2009 Tacoma aux input - Low Volume fix?
Discussion in 'Audio & Video' started by STLTaco09, Nov 17, 2009.
  1. Nov 17, 2009 at 12:40 PM
    STLTaco09
    STLTaco09 [OP] Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    I've been searching for a way to increase the input volume of the aux input jack on my Tacoma. Even with my ipod/iphone all the way up, I find myself listening to the radio on max (especially when the windows are down).
    I came across this:
    http://www.youtube.com/watch?v=jbniHbwO-CE
    Looks easy enough to build, think it would work? From what I can tell, power would have to be supplied to it in a manner different from what he did, along with the inputs/outputs changed a bit as we won't be using standard RCAs. Neither of which would be overly complicated.
  2. Nov 17, 2009 at 4:25 PM
    spp
    spp OC, Kalifornia
    OC California
    Try this: http://www.logjamelectronics.com/pdcblpak.html
    I put one on my wifes Camry, Zune version, and it is much louder and the volume control on the Zune has no effect on the volume of the head unit.
    They also make one that plugs into the back of the stereo so all you have is one cable coming out and allows control of the Zune or Pod from the stock headunit.
  3. Nov 18, 2009 at 2:19 AM
    NuovoTech
    NuovoTech Well-Known Member
    Upper Left Corner
    09 Tacoma 4x2
  4. Nov 18, 2009 at 4:51 AM
    STLTaco09
    I know replacing the HU will fix it. I guess I'm trying to find a $20 "preamp" that I can build that will also fix the issue.
  5. Nov 18, 2009 at 12:54 PM
    NuovoTech
    Upper Left Corner
    09 Tacoma 4x2
    I watched that video, very clever, it appears with that gizmo you could boost the gain on your aux input 20dB. I know I do not have the skills to build that gizmo. :eek:
