2010 4 cyl 4x4 AC taco, 16mpg and sluggish uphill. whats wrong?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mattjaro, Jan 7, 2014.
  1. Jan 8, 2014 at 3:22 PM
    #41
    Robode
    Robode Member
    I have a 2014 Tacoma, Access Cab, 4X4, 4cyl, 5 speed manual, with 1200 miles on it. I added a topper and I got rid of the crappy Dunlop tires, for Michelin; 265X70X16. Initially, and before the changes, I was getting between 19-21 MPG. Now, it is absolutely ridiculous; between 13-16. Granted, it is a very, very cold winter in MN, and I warm up my truck every morning for about 10 minutes, and all my driving so far is city driving. But still, if I had known it would be this bad, I would have gotten a bigger/more powerful engine. Not too happy with this. Love the truck otherwise though.
  2. Jan 8, 2014 at 3:43 PM
    #42
    Eternal24k
    Eternal24k Well-Known Member
    Vermont
    2009 SR5 V6 4x4
    i get better MPGs with my V6 than i did the 4 banger, with all the hills around here i think it was just working harder all the time, i hated it, sluggish as hell
  3. Jan 8, 2014 at 4:14 PM
    #43
    RogerRZ
    RogerRZ Well-Known Member
    New Brunswick, Canada
    White '14 DCLB TRD Sport
    The bigger more powerful engine would burn more fuel, if used the same way.
    Last couple of weeks, when there was either six inches of snow on the roads or temps went to zero, I was getting 16s and 17s.
    Last tankful, temps were in the low teens snowless glare ice roads (smooth rolling), I almost got 21. I have a good bit of data to be found in my fuelly sig. The really low summer dips are when I tow my 5-ish thousand pound trailer.
    Also, unless I'm sitting in the truck doing paperwork, I never idle. When you idle, you're getting 0mpg...
  4. Jan 8, 2014 at 5:55 PM
    #44
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    My '09 4wd, 4 banger access cab with 5-spd, camper shell, and a couple hundred pounds of extra crap gets a consistent 25+ mpg in the Arizona mountains at the altitudes you mention. The tires are 245, load range E, at about 35# pressure. It slows down on the steep hills, too. My guess is that a lot of the difference between your truck and mine is the tire sizes and driving habits. No offense intended. I had a lead foot when I was younger and my gas mileage showed it. :) Afterthought: My gas mileage with this truck improved after the first 2 or 3 months I owned it. I bought it used with about 28k miles. Yours might improve with time, too.
  5. Jan 8, 2014 at 5:58 PM
    #45
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Good proof that it can easily be done. It's amazing also how good mpg you have when you pair the right gears with the right size tire. Stock 245s with stock 4.10s I was getting 22-24. Went up to 285s with 4.10s and got 20-21. Put a lot of armor on, went up to 315s with 4.88s (the right "stock" gear ratio) and I get 19 now. I averaged 17 on my last offroad adventure. I drove 400 miles to a park, spent 3 days offroad mostly in 4hi and 4lo, then drove 400 miles back home. Ultragauge said 17 somethin.
    It also really helps to calibrate your speedo when you change tire size. Your mileage will always be off it you don't. So if you are running 285s instead of 245s with stock 4.10s then your speedo will read less miles then you have actually traveled and will consequently make your mpg calculations off
    Taco Wedo likes this.
  6. Jan 8, 2014 at 6:04 PM
    #46
    Xaks
    Xaks Cranky & often armed sysadmin
    Xaks
    Oklahoma City area
    work beast '06 reg cab 4 cyl 5 spd
    D'oh!
    Summabish, I completely overlooked this!
    *nuclear powered, weapons-grade facepalm
  7. Jan 8, 2014 at 6:15 PM
    #47
    Robode
    Robode Member
    Thanks for the feedback regarding resetting the speedo, and running 265's with factory 4:10's. That is probably the biggest factor. Believe me, I run the gears right all the time; around 2300 rpm, and I don't drive crazy (I am not a youngster, I am an old fart). Will just have to see what happens when weather warms up. Appreciate all the feedback.
  8. Jan 8, 2014 at 6:34 PM
    #48
    Taco'09
    Taco'09 Well-Known Member
    What the..... I must have a rogue ghost truck or something. I got the 4 banger 5 speed in an '09 regular cab and it is one peppy truck. Granted it is lighter than the AC but it lives between 7,000 and 9,000 ft. And, the best part is I always get between 23 and 25 mpg. I don't get why some Tacos seem to get horrible mileage and others sip fuel. That barometric sensor on the intake has had me wondering for a while whether it could substantially affect mileage on different but similar trucks.
  9. Jan 8, 2014 at 6:38 PM
    #49
    Xaks
    Xaks
    Oklahoma City area
    Mines an 08 reg cab L4 5 speed and I'm in the same boat. I can't believe some times that there are Tacos with this engine and transmission that AREN'T peppy.
    I don't confuse it with a 400-horse V8 like I used to race. But for what it is, and the mileage I get, I've never one time thought to myself "Gosh, I wish I had some more power"
    Hell, I've wished for more cab noise reduction in Florida rainstorms a lot more than I've wished for anything else. Put a gun to my head and I'd say better brakes under load and maybe stock 16 tires would be complaints 2 and 3. But I bought it *because* it's a fleet work truck with no frills and no power windows, so I knew what I wanted going in.
  10. Jan 9, 2014 at 2:04 AM
    #50
    RogerRZ
    I did't calibrate my speedo when I went to 235/85, but I check the odo from time to time against the Garmin on the dash on a 100km trip. I add the 3.9% when I do my Fuelly entry (my fuelly sig shows more mileage than my odometer.)
  11. Jan 9, 2014 at 8:13 AM
    #51
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yeah the calibration is def a big deal. Unlike the v6 model, our speed sensors are located at the wheels so the sensor is reading tire revolutions. Obviously a bigger tire takes a greater distance to rotote 360 degrees meaning that your distance traveled will be greater then a smaller tire. Your speed sensor knows no difference other then point A to point B equals one revolution.
    As said a few times also that driving habbits are key for mpg. For me, it's cool having a ultragauge because it reads real time and average mpgs. I find myself watching them all the time and almost challenging myself to keep the average up high. It's surprising sometimes to see how doin certain things gets my better mpgs then others. For instance, I notice that shifting under 2k gets worse mpg because the motor has to work harder to speed up. Seems like there's a lot more torque in the 2.5k area and keeping the rpms in that range makes it effortless to hold a speed and makes my foot very light on the pedal. Goin down a straight road at 40mph I watch the instant mpg gauge sit between 35-40. I never floor my truck, hardly ever idle it and drive according to how that gauge reads giving me the best mpg. And yes, if I floor it at even 1500 rpms in 5th gear that gauge instantly goes down to 10 mpg. It's not hard to get really bad gas mileage but it's also easy to get really good gas mileage.
  12. Jan 9, 2014 at 12:44 PM
    #52
    Mattjaro
    Mattjaro [OP] Active Member
    Jaro
    Mammoth Lakes, CA
    2014 Tacoma Access Cab V6 M/T 4x4
    plasti-dip rims, storage/sleeping platform in bed, drivers seat flashlight attachment.
    Duh, idk how i over looked this. thanks for helping with that now i need to find how to re-calibrate to the bigger tire size.
    thanks
  13. Jan 9, 2014 at 3:05 PM
    #53
    Robode
    Robode Member
    I don't have to recalibrate my speedo, from going from 245X75X16 tires to 265X75X16 tires, since that is only a change in the width, not diameter.
  14. Jan 9, 2014 at 3:43 PM
    #54
    Mattjaro
    Jaro
    Mammoth Lakes, CA
    your diameter should change as well.
    245 x .75 = 183.75mm
    265 x .75 = 198.75mm
    so the diameter of your wheele would have changed by 15mm x 2 = 30mm = 3cm
    thats over an inch in diameter change.
  15. Jan 9, 2014 at 4:03 PM
    #55
    spencer44306
    spencer44306 Well-Known Member
    Spencer
    Upstate Ny
    13 TRD Sport 4x4
    Ive found the problem?
    :anonymous:
  16. Jan 9, 2014 at 4:20 PM
    #56
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yeah tires are really strange. They never match when it comes to width and height changes. Ive always been confused by that. Haha
  17. Jan 9, 2014 at 4:35 PM
    #57
    TRD Toy85
    TRD Toy85 Well-Known Member
    CT
    loaded 2013 TRD sport
    LMAO , this should be the reply to the 20 threads per day we see on this topic
