2010 access cab subwoofer removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeZQ, May 9, 2010.
  1. May 9, 2010 at 2:16 PM
    MikeZQ
    MikeZQ [OP] Member
    Tacoma, Wa
    TRD OR
    100% Factory
    Can anyone tell me how to take this walmart quality sub woofer out.
    I can only find two fasteners under a small access panel on the bottom.
    I don't want to pry it off and end up breaking it.
    I see where Mr Marv is designing some replacement ideas, but nothing made up yet. I didn't see any removal tips however.
    Thanks,
  2. May 10, 2010 at 9:46 PM
    Rocko
    Rocko Active Member
    Washington
    2010 TRD Auto
    Basically there are four tabs on the sides of the sub. You have to squeeze in the sides of the sub and it will come out. If I remember right, there is a cover that comes off the bottom (maybe the top)also that has a bolt or two that needs to come off. The rear firewall cover does NOT have to be removed.
  3. May 11, 2010 at 6:59 AM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    search, there are removal instructions somewhere...with pics.
  4. May 11, 2010 at 7:16 AM
    WestonJ
    WestonJ Well-Known Member
    Weston
    Corpus Christi, Texas
    2010 Access Cab TRD Off-Road 4WD
    Added a Tool Box, rear spring TSB, Weathertech floor mats, Emergency lights,
    subscribed. i am also looking to replace the speakers in my 2010 access cab as well, does anyone know the size of the speakers that are in there now?
  5. May 11, 2010 at 7:18 AM
    Rocko
    Rocko Active Member
    Washington
    2010 TRD Auto
    go to crutchfield.com. enter your model and it will tell you what fits. I believe 6x9 fit the front doors.
  6. May 11, 2010 at 7:20 AM
    WestonJ
    Weston
    does it also tell you the size of the little sub in the door as well?
  7. May 11, 2010 at 7:35 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    Access.. Tweets and either 6x9 or 6.5s in front doors with 6.5s in rear access doors.
  8. May 11, 2010 at 7:53 AM
    WestonJ
    Weston
    i dont have speakers in the access doors, just in the front
  9. May 11, 2010 at 7:54 AM
    Jigzor
    Pennsylvania
    17 DCSB Silver Sky
    That's right, aren't they in the roof now?
  10. May 11, 2010 at 7:56 AM
    WestonJ
    Weston
    yes, they did put 2 speakers in the roof, and they have horrible quality. toyota did put a regular speaker, and a sub in the front doors though
  11. May 11, 2010 at 8:09 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    I've never seen a sub with a magnet the size of a quarter :eek:
  12. May 11, 2010 at 8:14 AM
    ilg
    ilg VanCity Taco.
    BC, Canada
    09 MGM TRD O/R 4x4 6-Spd
    WeatherTechs, Yellow Fogs, Alpine X-100 iPod Stereo, Custom Seat Covers, Debadged, Locking Bed Compartments, Black Front Toyota Emblem, AVS Vent Visors, Colour Matched Grill, TRD Shift Knob, Eagle Alloy 187s in 16x8 wrapped in 265/75/R16 Goodyear Wrangler Duratracs, Black Chrome TRD Badge on Tailgate, Black Rear Bumper, 8 in shorty antenna, 5100s @ 2.5.
    There is a little trick to removing the sub cover.
    First you have to pop the clips at the top to give you room to get you fingers in about half way down. Next you have to pry the sides outwards like the arrows shows. Thats where I had trouble, I saw pictures that others had posted, but you can't really see those bars that snap on in the middle. Look closely right where the inside of the arrows are. Once those middle bars are off, you can pop the remaining 4 clips on the lower half, and the whole cover slides off. A few bolts later and the whole sub is out. Also, it's easier to remove the cover that goes around the on off switch after the main cover is off.
  13. May 11, 2010 at 12:30 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Ilg - you may have solved my problem too.... I tried to take the sub out of my '09 Access Cab and gave up because I didn't want to break it. I think it might be that I wasn't pulling outward on the sides. That wasn't clear in any of the other threads on getting that weird looking thing out of there.
    I'm about to the point now where I'd GIVE it to someone who wants it, in exchange for the parts and pieces needed to cover up the mounting holes in the rear panel.
  14. May 11, 2010 at 12:47 PM
    ilg
    ilg VanCity Taco.
    BC, Canada
    Glad I could help!
  15. May 12, 2010 at 6:47 AM
    MikeZQ
    MikeZQ [OP] Member
    Tacoma, Wa
    TRD OR
    100% Factory
    Thanks for all the help, now that I know where to pry it should come right off.
    I went to Car Toys the other day to see if they had anything that would replace the factory sub, when they took a look at that funky sub I almost got laughed out of the store. It was the first they had seen, they couldn't believe Toyota put that in the truck.
    I'll try and find time to get that off today. Then start looking for a shallow mount sub box to cover up the hole between the seats.
  16. Sep 14, 2013 at 6:46 PM
    newgirl
    newgirl New Member
    10 Tacoma TRD Sport
    I am not sure why Toyota would put in this stupid subwoofer in the first place.
    Once you know how to remove the subwoofer it is EASY. First you will need tools (t20 torx screwdriver & 10mm socket wrench). You might want a flashlight to see bottom 2 bolts.
    ILG stated, "There is a little trick to removing the sub cover. First you have to pop the clips at the top to give you room to get you fingers in about half way down. Next you have to pry the sides outwards like the arrows shows.... Once those middle bars are off, you can pop the remaining 4 clips on the lower half, and the whole cover slides off....
    [​IMG]"
    Once the cover is off, I would HIGH RECOMMEND taking out the center console. There are 4 10mm bolts inside the console. It will help to get to the 2 bottom bolts.
    Then Pull off the nob switch (off-on-light on), then take out the 4 t20 torx screws. Once that is off there will be another piece right below it and it just pulls off. ** make sure it is in the off position**
    This is the hardest part:
    there will be 2 bolts and electrical plug left to take out. The bottom bolts are the similar setup as the top bolts, harder to get to and see. Once you take out the bottom bolts then it will be easy to unplug the power source to the subwoofer. :cool:
  17. Sep 14, 2013 at 7:00 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    ...welcome :wave: but you do realize this thread is over 3 years old right?
