200k+ Miles - How they doing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Delmarva, Jan 12, 2021.
  1. Jan 12, 2021 at 1:11 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    How many cars have you owned in a lifetime? Your generalization is false about all makes being the same. There are junkers out there. If you want to see the ratings look at consumer reports.
  2. Jan 12, 2021 at 1:46 PM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    180k 2011 and I’ve had it since 157k.
    Only things I’ve done since getting the truck is oil changes and spark plugs (for peace of mind)
    Only thing that went wrong so far was a bad fuse.. OEM was $13 I believe from the stealership
    That’s it so far
  3. Jan 12, 2021 at 2:38 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    LOL normally distributed data following a bell curve? That’s what I’m wrong about? Feel free to point out where I said “all makes are the same,” I’ll wait.
  4. Jan 12, 2021 at 5:16 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'm at 210,000 on my 2007 that I bought new. I have some paint peeling on the hood. The seats and carpet are a little dirty, but she still runs like new. I replaced the alternator at 180,000 miles and one U-Joint at 170,000. Other than normal stuff like belts, batteries, brakes, and fluids I've done nothing else to it.
    stonybrook and tedusmc1345 like this.
  5. Jan 12, 2021 at 6:01 PM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    2005 with 145k. Ac compressor went out at 125k. Blower motor and resistor and my power steering pump was just replace not because it had failed but it was leaking a little. I replaced a hub assembly a few years ago. All in all not bad for almost 16 years of ownership. Ohh and it still runs like a clock.......and also ticks like one as well. I do have a question about you guys that replaced your engine. Where and how was that total process including cost and time involved? Thanks
  6. Jan 12, 2021 at 6:10 PM
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    Ford never built a truck better than a Toyota , never will
  7. Jan 12, 2021 at 6:24 PM
    op9nf
    op9nf Well-Known Member
    Nilo
    Bothell,Washington
    2013 Tacoma TRD DCLB 4X4
    Bilstein 5100’s With OME 288. 2inch blocks with freedom off-road extended shocks.
    I had a 2008 Tacoma 4 cylinder manual work truck with 350,000 miles before I traded in for a 2016. The only parts that I replaced was a bad fuel pump, starter, and an alternator. My 2016 work truck now have over 130,000 miles and no issues whatsoever. Before that I had a 2005 Ford Ranger. It’s spend more time in the garage repair shop than on the road.
    igno1tus likes this.
  8. Jan 12, 2021 at 6:42 PM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    2009 with 353,000 on it. I drive it without a worry and I've had zero mechanical problems with it. It's pretty much stock except for billies in the front and 265's. Regular maintenance is the key. No leaks, no check engine light. It acted weird once, I cleaned the throttle.body and maf sensor and never did it again.
    R0dzilla75 likes this.
  9. Jan 12, 2021 at 6:59 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    SoCal truck. I was pretty high mileage driver for a while (95% highway/5% offroad), now I have a beater full size and use the Tacoma as a weekend offroad more like 50/50 highway/offroad. 2009 DCSB SR5 by 4x4 w/ 295,000 miles
    Beyond typicall maintenance...
    75k: front/rear brakes, battery
    140k: LCA's, front/rear shocks (Bilstein 5100s)
    200k: CV boots, front/rear brakes
    220k: LCA's, front/rear shocks (went w/ Icons)
    240k: battery, rear wheel bearing, rad mounts, AC console lights
    275k: front wheel bearings, a/c shrader valve & recharge, carrier bearing, u-joints, front brakes, front/rear shocks (rebuild), front headlight bulbs
    295k: body mounts, shifter bulb
    I'm probably missing something or off by 5k miles, but this is what I remember from the top of my head.
  10. Jan 12, 2021 at 7:10 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Bought the truck at 62k and now it sits at 205k. Nothing major other than your regular maintenance items. Doesn’t burn any oil, runs and drives the same as when i first got it. Rust free and trouble free. U joints and coolant system flush is next on list.
  11. Jan 12, 2021 at 7:14 PM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    You'll be replacing twice that on a ranger or an F150. Ask me how I know
  12. Jan 13, 2021 at 1:27 PM
    avery0829
    avery0829 Well-Known Member
    Western Washington
    2005 Tacoma DCLB Sport
    Bilstein 5100, Trail edition wheels, 265/70/17 Falkens
    2005 Tacoma V6, bought with 95k and now at 170k
    Replaced:
    Both front wheel bearings
    Intermediate steering shaft
    Blower motor resistor and harness pigtail
    Center console lid
    All idiler pulleys and tensioner
    Rubber brake lines
    CV axle due to boot ripping
    Basic maintenance, brake pads, plugs, fluids, etc.
  13. Jan 13, 2021 at 2:28 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    We’ve got a lot of Ford vans and on the past Ford trucks that get hammered everyday. A lot of idle time and slow speed driving around the airport. They keep on going.
    Accipiter13[QUOTED] likes this.
  14. Jan 13, 2021 at 2:43 PM
    97RangerXLT
    97RangerXLT Member
    Nick
    NoVA
    2013 ACLB 4x4 MT TRD Sport
    Stock so far!
    Having owned 3 Rangers (95-97), I can assure you that's a bad plan! I probably spent more time under them than driving them. Ford likes to make really stupid design decisions that make working on them 10x harder than any other vehicle I've ever worked on. Plus, it often took me at least two tries to get any repair done right, and some new problem would always pop up shortly afterward. There's a reason those trucks are so much cheaper than the competition in the resale market!
    Novafrk likes this.
  15. Jan 13, 2021 at 4:11 PM
    #35
    Accipiter13
    California
    '11 DCLB 4x4 Sport
    I don’t think I really need to tell you why referring to a 1995 model when discussing a 2020 model is kind of silly, do I?
  16. Jan 13, 2021 at 5:50 PM
    #36
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    All of the Fords in our fleet are honestly having way too many issues that I'd ever consider one. They're either vans/sedans/SUV, but still.
    Anyway, for the OP; you should ask this question in the "stock trucks" thread. I think too many people w/ modded trucks are going to skew the answers you're looking for. Unless you plan to buy a modded truck.
    Most of mine was preemptively replaced so not fair to say. I think the biggest non-wear item is the steering rack that is waiting to be replaced. Have a new one here, just no time yet. I'm at 155k fwiw. Other than that, it's been self inflicted or an aftermarket part that needed replacing or rebuilding.
    ARB1977[QUOTED] likes this.
  17. Jan 13, 2021 at 5:59 PM
    #37
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    2010 - 111k miles. Besides brakes, oil, and normal maintenance things; the only thing I needed to "do" was got a new frame. I havent had to replace any door lock actuators or other items **knock on wood**
  18. Jan 13, 2021 at 6:06 PM
    #38
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Mine was nearly perfect until 200k then all my problems seemed to hit at once
    fatfurious2[QUOTED] likes this.
  19. Jan 13, 2021 at 6:08 PM
    #39
    FloTaco
    FloTaco Well-Known Member
    Bay Area, CA
    2021 SR DC 4X4
    2007 TRD OR, 213k miles.
    -Full brake job, drive shaft carrier bearing and all U-joints at 170k
    -New OEM steering rack at 200k, turns out the old one was just fine!
    -ECGS clamshell bushing for the hell of it at 200k
    -clutch at 120k with URD throw out bearing kit.
    The truck is simply amazing. Just needs oil changes, do a coolant flush every 100k. The engine purrs quieter than my 2021 with 1200 miles. Selling the ‘07, sad to see it go.
  20. Jan 13, 2021 at 6:11 PM
    #40
    Jimmy92870
    Jimmy92870 Well-Known Member
    Texas (DFW)
    07 DCSB PreRunner
    Almost at 150K over here on my 07 and all I've done is basic maintenance (brakes plugs fluids) only "major" thing I had to do was replace my alternator which recently died on me.
