200K Timing Chain
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 93Wellcraft, May 26, 2022.
  1. May 26, 2022 at 4:13 PM
    93Wellcraft
    93Wellcraft [OP] Member
    2010 6ft towing
    Getting timing-chain done, which is fine, already did fuel pump, shocks & struts, front & rear differentials, transmission serviced - needs new E brake cable housings, calipers, et. Al. Am I missing anything?
    Any tips on the interior? Hope to keep for a while! I bought it at 28k, it never let me down.
    LeFro and Canadian Caber like this.
  2. May 26, 2022 at 4:19 PM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Out of curiosity, did your fuel pump quit? From what I understand, they are considered "life of vehicle" item.
    As for interior, did you mean interior of the car or engine? Seat covers if you don't already have them if you were talking interior of car.
  3. May 26, 2022 at 4:24 PM
    93Wellcraft
    2010 6ft towing
    Yes, and initially I had someone put one in, non Toyota and (turns out that pump was defective), had to do again. Sticking with Orem now
  4. May 26, 2022 at 4:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Might as well do the water pump if you are that far into it.
    Dm93 likes this.
  5. May 26, 2022 at 4:49 PM
    93Wellcraft
    2010 6ft towing
    Yes, that’s part of the plan, dropping it off this weekend.
  6. May 26, 2022 at 6:37 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Why are you replacing the chain?
    Dm93 and Rick's 2012 like this.
  7. May 26, 2022 at 7:00 PM
    93Wellcraft
    2010 6ft towing
    Getting codes, sluggish performance.
    b_r_o likes this.
  8. May 27, 2022 at 7:54 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    what codes?
  9. May 27, 2022 at 8:07 AM
    93Wellcraft
    2010 6ft towing
    P0011 & P0012, took it to toyota, they wanted $6,735 Timing chain & all attaching parts
  10. May 27, 2022 at 8:16 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Did you pay for any diag at the dealer or did they just read codes and say the chain was stretched?
  11. May 27, 2022 at 8:19 AM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    :eek:
    PhoS likes this.
  12. May 27, 2022 at 8:21 AM
    nd4spdbh
    SoCal
    OK, stop.
    Keep it simple, dont go cracking open the motor just cus the dealer told you so. There are oil filter screens (as well as accessible solenoids) that can get clogged that can be cleaned/replaced that control the vvti and can cause those codes. A full timing chain replacement is a very rare thing to need.
  13. May 27, 2022 at 8:32 AM
    Rick's 2012
    Rick
    Costa Rica
    Stock
    ^^^^^^^^^^^^^^ DITTO THIS^^^^^^^^^
  14. May 27, 2022 at 8:42 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  15. May 27, 2022 at 6:36 PM
    Bishop84
    Bishop84 Well-Known Member
    P0012 is almost always a stretched chain. Especially on a 4.0 Tacoma.
    I've seen VVTI screens cause issues once in 10 years and it was caused by a previous issue internally.
    Stuck VVTI controllers can cause the p0012, but usually there would be other codes.
    The only true way to diagnose it is with an oscilloscope and correlate the crank to cams, but honestly I'd have no fear calling a chain with limited time.
    P0012 first thing I do is check oil level, then active test the intake controllers (which eliminates the rare case of vvti filters). That's it. We have experience and know when to call them.
  16. May 28, 2022 at 4:16 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Dm93 and 93Wellcraft[OP] like this.
  17. May 28, 2022 at 5:38 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    1000% this
  18. Aug 11, 2022 at 8:28 PM
    Nickstover02
    Nickstover02 Member
    2008 Tacoma Quadcab
    Question so I have same issue p0012 and replaced vvt actuator gear and vvt selenoid on my tacoma. Still getting a P0012. When I put 12v directly to the selenoid I can hear it click but no engine noise change at all. The only thing I have not done is the timing chain but would a stretched chain cause the vvt gear not to kick in if I put 12v directly to it.
  19. Aug 11, 2022 at 8:31 PM
    Bishop84
    While running? It uses oil pressure to trigger the phaser.
    TnShooter and Dm93 like this.
  20. Aug 11, 2022 at 8:32 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What about the VVT screens, did you check/change those?
    TnShooter likes this.
