2010 Air conditioner compressor grind on start up?
Discussion in 'Technical Chat' started by widget, Aug 3, 2010.
  1. Oct 6, 2010 at 8:13 AM
    #41
    widget
    widget [OP] Well-Known Member
    TN
    2010 Prerunner double cab
    I wouldn't think something making a grinding noise as this does (and now apparently a Dodge) would be "normal." Per Fatal Exile's last post, his repair seems to have resolved the issue, however I'm not so sure that everyone is going to be as fortunate to get a dealer to make such a repair unless there it truly is a "known issue" and has a TSB that's been issued and I'm not aware of such a bulletin (if someone else knows otherwise, please let us know). I have about another 6 wks left on my "all encompassing" 1 yr. warranty and I really appreciate any and all info possible before my 1 yr warranty is up.
    Plannerman99, you didn't mention but I'm assuming you have a new Dodge; have you been back to the Dodge dealer about the noise, what did they say?
  2. Oct 12, 2010 at 11:26 PM
    #42
    Plannerman99
    Plannerman99 Well-Known Member
    So Cal
    Our Adventure Vehicle
    I haven't been back to the dealer to ask about her Dodge yet, but will soon. I'll let you know what, if anything, they say.
  3. Jun 4, 2011 at 7:31 AM
    #43
    scott8357
    scott8357 Active Member
    Arizona
    2011 Tacoma SR5 4x4 V6
    I have a 2011 4X4 Taco and it is making the same a/c "grunt" noise. This has been a great forum for finding information, and now I feel like I have hit the jackpot (thanks Fatal Exile). I too bought my truck from Avondale Toyota, and use them for my service. I will try to get them to repeat your same service steps to mine and post back with updates.
  4. Jul 24, 2011 at 12:15 PM
    #44
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    *BUMP*
    Anyone have any info on this? Mine is doing it, too.
  5. Jul 24, 2011 at 12:58 PM
    #45
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    The sound you are experiencing is liquid flood-back to the compressor. In the off-cycle, liquid refrigerant migrates to the coolest position in the system, being the evaporator. When you start up your A/C when it's been shut off for a long time, the liquid accumulated in the evaporator slugs the compressor inlet and causes the noise you're hearing. Compressors are meant to be a vapor pump, so the liquid is actually causing damage to the compressor's valves. The easiest way to fix it is to regularly run your AC system.
  6. Jul 24, 2011 at 1:07 PM
    #46
    TACK
    Nevada
    Very interesting. Thanks!
  7. Jul 24, 2011 at 1:14 PM
    #47
    PR45
    PR45 Well-Known Member
    Los Angeles
    PreRunner SR5 4cyl
    Run mind darn near every time I'm in it, all year long, and it still makes that wrenching grunt when you turn it on.....
  8. Jul 24, 2011 at 1:49 PM
    #48
    TACK
    Nevada
    Yeah, mine has been doing it almost every day this summer. Mostly happens when I leave work and it's been sitting in the heat all day.
  9. Jul 24, 2011 at 1:55 PM
    #49
    chopper
    chopper ky taco
    chop
    stanton,kentucky
    05 taco reg cab 4x4
    dura tracs, debadged, weathertech floormats, removed mudflaps,black paint wheels,k&n air intake.
    my compressor is locked up so it dont work at all
  10. Jul 24, 2011 at 3:27 PM
    #50
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Well, it's not just ours, it's nearly every AC system that doesn't have a pumpdown solenoid or some means of keeping the refrigerant in the condenser during the off-cycle.
    That is why, if you are an absentee homeowner, you should keep your thermostat set at something like 80-82 degrees rather than just shut off all of your disconnects or circuit breakers- so the system runs occasionally.
    Another down-side to liquid migration is that compressor oil usually migrates with it- leaving you with an under-lubricated compressor that slugs on start-up. Not a good situation.
  11. Jul 24, 2011 at 3:34 PM
    #51
    BradleyScottETC
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Exactly- the refrigerant wants to stack in the evaporator, probably because your condenser is sitting dormant at 110+ degrees, or maybe even quite more as engine heat dissipates or direct sunlight shines on the front of your truck, and your evaporator in the cab of your truck is going to be substantially less than that.
    At 110 degrees, the R134a in your condenser is going to be at 147 psi. Say the inside of the cab of your truck is at 80 degrees and your evaporator matches that temperature, the refrigerant is going to be at 86 psi. Hence it's inclination to migrate.
  12. Jul 24, 2011 at 6:46 PM
    #52
    TACK
    Nevada
    Why haven't I heard this noise from any of my past vehicles?
    Is there anything that can be done to ease the grind & make the startup easier on the compressor?
    Sorry to bombard you with questions, but I see that you're an HVAC tech :D
  13. Jul 25, 2011 at 6:24 AM
    #53
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Argh, mine does it daily. So, if the logic is to run it more because it causes damage , then i'd just have to leave it off for a month at a time instead of daily so as to do less damage that it does do.......daily.
    Who makes these things for toyota n dodge? k-mart?
  14. Nov 17, 2011 at 7:23 PM
    #54
    Blake28104
    Blake28104 Active Member
    Blake
    Phenix City Alabama
    09 Prerunner SR5 W/ 3" Toytec Lift
    Areo Turbine Muffler 4" Roll SS Tips at 45 3'' Toytec Lift Toytec Rear 2" AAL's 20" KMC Monsters Nitto Terra Grapplers 33" 275-60-20 6000K Fog 6000K RETROFIT Headlight HIDs BY: Morimoto LED Led Corner Lights LED Tag Lights Flat Tinted Tag Cover Memphis PR1000.1 Amp 2 Rockford Fosgate P3s Scanguage11
    Mine dose the same thing ! i never drive dirt roads just normal 30 mile commute to work . and every once and a awhile it makes a grinding sound
