200K miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by alex's taco, Jan 19, 2025.
  1. Jan 19, 2025 at 7:32 PM
    alex's taco
    alex's taco [OP] New Member
    2018 gold taco
    2008 Taco w/ 200K miles. I recently brought it in to the shop for a tune up. They told me that I'm going to need a new rear differential soon and it will be expensive, a couple thousand. In some ways it seems reasonable to put that kind of money into this truck since new (even used) cars are so expensive. But, I also wonder about whether it's worth it with such high mileage...
  2. Jan 19, 2025 at 7:36 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Why are they claiming it needs a new differential? Did they find metal in the gear oil or is a bearing actually going bad instead? Is it making an audible noise?
  3. Jan 19, 2025 at 7:36 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'd be curious how they cam to the conclusion the rear diff is on it's way out if you had no complaints about it.
  4. Jan 20, 2025 at 4:15 AM
    AnotherDude
    AnotherDude Well-Known Member
  5. Jan 20, 2025 at 4:29 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Welcome to TW. That’s a great picture.:thumbsup:
    Not sure about the rear differential replacement for your truck. I would be inclined to get a second opinion before spending any money.
  6. Jan 20, 2025 at 6:53 AM
    fxntime
    Rolling back around to this, I'd pull the driveshaft and inspect the u joints and carrier bearing well before I'd let someone rip into the rear end. At that mileage this may be the actual issue and can simulate a rear axle noise or vibration.
  7. Jan 20, 2025 at 6:57 AM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    Like stated above, ujoints and carrier are wearable. Replacing your third member is unlikely.. also a couple thousand is bonkers.
  8. Jan 20, 2025 at 7:14 AM
    alex's taco
    2018 gold taco
    Thanks for all of your replies! I can't remember exactly what they said. It was a few weeks ago and there were other things on the list, so I was a bit overwhelmed. Honestly I didn't even know what a rear differential did. (Okay, that's embarrassing) But something they noticed about it while it was up on the lift... I will give them a call and try to get a little more clarity.
    usmc2msu and hinmo24t like this.
  9. Jan 20, 2025 at 4:22 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Get a 2nd opinion. I doubt if the rear diff needs to be replaced. Even if it does, I think you'd be better off repairing it than trying to sell it with a bad diff. I'd fix it then decide if I wanted to sell or keep it.
    Hardscrabble likes this.
  10. Jan 20, 2025 at 4:29 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Looks like they are looking at the female repair manual. Ask in the regional forums for a referral to a trustworthy shop.
  11. Jan 20, 2025 at 6:16 PM
    Shotgun Clay
    Shotgun Clay Well-Known Member
    There are 3 Tacos on my road with 300K plus, none of which have had the diff replaced. (we compare notes at neighborhood bbq’s)
  12. Jan 20, 2025 at 6:20 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    You can get a junkyard diff replaced for under 2k.
