2009 TSB woes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JaredM, Dec 28, 2009.
  1. Dec 28, 2009 at 8:25 AM
    JaredM
    JaredM [OP] Active Member
    AVS Bugdeflector II
    Hey. I took my 2009 4x4 Sport double cab to the dealer complaining about the shifting weirdness. I mentioned the tsb and the one for the rear leafs. After a few hours he said it did not apply to my truck? It still shifts weird under 20mph like it down shifts instead of up when accelerating. I called them back the day before Christmas eve and they said to bring it back and a mgr would look at it.
  2. Dec 28, 2009 at 8:28 AM
    alx_alx_69
    alx_alx_69 Well-Known Member
    Alex
    Hope Mills, North Carolina
    Yep I just called the toyota 1800 number, they told me I had to take it to a dealership, to have a look because my 2010 is not on the recent tsb only 2005-2008 taomas
  3. Dec 28, 2009 at 8:32 AM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Take it to another dealership or call Toyota CS.
  4. Dec 28, 2009 at 8:33 AM
    JaredM
    AVS Bugdeflector II
    They said if they can not reproduce the issue then not applicable? wow that is almost impossible on the lot.
  5. Dec 28, 2009 at 9:31 AM
    JaredM
    AVS Bugdeflector II
    got an appt for wed morning. will keep you posted
  6. Dec 30, 2009 at 12:14 PM
    JaredM
    AVS Bugdeflector II
    Looks like they are going to do the TSBs. They said the trans shift one is done. But they started the rear and took it appart and said the parts are not there. So they are getting me a rental
  7. Dec 30, 2009 at 12:18 PM
    Taco-NB
    New Brunswick
    Good news.
    Cheers.
  8. Dec 30, 2009 at 12:31 PM
    JaredM
    AVS Bugdeflector II
    will the rear tsb lift it at all? if so...what should I do with the front?
  9. Dec 30, 2009 at 12:36 PM
    Brunes
    Brunes abides.
    Rotorhead
    It might lift the rear end a little bit- My A/C sport long bed was less than 1 inch.
    If you notice a lift to the rear end or you want to level it all out-GEt some bilstien 5100s.
  10. Dec 30, 2009 at 12:41 PM
    JaredM
    AVS Bugdeflector II
    how much are they?
  11. Dec 30, 2009 at 1:31 PM
    JaredM
    AVS Bugdeflector II
    so then I guess I need bigger tires....wooot
  12. Dec 30, 2009 at 1:51 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    My truck is geting the rear leaf tsb right now.
  13. Jan 1, 2010 at 8:00 AM
    JaredM
    AVS Bugdeflector II
    Nice. Hey got my truck back yesterday. What a difference. The shifting is not erratic now and I do feel that the back is lifted up a bit. Not sure how much, I guess time will tell. I failed to measure the wheel wells prior to the TSB. The guy said the springs are higher but settle after a while and that no alignment is needed.
  14. Jan 1, 2010 at 8:42 AM
    JaredM
    AVS Bugdeflector II
    can someone explain why some refer to the rear TSB as a spring TSB and not a leaf tsb?
  15. Jan 1, 2010 at 8:47 AM
    jodiddly33
    jodiddly33 Well-Known Member
    Jonah
    DFW
    2010 Golf TDI
    Leaf SPRINGS I think? :)
  16. Jan 1, 2010 at 8:52 AM
    JaredM
    AVS Bugdeflector II
    Right, but the leaf springs...some have said that they got 4 on their tsb? I do not see 4 on each side. I think that is only on a AAL.
  17. Jan 1, 2010 at 9:16 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    You should have 3 primary and one helper leaf. The bottom helper one does not go all the way across like the main 3.
