2010 Access Cab Manual
Discussion in '4 Cylinder' started by mallard75, Feb 3, 2013.
  1. Feb 9, 2013 at 7:03 AM
    rodney
    rodney Well-Known Member
    Toyota Sienna Mommyvan & Ford 2fitty
    if you are finding it tough to select gears, your clutch may be going. i had the same issue when i got my truck, and when the clutch gave up at 12k, i had the tsb clutch installed. since then it has been perfect. just an fyi.
    http://www.tacomaworld.com/forum/4-cylinder/176556-clunky-transmission.html
  2. Feb 9, 2013 at 3:44 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    I have had a tough 1-2 shift since new. I had the tab clutch done and got rear ended with a rebuilt transmission and the shift in 1-2 remains difficult under 2500rpm. I use 3k shift for that gear and its smoother.
  3. Feb 9, 2013 at 8:42 PM
    Timberland Taco
    Timberland Taco Well-Known Member
    Berlin, NJ
    2013 V6 6-speed 4x4
    Bilstein 5100's set at .85, OME 885x coils w/ 1/2" top plate spacers, Total Chaos UCA's, Wheelers 1.5" HD 3 leaf progressive AAL w/ factory overload leaf, DT Pipe Bomb Ypipe, Vibrant resonator, Magnaflow pro series catback system, URD Short Throw Shift Kit, Debadged, BHLM, BTLM, 6000K BiXenon Headlights & Fogs.
    just picked up a '10 access cab 2.7 5speed 4x4 last Saturday with 23,xxx. absolutely love the truck but after three days the %^&%*^$^%$^%^&%*$^&(%&^$*^%&^ clutch started slipping!!! going round and round with Toyota now on getting it fixed under the TSB. Good luck with ur new rig
  4. Feb 12, 2013 at 9:06 AM
    jassco
    NH
    2023 TRD Offroad
    Stick with it. The upgraded clutch is good. It's from the previous gen v6.
  5. Feb 12, 2013 at 11:20 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    ^Link me to the TSB please. This is by far my largest gripe with the truck, would love a fix.
  6. Feb 12, 2013 at 1:17 PM
    jassco
    NH
    2023 TRD Offroad
    Sorry don't have the pdf, but info on it is here.
    http://www.tacomahq.com/758/tacoma-tsb-5-speed-manual-clutch-disk-defect/
    If your Tacoma is out of the 3 year, 36 mile warranty, you will not receive warranty coverage for this repair even though it appears to be a manufacturing/design/quality related issue. The best you can hope for outside of warranty is manufacturer or dealer assistance (free labor, discounted labor, free parts, etc.)
  7. Feb 14, 2013 at 11:56 AM
    Timberland Taco
    Berlin, NJ
    2013 V6 6-speed 4x4
    good to know, its anooying because its not slipping enough for them to tell. its really sporadic. seems to do it more in the cold. Well see what happens
  8. Feb 14, 2013 at 12:02 PM
    jassco
    NH
    2023 TRD Offroad
    You have to get them to replace it on a good will. I complained to my purchasing dealer and they agreed to make me happy. They noticed the difference after replacing it, but before they couldn't tell something was wrong. They typically have to drive another similar model on the lot and compare it before.
