2010 4Runner Mirrors Worked!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blacked Out TRD, May 12, 2010.
  1. May 20, 2019 at 9:35 AM
    #561
    Lowroach
    Lowroach Member
    Phil
    Las Vegas
    TBD
    The door side mount/arm looks different on the highlander mirror and would have to be swapped, but otherwise it looks identical.
    Also the wiring in the picture looks different, the Tacoma has a 5 round connector for the mirror and light.
  2. May 20, 2019 at 6:02 PM
    #562
    tomjo1
    tomjo1 Well-Known Member
    Tomjo
    Taiwan
    2007 Black Tacoma Sport
    2.5inch high life kit
    Yes , it's should be swap arm like 2010 4runner.
    I don't worry about the wiring , caused I think it's can be fixed on our car.
    Just want to sure if I can using Highlander's mirror instead 4runner.
    Any other suggestion ?
    tks.
  3. Oct 29, 2019 at 10:26 PM
    #563
    CatfishCalhoun
    CatfishCalhoun Member
    Rocky View County Alberta Canada
    2008 Tacoma TRD
    Could you send me the specs you mentioned here. I just ordered the Wolsten modules. Thanks. -john
  4. Jan 5, 2020 at 1:42 PM
    #564
    RUSSELLTACO
    RUSSELLTACO Well-Known Member
    Blacksburg Va
    silver shitbox
    bolt ons and autozone decals
  5. Jan 5, 2020 at 1:47 PM
    #565
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Interesting. (PS the name is not me)
  6. Jan 5, 2020 at 1:48 PM
    #566
    RUSSELLTACO
    Blacksburg Va
    silver shitbox
    oops, lol sorry @Great White Taco disregard
    fatfurious2[QUOTED] likes this.
  7. Mar 12, 2023 at 7:26 PM
    #567
    caribe makaira
    Caribbean, Puerto Rico
    GoldTaco07[QUOTED] likes this.
  8. Mar 12, 2023 at 8:55 PM
    #568
    GoldTaco07
    GoldTaco07 Member
    You’re the man! Finally figured out the diagram as well of where to tap in and it’s simple the only thing that I wonder is what AWG size should I use to extend the connector wires? Not sure what gauge are the connector wires I’m thinking on using 18AWG to extend the wires…
  9. Mar 12, 2023 at 8:59 PM
    #569
    caribe makaira
    18 awg is fine, no larger.
  10. Mar 12, 2023 at 9:12 PM
    #570
    caribe makaira
    :hattip:
    Wires are 20 awg.
  11. Mar 12, 2023 at 9:44 PM
    #571
    caribe makaira
    A few options, get mating connector to mirror and the mating to door connector, terminals (pins) are different sizes.
    Or snip the door connector and crimp correct terminals to mating connector to door mirror.
  12. Mar 12, 2023 at 10:02 PM
    #572
    caribe makaira
    Found this, which has a bit of confusion;
    Similar connectors (from mirror assembly) different size terminals. No matching female side for -12610. Would need to confirm mirror connector part number.
  13. Mar 12, 2023 at 10:04 PM
    #573
    caribe makaira
    Also, the foot well lights sold for the 2nd Gen has a mating connector that taps into the cab illumination circuit (fused power and dimming) where you could add a Y harness to use for the mirror puddles.
    Or get parts and assembled it.
    @GoldTaco07
  14. Apr 1, 2023 at 1:11 PM
    #574
    caribe makaira
    Signal wires require their own ground, not shared with puddle ground. Did you add the missing terminals on the connector behind the fuse box? Did you substitute the jumper (no-DRL) for the connector with jumper pins like the drawing...:playball:
  15. Apr 1, 2023 at 1:44 PM
    #575
    caribe makaira
    When you removed the bolt on the tweeter brace, did you notice it screws into a plastic base? Do you have a DMM to verify it's actually a good ground? You can also use a DMM to verify the turn signal tap you are now connected to.
  16. Apr 1, 2023 at 1:58 PM
    #576
    caribe makaira
    Don't touch that nut, it's holding the window motor alignment.
  17. Apr 1, 2023 at 2:08 PM
    #577
    caribe makaira
    Have you verified that you are getting power from the signal tap? Also, the turn is an LED which requires correct flow. Are the wires from the LED color coded?
  18. Apr 1, 2023 at 2:19 PM
    #578
    caribe makaira
    With a longer length of cable wrap it to the eye terminal you have and find a bare metal area on the door. Then check the LED indeed works.
  19. Apr 1, 2023 at 2:28 PM
    #579
    caribe makaira
    You haven't verified that the Turn LED tap (+) is a good one. Or even if the LED is DOA...
  20. Apr 1, 2023 at 3:30 PM
    #580
    caribe makaira
    Only if both wires were getting proper contact. Positive & Negative.
