2009 Toyota Tacoma Electric Tail Gate Lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by killerken, Oct 5, 2008.
  1. Oct 5, 2008 at 1:33 PM
    killerken
    killerken [OP] Well-Known Member
    Philadelphia
    09 toyota tacoma dbl cab trd
    Access LE Cover Toyota Factory Nerf Bars Dynolock Tail Gate Lock
    :)Hello everyone!
    I have finally made up my mind that I am going to get a electric Tail gate Lock for my 2009 Toyota Tacoma Dbl Cab, Short bed, TRD Package with back up camera.
    Now here is where I need everyone's help.
    I am looking at two manufactures:
    The first manufactur is DynoLock which makes one specifically for the 2009 Toyota Tacoma with back up camera.
    The Second Manufacturer is Pop and Lock but I don't see one specifically designed for the 2009 with back up camera but there is a model PL8520 for 2005 and up.
    1st Question: Has anyone installed one of these units on a 2009 Toyota Tacoma with Back up Camera?
    2nd Question: Does any one have experience with one of these devices or even better with both of these devices and knows which one is better?
    3rd Question: Which one would you choose, would you by the DynoLock, try the PL8520 Pop and Lock or wait for the new electric Pop and Lock.
    Thank in advance for all your help.
    Ken:cool:
  2. Oct 5, 2008 at 5:33 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    I have DynoLock install on my 09Tacoma...
    It take about 1.5 hours for the installation. Do a search, I reply to a post with some photos after the installation.
    feel free to ask me for everything.
    aslo I believe DynoLock is the only company have it.
  3. Oct 5, 2008 at 5:39 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Pop and lock doesn't have anything that fits the '09s yet.
  4. Oct 5, 2008 at 5:55 PM
    killerken
    Philadelphia
    Wing103:
    What do you think of the construction of the DynoLock unit. Does it look like something that will last for a long time. The reason why I ask is what happens if the unit stops working. I know this could be a long shot but hey as we all know things happen. My fear is that it stops working and with my Access LE tonneau cover I will have no way of getting into my truck bed.
    Also I heard people mention that they asked the mfg for a heavy duty actuator. Did you do this?
  5. Oct 5, 2008 at 6:31 PM
    wing103
    Boston
  6. Oct 5, 2008 at 10:28 PM
    killerken
    Philadelphia
    Wing103
    Sure I would like to see the installation instructions. If you could post them it would be great.
    I am just being a little causious about Dynolock since I have not heard too much about this comany. Pop and Lock I have heard of alot. My other concern is when I look at the photo's it seems like the actuator is only bolted on by one bolt and I am concerned that over time that this coud turn or twist. When I look at the pop and lock versions for previous models it looks like it is more secure then the Dynolock but I could be completely wrong.
    Ken
  7. Oct 6, 2008 at 4:11 AM
    wing103
    Boston
    You are right. killerken.
    it only use one bolt with a spacer that come with the package. but you know, it did what you want it to be.
    Please see the attachment
  8. Oct 7, 2008 at 4:31 PM
    killerken
    Philadelphia
    thank you
  9. Oct 7, 2008 at 5:03 PM
    wing103
    Boston
    I wish I can help you out.
  10. Oct 17, 2008 at 7:07 AM
    killerken
    Philadelphia
    Just received my Dynolock
    Hope to install it this weekend.
  11. Oct 17, 2008 at 7:35 AM
    wing103
    Boston
    Good luck, By the way, it is not that hard to install, first find the rubber thing under your driver side,so start from there to route the wire to the tailgate, after route the wire, start go back to tie wrap it up...with other wire. and fellow the instruction.
  12. Oct 19, 2008 at 4:20 PM
    killerken
    Philadelphia
    wing103
    Thanks for the recomendation. Did't get a chance to install it this weekend. Hope to try and do it next weekend.
  13. Nov 9, 2008 at 9:13 PM
    1.21jigowatts
    1.21jigowatts Member
    SO CAL
    09 tacoma sport
    I am not too handy.... can I do this myself???
  14. Nov 10, 2008 at 7:35 AM
    wing103
    Boston
    I see you post on another post, but it is a easy installation, and it have a phone # for technical support.
  15. Nov 13, 2008 at 6:59 PM
    1.21jigowatts
    SO CAL
    09 tacoma sport
    pop & lock said today (11-13-08) that their tailgate lock for the 09 taco will be ready in 4-6 weeks for purchase.
  16. Nov 14, 2008 at 6:18 AM
    Joe B
    Joe B Well-Known Member
    Does the Dynolock have a separate keyfob or does it work on the Toyota keyfob button?
  17. Nov 14, 2008 at 7:39 AM
    2009Taco
    2009Taco Well-Known Member
    Northern Virginia
    2011 Highlander
    it uses your Toyota keyfob, it is wired into your system as another door
  18. Nov 14, 2008 at 7:46 AM
    Joe B
    Thanks,2009Taco.
    Now I don't know which one to get.
    The pop & lock or the Dynolock.
    The "actuator is only bolted on by one bolt and I am concerned that over time that this coud turn or twist" kind of scares me a bit.
    The Dynolock will be locking and unlocking often in using the Toyota keyfob button.
  19. Nov 14, 2008 at 7:55 AM
    2009Taco
    Northern Virginia
    2011 Highlander
    No problem, I am a little worries about that as well. When I get home, I am going to open it backup and see if I can either stick a block of something up there, or try and add another place to mount it. I went with the Dynolock because I didn't want an extra key, but I am in and out of my vehicle often, and because I don't have a Tonneau yet, I am not using the tailgate much. I am going to check out that Pop-N-Lock when it comes out, and see what I want to do from there.
  20. Nov 14, 2008 at 8:01 AM
    Joe B
    Yeah,I'll probably wait till the Pop N Lock comes out.
    One less electrical thing to worry about.;)
