2009 V6 (1GR-FE) started knocking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Plasmech, Oct 4, 2021.
  1. Oct 12, 2021 at 6:09 PM
    Plasmech
    Plasmech [OP] Well-Known Member
    2009 SR5 V6 Access Cab TRD Off-Road
    Funny, the more people I mention the 114k on the original factory plugs to, the more I hear about people putting 125k, 150k, 175k on their plugs.
    tacotoe likes this.
  2. Oct 12, 2021 at 6:20 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I gone as far as 50k miles and at that point the center electrode was noticeably worn. It's a easy enough task to do and not that expensive. I've both read and been told by a friend (now retired auto mechanic) that having a larger spark gap that the coil will run hotter, leading to bad coil.
    Other plug types can go longer but the factory plugs on the first and second generation aren't iridium. Not the v6's
  3. Oct 12, 2021 at 6:22 PM
    Plasmech
    Good info, thanks.
    Wonder if I should change the wires, too?
    How do I know if the coils are bad?
  4. Oct 12, 2021 at 6:26 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    No wires only coil boots, if they are in good condition with no cracking or oil contamination put some dielectric grease in them and you should be fine.
    If oil is present in the spark plug tubes you will need to do valve cover gaskets soon.
    tacotoe likes this.
  5. Oct 12, 2021 at 6:29 PM
    Plasmech
    I should replace the boots only and put dielectric grease in them?
    tacotoe likes this.
  6. Oct 12, 2021 at 6:31 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You can but it isn't necessary to replace them if they aren't cracked, carbon tracked, or soaked in oil.
    tacotoe likes this.
  7. Oct 12, 2021 at 6:41 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I believe if you had a bad coil, you'd be getting a misfire that would be noticeable. Likely no need to change coils.
    vtown, Dm93 and tacotoe like this.
  8. Oct 12, 2021 at 6:42 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    No need to replace anything but the plugs, just start with that. And a little dielectric grease in the boot on the sides like just a small amount with a q-tip or just put a small amount on the plug itself. The grease will make the boot easier to remove 50k miles from now. Just a small amount, your not basting a Turkey.
    Dm93 likes this.
  9. Oct 12, 2021 at 6:42 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    And a check engine light
  10. Oct 17, 2021 at 4:54 PM
    Plasmech
    Is there a modified plug torque spec for when anti-seize is applied? Maybe +3 ft*lb?
    Thanks.
  11. Oct 17, 2021 at 6:00 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    Less torque not more. Go back a page, that little screen shot says reduce torque by 1/3 if using anti-seize.
    I've never put a torque wrench on a plug:anonymous:
    Just good, snug, and done. It's not a lug nut on a big rig.
