2010 2.7 Taco with 6" lift and 35" tires
Discussion in '4 Cylinder' started by octane202, Jul 25, 2011.
  1. Jul 25, 2011 at 11:15 PM
    Manwithoutaplan
    ID
  2. Jul 25, 2011 at 11:23 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    you are right though, def a concern. but then again with lower gears youll be going slower and less likely to break something just by virtue of being able to go slow and not needing to go bashing.
    you ought to come up to big bear and do some of these trails without the snow lol
  3. Jul 26, 2011 at 10:10 AM
    octane202
    octane202 [OP] Well-Known Member
    Chandler AZ, "Desert Rat"
    2008 TRD Sport
    not yet... soon
    Thanks for the info. So with the gear swap on either the 6" lift with 35's or the 3" lift with 33's with the recommended gear change what impact will there be on high way driving.
  4. Jul 26, 2011 at 10:17 AM
    Manwithoutaplan
    ID
    your mPg's are going to go way down from stock. Your rpms with 4.56 on 33 is going to 2400 at like 65 /70. if you get 35' it might be 2100. 4.88 they are going to be a little bit higher not sure on the rough numbers.
  5. Jul 26, 2011 at 10:27 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I had 2.7 4 cyl 5 speed prerunner with 32s and it lost any kind of hwy acceleration it barely had with 31s, especially with air conditioning running. Headwinds/hills also meant downshifting. MPG took a hit. I wouldn't want to imagine the suck of running 35s much less 37s without regearing much less with more weight from 2nd differential in a 4x4. Of course this is just my opinion, go for it.............then regear.
  6. Jul 26, 2011 at 10:44 AM
    Yoytoda
    Roland
    completely stock
    the numbers you show are for a v6 am i right? since the final drive ratio of the 4cyl is already 4.10 jumping up to 4.56 with 33s is close to stock final drive.
    for a v6 you will jump from 3.73 with stock 30.5s to 4.10 with 33s to have stock final ratio. for the v6 if you jump over 4.10 to 4.56 the final drive will be low and the you will rev high at highway speed
    with a 4cyl and 33s with 4.56 you will be close to stock ratio but with all the weight and drag you will lose mpg. but not as much as running stock gears with 33s since with stock gearing you will be lugging around or need to use 4th all the time
  7. Jul 26, 2011 at 7:43 PM
    Manwithoutaplan
    ID
    Yes that is from i know with the v6. I didnt figure that their not at much change with the gearing with 4cyl. what mpgs do you get with 4.88's ?????
  8. Jul 26, 2011 at 7:53 PM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    I'm with this guy. I wouldn't do 33's on a 4-popper, let alone 35's. That's nuts.
    With: 32" all-terrains, no regear, no supercharger it was tolerable albeit downshifting uphill on the highway.
    With: same + supercharger, it's great.
    I'd do 32's, 32's with blower, or 33s + regear if anything. But 35's w/o regear is going to be awful, awful, awful.
  9. Jul 26, 2011 at 8:06 PM
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    Dude, the only thing id own with a 4 is, 1889 CRX Si, 1993 Civic EX, A 2001 fat boy & 2003 v-rod combo, Oh ya I had a 1980 toyota wag. Lots of bugs, still have 1979 drop top VW Bug Kar. 6200 miles. Also i had a Manx Buggy and 2-3 other VW back in the day. 4's have lots more power than back in the day. I would rather have a stock 6 or 8 than a built 4. Just cus. when your building power will b in ? at some time.
  10. Jul 26, 2011 at 8:08 PM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    What on earth? You're aware people are going to try to read this crap, right?
  11. Jul 26, 2011 at 8:46 PM
    Manwithoutaplan
    ID
  12. Jul 26, 2011 at 9:34 PM
    Yoytoda
    Roland
    completely stock
    this made my night. F'n hilarious.
  13. Jul 26, 2011 at 9:35 PM
    Manwithoutaplan
    ID
    pretty good stuff.
  14. Jul 26, 2011 at 9:39 PM
    Yoytoda
    Roland
    completely stock
    oh and i dont have 4.88s YET not till my tires are ready to be replaced but with 32s and stock gearing i get 21mpgs. i have k&n filter, secondary filter delete, synthetic oil in engine, tranny, f/r diffs. all got me from 18 to 21.
  15. Jul 26, 2011 at 9:43 PM
    #35
    Manwithoutaplan
    ID
    Ohh ok i am sorry. what do you get normally in the winter???
  16. Jul 26, 2011 at 9:54 PM
    #36
    Yoytoda
    Roland
    completely stock
    20-21 unless the roads are really sloppy up here then i get 15
  17. Jul 26, 2011 at 9:55 PM
    #37
    Manwithoutaplan
    ID
    ahhh. well next winter when you do any snow runs let me know i am done for that stuff.
  18. Jul 26, 2011 at 9:56 PM
    #38
    Yoytoda
    Roland
    completely stock
    you ought to come check it out in the summer. put some scratches on those sliders :p
  19. Jul 26, 2011 at 9:58 PM
    #39
    Manwithoutaplan
    ID
    i was up their two weekends ago. but all they wanted to do is do prerunning stuff. i wanted to do some more diffcult trails.
  20. Jul 26, 2011 at 9:59 PM
    #40
    Yoytoda
    Roland
    completely stock
    let me know, ill take you. i know where all the good trails are.
