200K - Maitenance Questions (San Diego based)
Discussion in '1st Gen. Tacomas (1995-2004)' started by yahee, May 19, 2023.
  1. May 19, 2023 at 5:53 PM
    yahee
    yahee [OP] Member
    1998 Toyota Tacoma 2WD, 4cyl, 2.4L, Manual 5-spd
    Lifted
    What do I need to be doing after 200k that wasn't done before or more regularly?
    Also if anyone has a good mechanic in San Diego (central) would be helpful!
    TACCOOOOOOOOOOOMA!
  2. May 20, 2023 at 4:51 AM
    1stevertaco
    1stevertaco Well-Known Member
    atlanta
    2000 taco 4x4
    sway bar end links
    my thought of maintenance every 100k, would be as followed:
    spark plugs
    upper and lower ball joints
    check valve adjustment
    visually inspect all vacuum lines for cracking or brittleness
    more than likely all of your bushings for your suspension components could be using a replacement.
    and as for things that "arent done more regularly"
    change all fluids, (be careful with transmission fluid, if you dont know when it was last changed)
    grease u joints
    replace pcv valve
    fix leaks, if the truck has been neglected.
    this should get you started
    yahee[OP] likes this.
  3. May 20, 2023 at 5:50 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    Did you have the timing belt changed at 100K? If not it's long overdue. Lower ball joints as well?
