2009 Taco won't start, no codes, cranks
Discussion in 'Technical Chat' started by 09_tacoma, Aug 3, 2012.
  1. Aug 3, 2012 at 1:01 PM
    Specalt
    Specalt Well-Known Member
    Phoenix
    2001 TRD 4x4
    Plugged Fuel Filter?
  2. Aug 3, 2012 at 1:05 PM
    Tacoma Mike
    Southern Maine
    Mylene ???????????????????????????????????????
    Can't help ya if your not typing.. LOL
  3. Aug 3, 2012 at 1:06 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    I vote air filter
  4. Aug 3, 2012 at 1:10 PM
    dbkid05tacoma
    dbkid05tacoma Well-Known Member
    Brooks
    Phoenix, Arizona
    05 long travel 4.0L
    Total chaos long travel, fox 2.5 coil overs, glassworks unlimited fenders front and rear, DMZ fab motor mounts, Bilstien 5100s in the rear, k&n cold air intake, 33/12.5r17 red letter grabbers
    i had this same problem a while back and the only way i figured out what was wrong was by taking off my air filter and spraying starter fluid into the throttle body. So try spraying starter fluid into the throttle body while cranking. if the engine fires then you probably have something wrong with your fuel system. if it doesn't fire then you probably have an issue with your spark plugs or ignition system.
  5. Aug 3, 2012 at 1:41 PM
    09_tacoma
    09_tacoma [OP] Forever at a crossroads
    Mylene
    North Pole
    09 Taco V6 4x4 DLCB TRD Sport
    Headlights, Exhaust, grill, Kings all around resi suspension. Camburg UCA's, Clarion double din
    I was in a meeting ;) Some of us have to work you know :p
    It's clean
    Yes I have a fob key, no I do not believe the key is the issue.
  6. Aug 3, 2012 at 1:52 PM
    Tacoma Mike
    Southern Maine
    :p:p:p:p:p:p:p to you too... heheheheheh
    OK This is what i want you to do.
    i know you have done some of this already but please..
    Have the keys in your hand and get in the truck and close the door.
    put the key in the ign and double check your flashing immobilizer light that it goes out.
    turn the ign on ONLY. check to see if check engine light comes on.
    If this is a yes then !!!!!!!!!
    take key out of ign.
    open and close the drivers door twice.
    using the key fob lock the doors
    using the key fob hit the unlock button twice to open all doors
    insert key into ign and try to start.
    that's all i can do from here.. time to get back to work...
  7. Aug 3, 2012 at 2:17 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Awesome having a Toyota Mtech in the forum but if it doesn't work, it's because you you forgot to add "pat your head and rub belly" in there somewhere. :D
  8. Aug 3, 2012 at 2:32 PM
    Tacoma Mike
    Southern Maine
    DAM knew I forgot something.. :frusty::frusty::frusty:
  9. Aug 3, 2012 at 3:40 PM
    09_tacoma
    Mylene
    North Pole
    Well I did that plus all of the above, still a no go :confused:
    Kidding about the rubbing belly and patting part :p:p
  10. Aug 3, 2012 at 3:42 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Did you pull the air filter?
  11. Aug 3, 2012 at 3:52 PM
    09_tacoma
    Mylene
    North Pole
  12. Aug 3, 2012 at 3:55 PM
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    Although less likely, I would also consider assessing the battery.
    Do a quick swap and see. Alternator could be an issue too.
  13. Aug 3, 2012 at 4:16 PM
    Tacoma Mike
    Southern Maine
    Ok then your going to have to get it somewhere for a analysis.
    One more thing is I know you said you had 1/4 tank but try adding some fuel.
    I was hoping your immobilizer was in limbo and the sequence sometimes wakes it up. You don't have any damage to the bottom of the tank do you?
    Good luck and sorry the wake up message didn't work..
  14. Aug 3, 2012 at 4:40 PM
    09_tacoma
    Mylene
    North Pole
    I've been preparing for that. I work up in a remote location so civilization is a ways away. I got someone to find a towing dolly, before everything closed for the long weekend. If I can't get it going by Sunday night I'll have them come up and tow me back home :(
    Thanks for the help! (that goes for everyone!!)
    Every suggestion helps!
  15. Aug 3, 2012 at 4:52 PM
    #35
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    Seriously, try adding some gas, like Taoma Mike said, I have seen where a float will hang up, and register X amount of gas but be truely empty!!!! Put a gas cans worth in and see what happens.
  16. Aug 3, 2012 at 5:12 PM
    #36
    09_tacoma
    Mylene
    North Pole
    I will try this tomorrow. I'm too far from the truck now. I know the mileage I've put since I last filled up. I'm confident my gauge is accurate.
  17. Aug 5, 2012 at 11:02 AM
    #37
    09_tacoma
    Mylene
    North Pole
    :annoyed:
    Looks like I'll be getting towed home tomorrow.
    :bananadead:
    :mad::(
  18. Aug 5, 2012 at 4:05 PM
    #38
    Tacoma Mike
    Southern Maine
    Let us know what the correction was..
    Sorry....
  19. Aug 9, 2012 at 9:18 AM
    #39
    09_tacoma
    Mylene
    North Pole
    Will do! It's in the shop today. Hoping to get some news in the couple of hours
  20. Aug 9, 2012 at 6:16 PM
    #40
    03is300ztk
    Zach
    07 Tacoma 4X4
