2010 4x4 DC V6 suspension question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thegrandpoohbah, Jan 9, 2010.
  1. Jan 9, 2010 at 11:50 PM
    thegrandpoohbah
    thegrandpoohbah [OP] Well-Known Member
    Fort Nelson, BC, Canada
    2013 4x4 Double Cab V6 TRD Sport
    I keep reading on here that Bilstein 5100s are a good way to go for a basic suspension upgrade. Assuming I get the TSB done and have the 4th leaf spring installed by the dealer, how much would I need to lift the front in order to level out the truck? I've read 1.75" but I'm not sure if that was with or wothout the extra leaf. Would an alignment be required for such a small amount of lift? Thanks for helping a noob out.
  2. Jan 10, 2010 at 12:01 AM
    stenyeart
    stenyeart Well-Known Member
    Sean
    Lewiston, Idaho
    06 DC TRD OR SWB
    3" Toytec Lift w/ AAL, TRD CAI, Leer 700 Series, Hypertech Speedo Calibrator, Locker Anytime Mod, LR UCA's, OEM Roof Rack, Satoshi grill with Devil Horns Emblem, USA Spec PA-15 Toy Ipod Integration, Redline Tuning Hood Struts and EZ Down Tailgate.
    5100's are adjustable, so you can set them from stock height to 2.5" of lift. This means you would be able to level it out. Also, anytime you replace suspension components in the front, you need an alignment. There are many posts on this type of issue, try the search button.
  3. Jan 10, 2010 at 9:20 AM
    thegrandpoohbah
    I should have clarified: I am aware that the front 5100s are adjustable. Just wondering what I would need to adjust them to in order to level the truck assuming I have the dealer do the leaf spring TSB.
  4. Jan 10, 2010 at 10:35 AM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    us canadians dont need the tsb done
  5. Jan 10, 2010 at 10:55 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    The 2010 Tacoma (mine anyway) is fine... it is the older ones with too soft rear springs. I never got or heard of the TSB and paid $800 to have airbags and 5100s added to the rear of my '05... to stop the bottoming out with a load.
  6. Jan 10, 2010 at 11:20 AM
    NorthernTacoma
    NorthernTacoma Well-Known Member
    Brandon
    Scottsdale, AZ
    10 DC TRD Off-Road 6 speed manual TRD exhaust
    TRD Exhaust, Rear leaf TSB, TRD CAI, Biceman 4x4 Illuminated switch mod
    I gained about an inch in the rear with rear leaf TSB, but I've heard it will settle and you can expect about 3/8 inch raise when all is said and done.
