2010 4 cyl. reg cab 4x4 ...what gear around town.
Discussion in '4 Cylinder' started by OldDog, Aug 18, 2010.
  1. Aug 18, 2010 at 1:14 PM
    OldDog
    OldDog [OP] Well-Known Member
    w.mass
    2010 reg cab 4X4
    Just want to know what speed should I use 5th gear around town. 40,45,50 !?! most of the time I'm in 4th between 40,45 around 2000 rpm's
    Thanks for looking
  2. Aug 18, 2010 at 1:19 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    In my 2000 I would get in 5th above 35 when just cruzin around town. Pretty much the highest gear I could get into without stalling, got really good mileage too.
  3. Aug 18, 2010 at 1:38 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    I only use 5th for long straight aways without hills, stop lights, etc. If you aren't going ~50 mph, 5th won't provide much benefit. Engine lugging isn't terribly good for it either (when the gear is too high for the speed and the engine & drivetrain strain to keep the truck moving...sounds like a deep growl and the truck hardly accelerates). Furthermore, it doesn't do any good to use 5th if you plan to be shifting soon...the more you needlessly use the clutch, the faster you'll wear out the discs and throw out bearing.
    Note: your owner's manual provides some insight as well...they provide recommended shift speeds for best fuel economy
  4. Aug 18, 2010 at 1:46 PM
    Switchback
    Switchback Well-Known Member
    Seymour, TN
    09 Reg Cab 4x4
    ARE MX Series Cap, Toyota Bed Mat, Weathertech Floor Liners, Front Flaps Removed
    i have the same setup in an '09, and my avg speeds for shifting are around:
    15 mph - 30 mph -2nd
    30 mph - 40 mph - 3rd
    40 mph - 60 mph - 4th
    > 60 mph - 5th
    obviously some variations based on the situation, but my truck seems to hum along just great using those speeds...
  5. Aug 18, 2010 at 2:14 PM
    OldDog
    w.mass
    2010 reg cab 4X4
    Thanks guys
  6. Aug 18, 2010 at 4:10 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    10 PreRunner AC Sport Rally 5 Spd
    Tail gate hose clamp, Front Windows 50% tint, fog lights, 894 backup light mod, LED license & interior.
    If cruising (not accelerating) I am in this gear at this speed:
    1: Rush hour, not happy
    2: 10-25 (still rush hour, still not happy)
    3: 25-35
    4: 35-45
    5: 45-
  7. Aug 19, 2010 at 7:53 AM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    The gearing on these trucks are too tall. 5th is almost worthless where I live. I can’t remember the last time I used it.
  8. Aug 19, 2010 at 11:32 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I use 5th all the time. I just wish there was a 6th gear for the 4 banger that would let me run at less than 2k RPM's at 70-75 MPH.
  9. Aug 19, 2010 at 8:54 PM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    i only use 5th gear on the freeway at 60mph+ but i also have a 5 lugger so my gears are much different
  10. Aug 19, 2010 at 8:55 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    X2! I've always thought 5th was basically just like 4th in mine. The drop in RPMs isn't quite drastic enough for me.
  11. Sep 8, 2010 at 9:25 PM
    Greenthumb
    Greenthumb Active Member
    Healdsburg
    2010 Tacoma SR5
    Painted wheels, grille and badges
    If you live in Kansas run in fourth and fifth gears at 2000 rpm all day... If you don't save your clutch and your gear box and run between 2500 rpm and 3000 rpm
  12. Sep 9, 2010 at 6:00 PM
    davidsdad
    davidsdad Well-Known Member
    Dave
    Grove City, Ohio
    Reg. Cab 4X4
    "Under Cover" Bed cover, 3" Suspension Lift, Sony stereo, 600w amp, Rockford Fosgate 12" sub, wheels, tires, (window tint coming soon).
    This is the exact way I seem to run as well!
  13. Sep 10, 2010 at 11:34 PM
    MowTaco
    Kansas
    I've been watching my "scanguage" (Torque app on Droid) and my mileage goes up dramatically whenever I get into 5th. So anything now above about 35 I put er in 5th unless it starts lugging.
