2009 Taco won't start, no codes, cranks
Discussion in 'Technical Chat' started by 09_tacoma, Aug 3, 2012.
  1. Jan 16, 2013 at 3:14 PM
    #121
    BamaToy1997
    Bill
    Navarre, FL
    We had the same thing at GM, Technical Assistance. I was actually offered a job with them once. It is a difficult job to have for sure.
    Can't just lemon a car that easy. There has to be a failure that has been diagnosed, and repairs MADE 3 times in the same system before you can even THINK of trying to call Lemon Law, which is different from the Magnison Moss Act by the way.
    Let's hope it all worked!!!
  2. Jan 17, 2013 at 6:42 AM
    #122
    09_tacoma
    09_tacoma [OP] Forever at a crossroads
    Mylene
    North Pole
    09 Taco V6 4x4 DLCB TRD Sport
    Headlights, Exhaust, grill, Kings all around resi suspension. Camburg UCA's, Clarion double din
    Hahaha welcome to Canada my friend ;)
    -24F this morning, didn't like it very much because I hadn't plugged it in overnight but it fired up after a second :D
  3. Jan 21, 2013 at 7:59 AM
    #123
    dpak
    dpak Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Toytec/Eibach coils w/ 5100's set at 0, Toytec 2.0 Aluma Rear Shocks, Toytec Boss Leaf Springs, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, Elusive Elements Mesh Grill
    Glad to hear your truck is up and running. Just curious, was the repair covered under your warranty or did you pay out of your pocket?
  4. Jan 22, 2013 at 3:38 PM
    #124
    09_tacoma
    Mylene
    North Pole
    It was covered under warranty so I didn't pay a cent. If I would've been presented with a bill I would have fought it because they refused a rental (which I qualify for with my warranty coverage) or loaner and I was without a vehicle for 7.5 weeks. So the service was lacking
  5. Jan 22, 2013 at 3:57 PM
    #125
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    Glad to hear that you FINALLY have your truck back. I know this has to of been a living hell going through this for such a long time.
  6. Dec 30, 2014 at 7:36 AM
    #126
    BamaToy1997
    Bill
    Navarre, FL
    This thread was referenced to me by a new member having an identical problem with their Tacoma Prerunner. I am going to post this here for him, as well as anyone else who may need this.
    ENGINE IMMOBILISER SYSTEM: B2799: Engine Immobiliser System Malfunction
    DTC B2799 - Engine Immobiliser System Malfunction
    DESCRIPTION
    This DTC is output when one of the following occurs: 1) the ECM detected errors in its own communications with the immobiliser code ECU; 2) the ECM detects errors in the communication lines; or 3) the ECU communication ID between the immobiliser code ECU and ECM is different and an engine start is attempted. Before troubleshooting for this DTC, make sure no certification ECU DTCs are present. If present, troubleshoot the certification ECU DTCs first.
    Zoom and Print Options
    WIRING DIAGRAM
    INSPECTION PROCEDURE
    PROCEDURE
    1. CHECK HARNESS AND CONNECTOR (TRANSPONDER KEY ECU ASSEMBLY - ECM)
    (a)Disconnect the T10 ECU connector.
    (b)Disconnect the E7 ECM connector.
    (c)Measure the resistance of the wire harness side connectors.
    Standard resistance:
    (d)Reconnect the ECU connector.
    (e)Reconnect the amplifier connector.
    Result
    C -- REPLACE ECM
    B -- REPLACE ECM
    A -- REPAIR OR REPLACE HARNESS OR CONNECTOR
  7. Dec 30, 2014 at 8:09 AM
    #127
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Maybe the cheap route would be to start by having your keys re-initialized to the vehicle? Back in August, I had to call AAA for locking the keys in the car. They came out, got me in but then had to come to my house a day later when they ended up redoing the codes for my keys.
    I've had the B2799 code one time- actually earlier this month, along with ECM code P0606. These were cleared and then I had a p0444,0445 a week or so later. The hypothesis by a tech I know is that it could have been a hiccup caused by my remote starter and a faulty gas cap- the P0441 came on a week after the other codes, replaced the cap and no more codes after a few hundred miles. The 0441 caused the 0444-0445 and that relayed to a P0606 (most people say replace ECM, but according to Toyota tech, it's an airflow ratio issue tripping the code)... and if there was a hiccup when starting in the cold morning while using the remote (there's a key in the dashboard), then it could be all related. I had NO drivability issues whatsoever by the way.
    So, in a nutshell, I'd go the cheap way first. Have the codes redone to try and resolve. I think you can do it at Home Depot too. Then start to worry about an ECM.
    Do you have a remote starter?
    Sorry for the long, rambling post... Starbucks coffee with extra shot of espresso.
  8. May 28, 2019 at 6:55 PM
    #128
    raf-1200
    raf-1200 Active Member
    2008/2012 Tacoma 2tr-fe rear wheel drive
    Lowered, turboed, haltech, body kit, mags, 3 inch pipe
    I’ve read through this but may have missed it. Did the security light always go out with the correct key in it?
    I am having a b2799 issue as well and it is with a new key but the light goes out when keys inserted...
    scouterjan likes this.
  9. Jul 18, 2019 at 11:21 PM
    #129
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    I have had my 09 4 banger 6 months and this happened last week. 3 rd time it's happened. It starts up after a while
    I just have a factory key no fob
    No warning lights etc
  10. Jul 18, 2019 at 11:38 PM
    #130
    scouterjan
    Jan
    A thought just entered my memory . Every time this has happened my truck was parked with key in the ignition in the off position for about 1 hour
  11. Jul 27, 2020 at 9:02 PM
    #131
    lovemytaco2020
    lovemytaco2020 Member
    2009 Taco V6 4wd
    Were you ever able to verify this theory? My 09 just did the same thing. I was sitting in a parking lot with the key in the off position for a fair amount of time before it happened.
  12. Jul 29, 2020 at 7:55 AM
    #132
    scouterjan
    Jan
    Morning. No I could never verify it but it hasn't happened again. I just dont leave the key in the ignition unless it's running or in the accessory position
