2010 backfires sometimes when cold started
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RV7Garage, Nov 17, 2009.
  1. Nov 17, 2009 at 7:56 PM
    RV7Garage
    RV7Garage [OP] R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    OK, it's only on the first start of the day, and doesn't happen every time either.
    Sometimes, I gat a small backfire though (SNAP! - from the tailpipe when first starting).
    Anybody else noticed this with their 2nd gen? I thought it might be bad gas, but have changed gas stations and it still happens once in a while.
    :confused::mad::(:eek: OMGWTF (yeah, we got the whole range of emotions going here!)
  2. Nov 17, 2009 at 11:01 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    happened to me once but i had my toe resting on the gas pedal i think...
  3. Nov 18, 2009 at 5:01 AM
    unimog
    unimog New Member
    Tim
    East Tn
    09 Tacoma
    This same backfire thing happens to me about 3 times a week. This backfire (or backfire sound) started when the weather turned cooler. It also feels like the high idle is really jacked up on the truck. Maybe this has something to do with the noise. Soon as I get a chance I will contact dealer to have this checked out. I guess they will have to keep it overnight, on a cold night, and hope it backfires.
    Sounds like this one is going to be hard to diagnosis
  4. Nov 18, 2009 at 5:52 AM
    z33tec
    z33tec Well-Known Member
    Rochester, NY
    09 4X4 Access Cab 4cyl
    There's been a bunch of threads made on this already. Here was the one I made: http://www.tacomaworld.com/forum/4-cylinder/25229-exhaust-pop-stock-09-a.html
    Seems to be normal. Mine does it on occasion when it's cold in the morning and has been sitting. I wouldn't worry about it unless yours is more than just a "pop." If you're actually hearing a really loud backfire, then you might have an issue.
  5. Nov 18, 2009 at 6:17 AM
    tacoeater
    tacoeater Well-Known Member
    Johnny
    Missouri
    07 TRD
    Weather Tech floor mats
    Some vehicles will backfire when started cold. They are running in open loop which means they are dumping lots of fuel into the cylinders. Some of the fuel ends up not burning until it gets into your exhaust, causing a backfire. I use to drive a Subaru STi before my truck and I ran a straight pipe with no cats. Whenever I started it up and drove it cold, it would backfire all the time especially during shifts. It is normal and it is not going to hurt your truck.
  6. Nov 18, 2009 at 9:18 AM
    Yoytoda
    Roland
    completely stock
    Actually were talking about post detonation. Firing during the exhaust stroke. Really normal when high amounts of fuel being dump into the engine like tacoeater said. Fuel injection "choke" when cold. If it was back firing which is considered pre detonation, would be if the engine were to fire before the compression stroke was complete, you would have an issue most likely timing related which is highly doubtful and it would happen even when warm. Post detonation afterfiring is normal.
    My father in his old ass suburban(manual choke) would choke the truck coming down a hill into town and turn it off and stomp on it in town giving the 12gage shotgun sound scaring the crap out of anyone walking the street.
  7. Nov 18, 2009 at 5:17 PM
    unimog
    unimog New Member
    Tim
    East Tn
    09 Tacoma
    My episodes are exactly like RV7Garage explains in his post. Sometimes (not always) when you first turn the key....exactly at the moment the motor starts to fire....pop. Although my pop sounds more like it is in the engine compartment instead of in the exhaust pipe.
    Does anyone think the high idle (warm up) setting for these trucks is higher than normal? Maybe Toyota decided to really dump some fuel in there to make them start right up.
  8. Nov 19, 2009 at 6:19 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    mine pops too, it doesn't seem loud, but I wonder if its "normal" or if there is a possibility of damage down the road. I place it in the catagory of what i dont like about my truck/might not matter though.
  9. Jan 18, 2010 at 12:07 PM
    crawl
    crawl Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    exactly!!! my pop sound is coming from the engine compartment, not the tailpipe. It must be coming out the intake tube (I need to confirm). Ive got 1,300 miles on my 2010.
  10. Mar 31, 2010 at 8:37 PM
    lowzone
    lowzone Well-Known Member
    Ron
    Earth aka NJ
    2010 MGM AC 2.7L 5 spd SR5
    future plan of 2" drop and any type of rim thats not a steelie. grille and BHLM mods, maybe....
    mine does it to, even after sitting for as little as 2 hours, im bringing it back and if they cant fix it 3times...i f'ing lemon law the truck. its 2010 and i have to deal with that crap? sorry its not NORMAL. :)
    actually i wont lemon law it, ill just keep bringing it back and have them refund my extended warranty and give me a better one....did it with my GMC when it kept dropping valves (dealership/GM quality control issues, nothing i did) and it kept going back over and over and over, they fixed it and refunded my warranty and gave me a better on...im uploading a video of my truck popping...
  11. Mar 31, 2010 at 8:56 PM
    Yoytoda
    Roland
    completely stock
    the pop doesnt hurt anything or prevent the truck from starting. Theres no need to waste time at the dealer. the pop is from excess fuel that gets injected to help start the truck. equivelant to choke on a carb. Its not going to hurt anything.
  12. Mar 31, 2010 at 8:58 PM
    Yoytoda
    Roland
    completely stock
    btw its actually pretty loud with the addition of my magnaflow exhaust.
  13. Mar 31, 2010 at 9:01 PM
    Yoytoda
    Roland
    completely stock
    since its a detenoation of fuel on a cold engine it will not have any long term effects to the engine. my noise defenitely got louder when i added my exhaust telling me its post detenation.
  14. Mar 31, 2010 at 9:06 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Mine does it to, everything that was explained so far sounds exactly like mine but it also does it on the first start on really hot days to. i get really mad everytime it happends.
  15. Mar 31, 2010 at 9:30 PM
    Yoytoda
    Roland
    completely stock
    i mean cold engine. Normal operating temps are 190-210 degrees. an engine even at 90-100 degress is "cold"
    Dont let it get to you. Most cars do it but the airbox/exhaust muffles the sound so much you cant hear it. My $40,000 GTO did it too and so did my dads vette. nothing to worry about
  16. Apr 1, 2010 at 4:40 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    2TR the LOL engine...
  17. Apr 1, 2010 at 4:42 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    2010 is backfiring because people aren't buying the lies and decit and corruption of the obama administration.
  18. Apr 1, 2010 at 5:52 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    why did you spend $40k for a GTO..??
  19. Apr 1, 2010 at 6:20 AM
    lowzone
    Ron
    Earth aka NJ
    backfiring on start up is NOT normal, especially in 2010...1960 OK fine....not today. the catalyst in the converter can be damaged by the excess fuel (clogging) thats being ignited OR can be damaged by the percussion of the explosion. ive seen mufflers blow apart at the seams from backfiring, granted that is much more excessive but over time, you dont think this could cause an issue? im having toyota look at it, its on paper and if i ever have a problem later on, i can throw it back in their laps. Ive learned with car manufacturers and dealerships, a paper trail will make them bend like a contortionist and get you results ALOT fast.
  20. Apr 1, 2010 at 6:23 AM
    Trigger
    Trigger Well-Known Member
    Not A mechanic. But one of our new VW cars was doing the same thing.
    The Timing was off. As in the engine timing.(when the pistons fire)
