2010 2.7L Oil Pressure "sender" switch replacement info or how to?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TreeFortRichard, Apr 25, 2021.
  1. Apr 25, 2021 at 5:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    https://uk.rs-online.com/web/generalDisplay.html?id=ideas-and-advice/ptfe-tapes-guide
    Can Teflon tape be used on oil fittings?
    Due to its chemical inertness, PTFE tape is resistant to both petrol and oil. Therefore, it is often used in automotive applications to seal and lubricate fuel line joints. ... This means that it is broadly suitable for use in environments where it may encounter oil, petrol, diesel and other fuels.
    6 gearT444E and TnShooter like this.
  2. Apr 25, 2021 at 6:36 PM
    TreeFortRichard
    TreeFortRichard [OP] Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    I think the concern here is that a piece might tear off and get into the system?
  3. Apr 25, 2021 at 6:45 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well that isn't what you asked in this quoted post below.
    All Teflon Tape is safe for oil and gasoline.
    There is very little danger of a piece coming off and getting stuck somewhere it shouldn't be if done correctly.
    6 gearT444E likes this.
  4. Apr 25, 2021 at 7:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Thats why the goop is good. You just paint a little dab on the threads instead of futzing around with pieces of actual tape
    TreeFortRichard[OP] likes this.
  5. Apr 30, 2021 at 1:28 PM
    TreeFortRichard
    Brian
    Crazy stuff here...so the old one comes out with a 24mm and the new one goes in with a 22mm...
    Thanks toyota!
    TnShooter and 6 gearT444E like this.
  6. Apr 30, 2021 at 6:43 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Maybe they improved on the design?
  7. Apr 30, 2021 at 7:00 PM
    TreeFortRichard
    Brian
  8. Apr 30, 2021 at 7:35 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    So you blame Toyota that the aftermarket part you bought that is made by another company is a different size hex than the OEM Toyota Part.
    o_O
    I am confused.
  9. Apr 30, 2021 at 7:52 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    At least you did have to buy the special socket for the OPS.
    I guess we can Thank Toyota for that at least?
  10. Apr 30, 2021 at 7:56 PM
    TreeFortRichard
    Brian
    No...I was just confused as to why they would use different sockets...I bought the 24mm to take it off...and the new one needs a 22mm...
    I guess it's more of a thanks carquest...I bet it's obviously cheaper to make the nut head size smaller..
    Jimmyh[QUOTED] likes this.
  11. Apr 30, 2021 at 7:57 PM
    TnShooter
    Deogee
    STOCK
    Likely because the new one isn’t OEM.
  12. Apr 30, 2021 at 7:59 PM
    TreeFortRichard
    Brian
    OEM was like $59...Knock off...$14
  13. Apr 30, 2021 at 8:32 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    electrical tape over the instrument cluster light....priceless
  14. May 1, 2021 at 3:56 PM
    TreeFortRichard
    Brian
    alright...swap done...It was a contortionists effort in the driveway with jack stands...and my arms are covered in scratches...
    Old vs New...See if you can figure out which is which
    Install location for future reference readers...Basically straight in from the top of the right front tire in front of the oil filter.
    I was confused at first because I didn't realize..
    1. It threads straight into a hole, no other guiding "parts"
    2. It threads in at like a downward angle...It took a while to get the threads to catch when hand tightening VERY carefully to start...I used 2 drops of blue loctite
    3. Letting it sit/cure for probably overnight. I packed an absorbent drop pad up under there to check after I start it up...
    4. Disconnecting it was odd to figure out until I hit it with some brake cleaner spray. That got the grit out of the push tab and then it came right off..
    5. Almost zero oil leakage...when I removed the old one...Yes my dipstick is in the good range
    Check out that New England rust...
  15. Jul 7, 2023 at 6:48 PM
    #35
    papergirl
    papergirl Member
    Patti
    2006 Tacoma 2.7
    Thanks for taking the time to write out step by step instructions, helped me do this job in ten minutes flat :)
    Much easier to access if you turn the steering wheel all the way to the right, squeeze yourself right into the wheel well.
  16. Jul 9, 2023 at 7:07 AM
    #36
    TreeFortRichard
    Brian
    Replacement switch still holding...after 2+ years.
