200K Timing Chain
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 93Wellcraft, May 26, 2022.
  1. Aug 11, 2022 at 8:38 PM
    Nickstover02
    Nickstover02 Member
    2008 Tacoma Quadcab
    Did the 12v test to the selenoid while running and pulled the vvt screen. Even pulls the oil drain pan. No sludge or any build up on the pickup screen either.
  2. Aug 11, 2022 at 9:03 PM
    Nickstover02
    Nickstover02 Member
    2008 Tacoma Quadcab
    If the chain was stretched would the 12v test still kick the gear in and cause engine bog.
  3. Aug 11, 2022 at 9:06 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yes the timing should still change if you activate the solenoid with the engine running, if it doesn't then it sounds like you have a plugged oil passage, bad solenoid, or bad cam phaser.
  4. Aug 11, 2022 at 9:06 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes, its pretty much the only test I really do before calling a chain.
    I command both intake vvti, watch their readings and rpm drop.
  5. Aug 11, 2022 at 9:21 PM
    Nickstover02
    Nickstover02 Member
    2008 Tacoma Quadcab
    Thanks. So I did originally go with an Aftermarket selenoid. Very possible for port line up issues on the aftermarket. I may go with an OEM selenoid and try it and see if that fixes it.
  6. Aug 16, 2022 at 8:03 AM
    Nickstover02
    Nickstover02 Member
    2008 Tacoma Quadcab
    Thanks for the help folks fixed p0012. The aftermarket vvt selenoid was causing the issue. I got a factory Toyota solenoid and no more code just waiting for Evap monitor to clear. Drove it several times yesterday and no engine light .
    4x4spiegel and Dm93 like this.
