2010 4x4, LSD or Auto LSD as standard option???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by huff.jeremy, Feb 7, 2010.
  1. Feb 7, 2010 at 9:36 AM
    huff.jeremy
    huff.jeremy [OP] Well-Known Member
    Illinois
    2010 MagGray SR5 Access Cab, 4x4, 2.7L, 5spd
    OME 884's, OME shocks, Wheelers 1.5" AAL, Light Racing UCA, Jason Fiberglass top, URD Short Shifter, Fog Lights
    :mad:
    So when purchasing my 2010 4x4, I was assured that every tacoma came standard with LSD. I asked because I was willing to have an LSD diff installed. Now I have been reading my manual and all I see is this "Auto LSD" crap. That is not what I wanted. I know, it may be my fault for not researching... but dang it, I am pissed.
    So a 2010 4x4 tacoma has ONLY auto LSD? Or did I miss something in the manual?
  2. Feb 7, 2010 at 9:37 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Correct, it's an Auto LSD.
  3. Feb 7, 2010 at 9:39 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    It has only electronic LSD, nothing mechanical. Maybe some of the guys with the Auto LSD will give you their opinions. The auto LSD uses the brakes to mimic the actions of a mechanical LSD.
  4. Feb 7, 2010 at 9:46 AM
    huff.jeremy
    Illinois
    Crud. I Appreciate the responses even though they are not what I wanted to hear. I understand how the Auto LSD works, and I would much prefer having a mechanical diff. Especially since there is a pretty noticeable loss of power when the Auto LSD kicks in (even my headlights dim for a second...).
  5. Feb 7, 2010 at 10:01 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Not all is lost if you install Truetrac you will be better off then with mechanical lsd.
  6. Feb 7, 2010 at 10:14 AM
    huff.jeremy
    Illinois
    That is VERY interesting, and affordable. I gather that this thing won't work in "no traction" situations, which the Auto LSD should handle well. I may just have to buy a couple of these. :)
