200k+ Miles - How they doing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Delmarva, Jan 12, 2021.
  1. Jan 13, 2021 at 6:13 PM
    #41
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    ughh! Im not looking forward to that. This spring Im replacing the pulleys, waterpump, radiator and hoses. I went to a 1 piece driveshaft so I dont have to worry about the carrier bearing anymore.. Hopefully not too much else
    Oreo Cat[QUOTED] likes this.
  2. Jan 13, 2021 at 6:49 PM
    #42
    sbb
    sbb Active Member
    CNY
    2020 Red OR DCSB, 2006 Indigo OR
    Highly customized radio presets / Metric fuel adapter
    06 OR MT, 225k. NYS with a salt-happy county.
    Resister thing in the overhead display needed soldering
    Rear leafs about a month before the recall
    Alternator
    Water pump
    Blower resister pack
    Blower resister pack again
    F*** it, rewired it to use a mosfet
    Fuel door
    Brakelines front to back every six years, perhaps this "new alloy" stuff will end that
    Power steering is starting to cog a bit, so whatever that ends up being
    Tail light lens screws have all sheared the clip things they screw into
    Exhaust every few years
    Shocks, Ball joints, usual wear items
    Windshield seal sometimes leaks and fills the overhead console, which then pees on your arm when you start the truck (insert Flexseal gif)
    Not as good as my FJ60 did, but it'll do.
  3. Jan 13, 2021 at 6:55 PM
    #43
    DRAWN
    DRAWN Well-Known Member
    2016 QUICKSAND AC SR5 4X4
    Sliders, 6112's, full skids.
    I think it’s safe to say a naturally aspirated v6 from Toyota has the potential to last much longer than the eco boost 4cyl they put in the new rangers. People freak out when ecoboost f150’s reach 200k. A 2nd gen will go 250k to 300k with proper maintenance period. Watch wheel bearing and u joints.
    sbb likes this.
  4. Jan 14, 2021 at 8:51 AM
    #44
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Mine has 166,000 and it's only needed a water pump and A/C condenser. Everything else is factory parts. Runs perfect. I'm not OCD about maintenance either, just do stuff when required, nothing fancy, although I do run longer OCI (7500 miles/10 months) with full synthetic oil and oversize oil filters. (Toyota specifies conventional OCI 5000 miles/6 months.) I fully expect to get 300k+ out of it.
  5. Jan 20, 2021 at 9:06 AM
    #45
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    I got my 2012 almost 4 years ago with 21k on it and have 188k.
    • Both front wheel bearings
    • AC Compressor (probably need the condenser too)
    • Rear leafs (more of a choice for lift and weight)
    • Emissions pump valves x3 (2012 problem)
    • Bluetooth in the radio went out so I upgraded.
    Then just brakes, tires, oil. This spring I need to do shocks and I have an oil leak at the front of the engine. Probably the timing chain door, sounds like a good time to do the serpentine belt and pulleys.
  6. Jan 20, 2021 at 10:01 AM
    #46
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Incorrect.
  7. Jan 20, 2021 at 10:07 AM
    #47
    vtwinjunkie
    vtwinjunkie Well-Known Member
    2005 TRD Sport
    Bilstein 5100's, 885 coils, Dakar Leafs, SPC LR UCA's, 275-70-17
    Can you elaborate?
    Not to disagree just want to hear it.
    Oreo Cat likes this.
  8. Jan 20, 2021 at 10:11 AM
    #48
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    I'd say 11 is the best year, but your really splitting hairs at the point. Talking about 10 year old trucks, the best one you can buy is the one that has been maintained the best. I'd rather do an airpump delete on a well loved 2012 than buy a beat to shit 2011.
  9. Jan 20, 2021 at 11:25 AM
    #49
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    There's no issue w/ the 12 - 15's. $3 uni filter on the SAIP and it's not a worry anymore.
  10. Jan 20, 2021 at 11:37 AM
    #50
    mabepossibly
    Andrew
    Albany, NY
    2021 TRD OR Manual
    That is the air pump. The valves that it pumps into fail regularly and send the truck into limp mode. There is a TSB and warranty extension on it.
  11. Jan 20, 2021 at 12:13 PM
    #51
    jackrabbit14
    jackrabbit14 New Member
    Jack
    Texas
    2014 Silver Tacoma Trd Sport PreRunner V6
    ranch hand brush guard, ranch bed shell, Trd Pro wheels and Falcon AT3 tires, roof basket with nilight pods and light bars.
    14 about to hit 160k. only thing ive had to really mess with are the bushings/bearings and changing out shocks and replacing brakes. Other than that no engine problems and rides like a dream still. the owner before me drove pretty much only on the highway and traveled a bunch so it had very little city driving which i believe helped its longevity. Im having trouble with a slight pull towards the left consistently, not sure where its coming from but with nearly 160k, no complaints from me. Obviously i maintain it the best i can by driving without harsh acceleration or braking and take care of monthly items like oil and cleaning air filters and whatnot but worth it considering its saving my wallet from having to make big repairs in the future.
    Hope this helped a little bit!
  12. Jan 20, 2021 at 1:14 PM
    #52
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    :duh:
    iNcoRrEcT
    mabepossibly likes this.
  13. Jan 20, 2021 at 2:04 PM
    #53
    ToyoCoMo
    ToyoCoMo Well-Known Member
    DP
    Banks of the Mississippi River
    2013 Toyota Tacoma DCSB
    Lol, wtf? I'm going to roll over 150k in the next week or so and I've had no issues whatsoever. I have done all the standard recommended maintenance and upgraded my suspension with a Bilstein 5100/OME and new upper/lower control arms but this was completely voluntary.
    DGXR likes this.
  14. Jan 20, 2021 at 3:14 PM
    #54
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    Tell me about it.
  15. Jan 20, 2021 at 4:09 PM
    #55
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    There's always an extension on emission systems. That's standard. A TSB means nothing. It's a fix bulletin for the techs. Not a recall. There's TSB on damn near anything that breaks.
