2010 4 vs 6 cylinder access cab 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NMTrailRider, Sep 28, 2009.
  1. Sep 28, 2009 at 5:45 PM
    NMTrailRider
    NMTrailRider [OP] Well-Known Member
    New Mexico
    hey, all... i'm new to the forum and need some fast advice! thanks in advance. i've been driving a 1998 reg cab 4wd with the 2.7 4 cylinder for 9 years- LOVE IT. but it's time to upgrade and i must do it soon. i've lost much power in the last few months. took it to a toyo dealer and they did a compression test. one of the cylinders is only working at 50%. i don't want to put any more money into it, as i just dropped $2500 into it 3 months ago. 170,ooo miles, so time to upgrade.
    i put in an order for a 2010 access cab 4WD with the 4 cylinder engine... it'll be here in a month. but now i'm having doubts! i'm thinking i should have gone with the 6 cylinder! i do most of my driving on the interstate at 75-80mph (10,000 miles a year). and i'm wondering if i'm really going to be underpowered driving against the wind and up hills with the 4 cylinder at highway speeds. i feel like my little '98 4 cylinder reg cab is underpowered against the wind at hiway speed and the 2010 is a considerably larger truck. am i going to be disappointed with the 4 cylinder? i rarely tow, so that isn't much of a consideration. have there been major changes in the 4 banger in the last 10 years so that they can accommodate the change in size? the new ones seem HUGE compared to my 98. i would REALLY appreciate your advice! i can probably still call and change my order!
  2. Sep 28, 2009 at 5:53 PM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    I would go with the sixxer. Just my opinion. I think you will be happier in the long run.
  3. Sep 28, 2009 at 5:56 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    i love my 4cyl but the 4.10 rearend will be killing your gas mileage at 80mph.
  4. Sep 28, 2009 at 5:57 PM
    IndigoTaco
    IndigoTaco Well-Known Member
    07 Access Cab Sport 4x4
    Go w/ the Six. Gas mileage is actually closer than you think ( most guys w/ auto report 22+ highway). IMO, the difference in power and options is well worth the gas milage difference.
  5. Sep 28, 2009 at 5:58 PM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    I have no problems with my 4 banger. Just have to get the RPMs up.. Test drive both, And then decide for yourself power VS. Price. Do what YOU like.
  6. Sep 28, 2009 at 5:59 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    my reg cab 2.7 does fine at 65,gets more power at 75 though, for hills. But add 200? pounds more, and goin 80 a lot, the v-6 might better suit you. B.T.W. I went 65 into a 20-25 mph head wind the other day, cruise control never waivered, mpg sucked though as u would expect.
    reg cab 04 to the 05 model weighs 200 lb more , not a lot considering the size.
  7. Sep 28, 2009 at 6:02 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Go with the 6 cylinder or you'll regret it. The fuel mileage isn't that much worse.
    I had the same issue with my '08 Accord. I bought it with the 190hp inline 4 but the engine had to work pretty hard to move the car-at least to my liking. The fuel mileage of the I4 was only slightly better than that of the 271hp V6.
    I might still have that car if I got it with the V6.
  8. Sep 28, 2009 at 6:04 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    I've got the six in an acess cab and it feels just right to me. I drove a regular cab with the four and a 5 speed manual, seemed just a little underpowered. I get between 21 and 23 mpg with the auto trans. If you can live with that mileage, I'd go with the six and the auto. To me, it's better to have the extra power there when you need it. Really, you can't go wrong either way, but it would be a shame to be making payments on a truck you have second thoughts about.
  9. Sep 28, 2009 at 6:04 PM
    NAAC3TACO
    NAAC3TACO Well-Known Member
    Sparks, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Toyo A30 tires, Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts.
    If you can afford it, get the 6, but the 2.7 is a great engine too. As long as you get a Tacoma, you'll be happy. JMO
  10. Sep 28, 2009 at 6:07 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Go with the 4 banger. Like everyone else here who drives a 6 and is recomending the vehicle they drive, I am going to do the same. I go to college up in the mountains and spend 4 hours on a hilly interstate to get there and back. I used to have to downshift a good bit, but then I started using premium and now I can hold many hills in fifth that I couldn't before.
  11. Sep 28, 2009 at 6:13 PM
    NMTrailRider
    New Mexico
    great feed back- thanks. wish i would have found this forum a week ago. another question... if i'm on the interstate at 80mph with a 4cyl 2010 and come to a big hill, is it OK to dowshift to 4th at that speed? i do it all the time in my '98, but it really cranks the rpm's- i'm a little more relaxed with how i treat the old truck.
  12. Sep 28, 2009 at 6:20 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    If your are running 80 you prolly won't need to downshift, you'll already be tach'ing over 3k...it should pull just fine unless your facing some serious wind.
  13. Sep 28, 2009 at 6:21 PM
    Tacoyota
    08 4wd
    on the 5 spd manual , yes. The max speed in 4th is 100 or so, i'll never see that, but it does fine at 70 mph (highest speed i had to downshift at )
  14. Sep 28, 2009 at 7:09 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    Test drive both.....get 'em out on the freeway where there are some grades to pull.
    I am amazed at how my 2.7 will hold 5th gear on grades.
    I looked at the V6 but didn't like the fuel mileage......IMO, that's V8 fuel mileage that is being reported.
    When Toyota gets the V6 easily into the 20's without lightfooting, I'll prolly buy one.
    So far no regrets with the 2.7
    My 2¢
  15. Sep 28, 2009 at 7:19 PM
    Tacoyota
    08 4wd
    All said, only you know, Harpo, if you wnat/need the v-6. Dont think you'll regret it if you do.
    The 4 cyliner is still about low maintainance, and "enough" power, the 6 is sporty n strong, with a bit more maintainance.
    Only thing i say that you must do, is to make sure its Barcelony Red!:D
  16. Sep 28, 2009 at 7:39 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    10 PreRunner AC Sport Rally 5 Spd
    Tail gate hose clamp, Front Windows 50% tint, fog lights, 894 backup light mod, LED license & interior.
    Agreed :)
  17. Sep 28, 2009 at 9:18 PM
    NMTrailRider
    New Mexico
    TACOYOTA- the 4cyl 1998 i have now, i haven't done a thing to it in 9 years. it's been great. but i think i'm going to want the more power in the 6cyl. when you talk about the 6 being a bit more maintenance, what do you mean exactly? do you mean there is there a list of routine maintenance that must be done at particular milages (like plugs, belts, etc), or do you mean there may be trips to the shop for fixes? do the 6cyls break down more? i really appreciate the comments from all you guys!
  18. Sep 28, 2009 at 9:27 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
  19. Sep 28, 2009 at 9:46 PM
    akwagon
    akwagon Alaska Dude
    chris
    alaska
    08 Access 5spd 4x4
    5100, kazktin leather, truxedo
    Auto trans v6 comparable to manual 4.
    V6 6spd not so much.
  20. Sep 28, 2009 at 9:54 PM
    uood8
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    not quite
    the v6 isn't comparable in any way, its a totally different beast.
    my i4 keeps me out of trouble with plenty of pep around town, with good city mileage.
