2009 Tacoma w/ Kenwood DNX 8120 Crossover setup question
Discussion in 'Audio & Video' started by kcossabo, May 3, 2009.
  1. May 3, 2009 at 5:18 PM
    kcossabo
    kcossabo [OP] Kevin Cossaboon
    Kevin
    Round Hill, VA
    2009 4dr 4x4 Tacoma
    Firestone Destination A/V, Kenwood DX8120, ScanGauge, Second Back Up Camera, Aris Bull Bar, KC Driving Lights, Weston Nerf Bars, Tonneau Cover, Bed Extender, Dynamat in doors and floor, Kenwood KSC-SW10 150W Compact Powered Subwoofer, Kenwood KFC-1362 5-1/4" 3-Way Speaker (Rear), Kenwood KFC-1682ie 6-1/2"/6-3/4" 3-way Speakers (front), Heated Signal Muth Mirror System, ScanGauge II, Viper 5701 Alarm with Tilt, Proximity, 4 window remote up/down, and remote start.
    Setting up the DNX 8120 in a double cab 2009 taco, with stock speakers. The truck had the non-JBL stereo if this matters.
    The Head unit permits the setting of a cross over for the front speakers. I set the size (there is no 6x9, so I will guess on a size), and a CROSSOVER frequency.
    At what frequency should I set the crossover? I assume this is depended on the Frequency response of the tweeters, but, I have never done this before.
    thanks
    Kevin Cossaboon
  2. May 3, 2009 at 6:20 PM
    bass mechanic
    bass mechanic Well-Known Member
    colorado springs, colorado
    2009 tacoma Access cab TRD offroad in black
    none
    the best answer is se it to your ear. the best way to do this is to play somthing with a lot of bass, like rap or hip hop you want to crank it up pretty good and while your listening to it listen for distortion from the speakers they will sound like your overpowering them.
    if you move the xover higher you will eliminate some of the low bass frequencies. choose a 12 db / octive slope that HU goes all the way to 24 db/ oct move the crossover frequency from the lowest setitng to the highest setting untill the distortion goes away. then set the xover to 18 db / oct and back the xover down 1 setting. it should get you close.
    your objective here is to retain as much bass as possible without the speakers getting distorted. i would guess without an amp you can get away with about 60-80 hz with an amp a little higher than that.
    i have the same head unit as you.
  3. May 4, 2009 at 4:43 AM
    kcossabo
    Kevin
    Round Hill, VA
    2009 4dr 4x4 Tacoma
    thanks, will try this. I was playing with it with music, but your procedure is much more defined, than "does that sound better to you?"....
    Appreciate the help.
