2009 trd sport need to beef up rear leafs
Discussion in 'Suspension' started by douggytundra, Feb 15, 2010.
  1. Feb 15, 2010 at 9:32 AM
    douggytundra
    douggytundra [OP] Well-Known Member
    orlando
    09 D-CAB 4x4 White Sport Taco
    I use my truck for work and also have a cap on the back so i would like to beef up the leafs a little to get it up to stock again. What are my options guys.
  2. Feb 15, 2010 at 9:33 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    What do you have now?
  3. Feb 15, 2010 at 9:36 AM
    douggytundra
    orlando
    Just the stock 2009 trd sport double cab 4x4.
  4. Feb 15, 2010 at 9:39 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Have you had the leaf spring TSB done?
  5. Feb 15, 2010 at 9:41 AM
    douggytundra
    orlando
    was there actually one for the 2009 or was it just for older models. so the answer is no I have not.
  6. Feb 15, 2010 at 9:41 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    x2 and look into some airbags.
  7. Feb 15, 2010 at 9:44 AM
    douggytundra
    orlando
    I was looking for leaf replacement or something of that nature.
  8. Feb 15, 2010 at 9:45 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Do you want lift as well?
  9. Feb 15, 2010 at 9:47 AM
    Carlo
    Carlo Well-Known Member
    CA
    2010 Taco Magnetic Grey
    5100's all around, front at 0 with Ebiach springs up front; Wheelers 3 leaf AAL rear, Spidertrax
    Ok, I need to ask (very new guy; just had my taco 6 days) what is a TSB?
  10. Feb 15, 2010 at 9:49 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Technical Service Bulletin
    Replacement of rear 3-leaf leafs with 4-leaf leafs. And if you dont have a trd, you get the trd billies.
  11. Feb 15, 2010 at 9:57 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    And here's the TSB...........
    I Had it done to 2010.
  12. Feb 15, 2010 at 10:24 AM
    douggytundra
    orlando
    no lift just get it to hold the weight a little more level. Since the weight is in the truck all the time it looks stupid to be tilted back the way it does.
  13. Feb 15, 2010 at 10:26 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    You can always get a custom leaf pack made. Other than that the Firestone airbags are cheap and work great from what I hear.
    But since the weight is always in, if you just get a 1" or 1.5" add a leaf it will squat a little bringing you close to stock rear height with no weight.
  14. Feb 15, 2010 at 10:28 AM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    Print the TSB out and take it to your dealer. Take it with a load on and tell them it should not look or ride like it does. If they give you grief, take the TSB out and show it to them. If that doesn't work, roll the TSB up like a cone, and poker the idiot in the eye with it!
  15. Feb 15, 2010 at 10:47 AM
    afd23a
    The Dynamo of Dixie
    If the TSB springs don't fix it for you, there was a guy on here who put on some supersprings and did a write up about them here
  16. Feb 15, 2010 at 9:03 PM
    dougdiggler
    dougdiggler Member
    Doug
    Longview WA
    08 TRD Sport 6spd on 265's
    Husky Floor Mats, Leer Canopy
    I have a revtek lift w/ add a leafs in the rear, do you think I can still get the TSB? Seems like it is nose high by about 3/4 of an inch. Will measure and speak w/ the dealer
  17. Feb 16, 2010 at 5:12 AM
    douggytundra
    orlando
    Thanks guys for all the help....
  18. Jun 21, 2010 at 7:46 AM
    flash183
    flash183 New Member
    Baltimore
    Tacoma '05 TRD
    So I have a '05 TRD and was wondering, can I still get this TSB or does the vehicle need to be in warranty to qualify?
    Thanks
