2009 Tacoma TSB Leaf Springs
Discussion in 'Suspension' started by Outlaw, Mar 24, 2009.
  1. Mar 24, 2009 at 8:05 AM
    Outlaw
    Outlaw [OP] Well-Known Member
    Iowa City, Iowa
    '10 TRD SPORT Acc.Cab Mag Grey 4x4 Auto
    Weathertech floor liners, stone and bug deflector, Putco Element In Channel Window Visors, Viper remote starter, Harley lighted hitch cover, Herculeze front mudflap, Metal Miller Harley Grill Emblem, SockMonkey design Bedside Decals and 3rd Brake light TRD decal, K&N Air Filter, Goodyear Duratrac 265/70/17 C load, Valor Exhaust tip, De-badged tailgate, Advantage Tonneau Cover, Tacoma bedmat, Bicycle Mount Rail mounts, Custom Ipod holder. Stock Suspension :( (winter wheels: 2014 16" stock steel wheels plastidipped black with general arctics 265/75/16)
    There is a TSB on 2009 Tacomas anti friction pads, however I dont know where to find it.
    I took my truck to the dealer because I was getting some serious squeaking coming from the Leaf Springs, and they told me there is a TSB on the anitfriction pads wearing out between the springs. So they are putting on new pads and greasing them. Not getting the add a leaf, but I havent had any issues yet with bottoming out, though I havent had a heavy load yet. I am planning on putting my motorcycle in the back and testing it out.
  2. Mar 24, 2009 at 8:27 AM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2016 Limited DCSB 4x4 Blazing Blue
    They added the leaf on my 09 via the not yet defined 09 TSB and it made a difference. It has initially lifted the back up about 1.-1.5 inches. Im sure it will settle though. I can tell it also changed the ride a bit and now it feels stiffer.
    No squeaking at all.
    I have only seen these;
    1TSB Number:TSB005408NHTSA Number:10025203TSB Date:May 8, 2008Date Added to File:July 17, 2008Failing Component:
    Tires:pressure Monitoring And Regulating SystemsSummary:
    Tire pressure warning system initialization.
    2TSB Number:TSB005708NHTSA Number:10025202TSB Date:May 9, 2008Date Added to File:July 17, 2008Failing Component:
    EquipmentSummary:
    Driver and passenger side floor mats retaining clips; pe
  3. Mar 24, 2009 at 8:42 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    you will want to get the rear harsh ride TSB done....bottoming out or not.
  4. Mar 24, 2009 at 8:42 AM
    Outlaw
    Iowa City, Iowa
    Yeah thats all I have seen for '09's too, but the mechanic at the dealer told me about the friction pads.
    i really do want the new leafs too!
  5. Mar 24, 2009 at 9:21 AM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Hi, can you tell me where I can get all the TSB print out? So I can talk to the dealer? By the way I have a 09 DC Taco
  6. Mar 24, 2009 at 10:09 AM
    KMN-BLU
    Destin, Fl
    try here; or google 2009 tacoma tsb
    http://www.edmunds.com/maintenance/...mileage=500&zip=92126&type=tsb&serviceType=#2
    or here
    http://www.aboutautomobile.com/TSB/2009/Toyota/Tacoma
    just take those tsb numbers into the dealer, they will have a hard copy. The rear leaf replacement has not been issued on the 09 yet. However each dealer is handling it on a case by case issue right now. If you look at your rear springs and you only have 3 leafs then you could be elgible for the replacement. Just take the truck to the dealership and tell them it bottoms out if you carry any loads in the back. Thats what I did and they replaced mine without any questions.
  7. Mar 24, 2009 at 10:25 AM
    wing103
    Boston
    Thanks OLDGENZR.
    Thanks for the info.
  8. Apr 8, 2009 at 2:37 PM
    Outlaw
    Iowa City, Iowa
    Just talked to my service mgr about hauling sand bags this winter and truck bottoming out a little. Had him look up the TSB and told him I have the same part numbers.
    He said he would talk to his Regional service mgr, cause he would have to get it approved.
    called me today and said if its bottoming out with 2000 lbs too bad, but with only 1000lbs or less since the load rating is 1380, go ahead and order the parts. no questions asked. I will schedule my service when the parts come in.
    Thanks for all your help everyone!
  9. Jun 8, 2009 at 3:53 PM
    BringbackSnacks
    BringbackSnacks The H
    Pasadena,CA
    2017 TRD PRO
    im curious about TSB, do we just get the printout and take it to our local dealer and voila! they'll change it for free? because ill be getting my 2009 double cab at the end of the month, so should i just have them do it before i even get the truck? or will that issue already be fixed?
  10. Jun 8, 2009 at 4:04 PM
    BLKSR5TACO
    BLKSR5TACO Well-Known Member
    Craig
    Chesapeake, Va
    09 BSP Tacoma PreRunner SR5
    Tint / Debadged / Bed Lights / N-Fabs
    i just checked my 09' dc prerunner and found that i only have 3 leafs. i'm gonna call tomorrow and complain about sagging and see if i can get the replacements.
  11. Jun 9, 2009 at 6:28 AM
    TacoTycoon
    TacoTycoon Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    the key phrase to tell the dealer is.." I have a harsh ride when under load" or any version of that
  12. Jun 9, 2009 at 6:33 AM
    JDrew
    JDrew Well-Known Member
    Evansville, IN
    '08 Tacoma TRD RT
    Kenwood DNX9140, DRL Mod
    Mine is having the TSB done as we speak.
  13. Oct 19, 2009 at 1:04 PM
    trialsmm
    trialsmm Well-Known Member
    Macon,Ga USA
    16 Tacoma, TRD Sport
    What is the TSB number for 2008/2009 Tacoma. My '09 bottoms out with about 700-800lbs. I have searched the internet and have not found that TSB to print out.
    I just called my dealer and they have had no complaints.
    Mick
  14. Oct 19, 2009 at 1:37 PM
    briinh
    briinh Well-Known Member
    Maine
    08' Tacoma sr5
    i just called a dealer just this min, i have an appointment Oct. 26, my rear end squeaks when i get in the truck, so hopefully they add a leaf!..
  15. Oct 19, 2009 at 1:41 PM
    Brunes
    Brunes abides.
    Rotorhead
    I wouldn't hope for that....Completely different problem.
    If you have squeaking...They will add anti friction pads and grease to your current springs.
    If you were having other issues with cargo capacity they might have considered the TSB (which is NOT an add a leaf btw)...
  16. Oct 19, 2009 at 1:45 PM
    briinh
    Maine
    08' Tacoma sr5
    so should i tell them i also have cargo issues?
  17. Oct 20, 2009 at 10:42 AM
    trialsmm
    Macon,Ga USA
    i own a '09 Tacoma double cab pre-runnner. I noticed with my motorcycle loaded (200 lbs) and about 250 lbs of rocks the rear sags and felt "different". The front end felt very light also at interstate speeds.
    I printed the TSB out and made a trip to my local dealer with the rocks still in the bed. They told me to drop it off in the morning and they would check it out.
    With just the rocks in the bed, the spring are reveresed and the frame bumper is about 5 inches from touching the frame. One can see the rub markes on the frame from the bumpers hitting the frame. I also notice there is a squeak in the rear area.
    Mick
  18. Oct 22, 2009 at 9:07 PM
    stevenb5214
    stevenb5214 Active Member
    steven
    sierra vista
    silver 09 sport pkg 3 inch lift
    blacked out lights rims 255 75 17 bfg mud terrains 3 inch rough country lift
    ya i am going to go down there tomi never knew any of this it is great to no the squeaking drives me nuts when i am hunting and driving slow all i here are squeaks form the rear and when i load my dirt bike up and my tool box and riding gear my truck sags what kinda truck sags with that little amount of stuff i hope they fix this problem if not i am not goin gto stop buggin them till they do something i will let you no what they say tom
  19. Oct 23, 2009 at 7:45 AM
    Outlaw
    Iowa City, Iowa
    T-SB-0305-08 Rev 1.pdf
  20. Oct 23, 2009 at 11:31 AM
    stevenb5214
    steven
    sierra vista
    i went to dealship today i have a lift on already mind oyu and told them truck bottoms out with little weight no questions asked they covered it and on tuesday getting leaf spring added and yesterday when hunting i punctured my outer cv boot on brush and they are even covering that under warrenty sieera toyata will cover anything they are awsome
