200k Tacoma maintenance.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Owenhall, Jan 14, 2025.
  1. Jan 14, 2025 at 6:42 PM
    Owenhall
    Owenhall [OP] Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    My truck is approaching 200k is there anything I should replace or check that I haven’t already done. I have changed all fluids and replaced a few suspension components.
  2. Jan 14, 2025 at 7:38 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    For 200K I gave my Taco a cooling system makeover as preventive maintenance - new CST radiator, antifreeze, fan, fan clutch, thermostat, water pump, and some bypass hoses. It is a 200K mile thing I do in general to our vehicles we intend to keep another 100K. The hoses, belt and pulley bearings were done by 150K.
    2013XSPX likes this.
  3. Jan 14, 2025 at 8:32 PM
    Owenhall
    Owen
    Lift 33s
    I think my water pump and thermostat has been replaced buy the previous owner and I have a spare fan clutch. Might check on the hoses soon
  4. Jan 15, 2025 at 3:25 AM
    mk5
    mk5 Asshat who reads books
    SoCal
    '05 access cab 4x4
    Get on the transmission fluid if you haven't yet. Drop the pan, replace the filter, refill, then disconnect the cooler lines so you can pump fresh fluid throughout the rest of the system. There are instructions on the forum.
    Check suspension linkage for wear, and be weary of front bearings going out. Hard to detect or diagnose. Others might disagree, but personally, I'd replace the hubs at 200k if they are original.
    If you are removing the belt for any reason, pull the alternator and have it rebuilt at a shop. Starter is another candidate for replacement, esp. if you drive through water sometimes. Its failure is usually graceful, however, so you might wait for it to falter... but when it does, don't delay.
    Might be prudent to do a cooling system refresh as recommended by @Chuy. New radiator, hoses, water pump. I went with OEM hoses and Asin radiator/pump (which I think is the OEM for Toyota), and it was relatively affordable.
    Chuy likes this.
  5. Jan 15, 2025 at 5:17 AM
    Owenhall
    Owen
    Lift 33s
    What hubs do you think I should , get I already did rear wheel bearings, transmission service.
  6. Jan 15, 2025 at 5:33 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Nice. About how much did that cost you?
  7. Jan 15, 2025 at 8:56 AM
    Owenhall
    Owen
    Lift 33s
    I already have a thermostat and a fan clutch that I got for 90% off might get a radiator today and eventually change the water pump and bypass hoses. And do it all at the same time.
  8. Jan 15, 2025 at 9:09 AM
    Chuy
    Lakeside, CA
    Silver Taco
    Low 300’s, I want to say. Did it 9/22. Most parts were from Rockauto, some from Amazon. Stuck with CST, Aisin and Gates.
  9. Jan 15, 2025 at 9:25 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    If the cooling system has no leaks/weeping and keeps the truck at proper operating temp no point to replace it. Just do a proper coolant swap
    Sig45 likes this.
  10. Jan 15, 2025 at 9:31 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I'm coming up on my 200K mile service. Planning on regular 5K service in addition to a full coolant flush (did it at 100K). Other things are on the 30K interval. Those will be done at 210K miles
    My local independent Toyota Shop does a great job. If anything else needs attention, they'll let me know.
  11. Jan 15, 2025 at 9:49 AM
    nd4spdbh
    SoCal
    Id recommend coolant every 3 yrs 50k miles tbh, seems like some of the older toyotas with multi layer headgaskets are getting eaten by old acidic coolant, cheap insurance to just double the coolant change interval.
    eherlihy and Sig45[QUOTED] like this.
  12. Jan 15, 2025 at 9:58 AM
    Owenhall
    Owen
    Lift 33s
    What years had the head gasget issues.
  13. Jan 15, 2025 at 10:00 AM
    Owenhall
    Owen
    Lift 33s
    I’m going to get a radiator today on sale and will probably get a water pump in the coming months.
  14. Jan 15, 2025 at 10:15 AM
    nd4spdbh
    SoCal
    05 and early 06 had actual headgasket issues potentially. My comment was for all toyotas with multi layer headgaskets just double the frequency of the coolant change interval and you are good.
    why are you having issues with them?
  15. Jan 15, 2025 at 10:20 AM
    Chuy
    Lakeside, CA
    Silver Taco
    Preventive maintenance and sense of security if you plan on keeping the car to 300K or beyond.
  16. Jan 15, 2025 at 10:29 AM
    Chuy
    Lakeside, CA
    Silver Taco
    Here is where I may lose some, or more, of you - at first coolant service (100K), I replace the oem coolant with universal coolant - usually the StopTech brand because the label contains in writing everything Toyota/Lexus says the coolant should be composed of for their vehicles - ethylene glycol based non−silicate, non−amine, non−nitrite, and non−borate. Have always done this, going back to our 1998 Sienna which my mom still has. Coolant color matters nothing today as it is just a dye to distinguish the various manufacturers. You do want to flush out as much of the oem coolant as possible.
  17. Jan 15, 2025 at 12:18 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If it ain't broke don't try to fix it. Just continue regular service.
  18. Jan 15, 2025 at 12:32 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Yeah, but a radiator or water pump is not something you want to break on the road. At this mileage preventive maintenance on certain components is worth the cost and effort imo.
  19. Jan 15, 2025 at 1:01 PM
    cj13058
    cj13058 Well-Known Member
    Oregon
    2024 Tacoma TRD Off-Road Premium iForceMax Bronze Oxide
    2024 Tacoma TRD Off Road Premium iForceMax Bronze Oxide - AluCab Contour canopy 2005 Tacoma TRD Off Road DCSB Radiant Red - ARB 3'' lift, ARE canopy, 265/75/16 All Terrain KO2, after market stereo, ECGS differential bushing, ARB Deluxe front Bumper, Warn M8000 winch, custom winch control box install, FrontRunner Slimline canopy rack,
    I bought from here based on reviews in Tacoma/Toyota forums - https://www.ebay.com/sch/i.html?_ssn=you_only&store_name=kyotoautoparts&_oac=1.
    So far, so good. Previously bought from BamaToy, but he flaked on a lot of people, was banned and closed up shop. Both pre-assembled hubs were good quality.
  20. Jan 15, 2025 at 6:46 PM
    Owenhall
    Owen
    Lift 33s
    I changed coolant last year but the peak stuff is more red than pink so might Change it again the original wasn’t bad looking and did not have any voltage so it wasn’t acidic but who knows when it was changed.
