2010 Access Cab Rear Console
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dbarn, Feb 22, 2010.
  1. Feb 22, 2010 at 9:57 AM
    dbarn
    dbarn [OP] Well-Known Member
    Texas
    Tacoma 4X4 V6
    Have a question regarding the rear console. Mine really gets in the way when I am packing something length wise that needs to lay flat in the floor board. It's easy enough to remove but there is a gap in the storage bin, the seat belt buckles flop around, and there are holes left in the carpet to collect dirt. Does anyone make an adapter to cover this area when console is removed that will allow you to utilize all of the floorboard space? Do you guys just work around the console or leave it removed with no other provisions? Thanks for your opinions.
  2. Feb 22, 2010 at 9:59 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
  3. Feb 22, 2010 at 10:01 AM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    I was having the same issue. I had stuff that I didn't want to leave in the box of my truck because it might get stolen. And it was difficult to put the stuff in the back seat, partly because of the hump that is between the seats. So I bought a locking tonneau cover (Fold-A-COver G$) and it solved my problem. The only thing I put in the back seat now is my gym bag or beer.
    I know that isn't exactly what you were looking for but this is how I solved the problem.
    Cheers.
  4. Feb 22, 2010 at 10:07 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Hey Taco-nb is your tonneau waterproof?
  5. Feb 22, 2010 at 10:29 AM
    dbarn
    Texas
    Tacoma 4X4 V6
  6. Feb 22, 2010 at 10:31 AM
    dbarn
    Texas
    Tacoma 4X4 V6
    Also an option. But haul four wheeler too often.
  7. Feb 22, 2010 at 10:35 AM
    Taco-NB
    New Brunswick
    No it's not completely waterproof. A little bit of water does get in during heavy rain or when I wash the truck.
    It's a great tonneau cover. It opens near the cab and also at the tailgate end. What I did was put a big Rubbermaid container in the box of the truck, up near the cab. When water does get it, it leaks down the side of the box of the truck and can't get into the top of the Rubbermaid container. When I want to make sure that my stuff stays dry, in the box of the truck, I put it in the Rubbermaid container.
    Someone else suggested that one of the rubber mats works very well because, when a little bit of water leaks in, it runs down the inside wall of the box and then it goes under the mat and then runs off without getting your stuff wet. I'm going to pick up one of those this summer.
    Cheers.
  8. Feb 22, 2010 at 10:55 AM
    Taco-NB
    New Brunswick
    I think I remember seeing a tonneau cover that folds in three sections and sits up against the rear window of the cab when it's open. Then the box is almost completely uncovered. Of course, you can't see out the back window when it's open. :D
