go ahead and replace it? Or, should I just be prepared to "bypass" the resistor trick?
  8. Jul 27, 2020 at 12:18 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    If you have a multi-meter, test the resistor rather than firing the parts cannon.
    Jimmyh likes this.
  9. Jul 27, 2020 at 5:22 PM
    lovemytaco2020
    2009 Taco V6 4wd
    If it is starting just fine now, am I likely to get a faulty reading? Also, what amps should I get if it's normal? Many thank!
  10. Jul 27, 2020 at 7:52 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Simply replacing the resistor will tell you nothing.
    If it were me this is what I would do:
    I would make sure I have a jumper prepared that I could place across the connector that works. The next time I had the issue show up install the jumper. If it works great and I know the resistor is the issue. If it doesn't then I know that the resistor is not the issue.
    Firstly you don't want to read amps on the resistor. Set it to the resistance mode and it will read in Ohms (Ω). I have to see if I can locate the resistance reading for a good resistor. Give me a few minutes.
    This is what you look for on the fuel pump resistor reading the terminals on the resistor connector:
    FUEL PUMP RESISTOR INSPECTION
    1.INSPECT FUEL PUMP RESISTOR
    (a) Check the resistance.
    (1) Using an ohmmeter, measure the resistance between the terminals.
    Resistance:0.71 to 0.75 Ω If the result is not as specified, replace the fuel pump resistor.
    tirediron likes this.
  11. Jul 27, 2020 at 8:03 PM
    lovemytaco2020
    2009 Taco V6 4wd
    Hi Jimmy,
    So I just purchased the specific Toyota software for my iphone code reader. It showed two faults, both b2799 Engine Immoblizer System Malfunction. This makes sense, as my Taco started for a few seconds and then died. I have no idea why it would start with the same key 30 minutes later. Any idea? Any idea how to prevent this from happening again/fixing it?
    Many thanks!
  12. Jul 27, 2020 at 8:09 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Looks like it would have to be a wiring harness issue, Your Key Chip or the ECU.
    This may require a dealer to look at the ECM Code and data.
    b2799 Code:
    This DTC is output when one of the following occurs:
    1) the ECM detected errors in its own communications with the immobiliser code ECU;
    2) the ECM detects errors in the communication lines; or
    3) the ECU communication ID between the immobiliser code ECU and ECM is different and an engine start is attempted.
    Before troubleshooting for this DTC, make sure no certification ECU DTCs are present.
    If present, troubleshoot the certification ECU DTCs first.
    Causes:
    •Error in communication between ECM and transponder key ECU, and in communication line
    •Communication ID is different during communication with transponder key ECU
    Trouble Areas:
    •Wire harness and connector
    •ECM
    2WD likes this.
  13. Jul 27, 2020 at 8:19 PM
    TnShooter
    Deogee
    STOCK
    The next time the issue occurs, take a look at the flashing key Light.
    It’s the light the flashes when the key is not in the ignition. It’s next to the clock in my truck.
    See if it is still flashing.
    At this point, it’s beyond my level of diagnosis.
    Hopefully you get it figured out.
    If you do, let use know.
    Jimmyh likes this.
  14. Jul 27, 2020 at 8:27 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Key in and still flashing means it is not reading the key or reading it improperly. Do you have a second key you could use?
  15. Jul 27, 2020 at 8:27 PM
    #35
    lovemytaco2020
    2009 Taco V6 4wd
    Do you suspect that it will happen again? I was reading, on another post, that it would only happen to some other guy if he sat is his car for an extended period of time with the key turned to the off position. That basically describes my trip to the grocery store. I was waiting in my Taco for a decent amount of time, with the key turned to the off position, waiting for the person to bring out my groceries. Maybe I just need to remember to remove my key from the ignition? Maybe somehow that made the key recognition fail due to some bug in the code that basically tells the Taco to stop reading the key data after some period of time. Thougths???
  16. Jul 27, 2020 at 8:30 PM
    #36
    Jimmyh
    SC
    2012 Prerunner SR5
    Possible... One thing for sure, Time will tell.
    I wish you the best and hope it doesn't happen again. You could do the experiment and leave the key in again with it off and see what happens. If it is repeatable then you have your answer.
  17. Jul 27, 2020 at 8:49 PM
    #37
    lovemytaco2020
    2009 Taco V6 4wd
    Thanks Jimmyh. I appreciate your help!
  18. Jul 28, 2020 at 12:13 AM
    #38
    challenger3406pk
    challenger3406pk Member
    Reedsville PA
    08 sport dc
    I have had the same problem over the last year to two. Never any check engine light. I did clean the maf sensor and it went away for a long time, over 6 months. Seems very random when it does happen. For a stretch in the beginning it was almost weekly. I havent checked the key light suggestion yet. I do know this. Ifyou cant get it to stay running, disconnect the battery and hold the key to start for 30 seconds. Once you reconnect it. It will start up. ( after one or two sensing cycles) If you ever figure it out send me a message!
  19. Jul 28, 2020 at 1:13 AM
    #39
    Jimmyh
    SC
    2012 Prerunner SR5
    This is why I hate the Engine Immobilizer System and Chipped Keys.
  20. Jul 28, 2020 at 10:11 AM
    #40
    lovemytaco2020
    2009 Taco V6 4wd
    Yes, wife's and valet key. I'll keep them with me in case it happens again. Great idea!
    Jimmyh[QUOTED] likes this.
