2010 dash noises(sounds like gerbals on exercise wheel)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by willy2010, Aug 25, 2010.
  1. Aug 25, 2010 at 2:00 AM
    willy2010
    willy2010 [OP] New Member
    bc
    2010trd offroad
    have a problem with dash noise,at 100k,110k upto 121k and past sounds like its coming from behind the speedo gages,sounds like a sqeeky wheel have,tried turning off and on different controls to narrow it down .also took it to the dealer and they retourqued dash bolts but did not help.thanks for your input.
  2. Aug 25, 2010 at 2:06 AM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Check your interior fan make sure the filter is there. Behind the glove box, the other possible problem is leaves stuck in the cold air intake sort of under where the wiperblades are. Under that plastic. If it has a interior filter and it has stuff on the top like leaves and things suspect that problem is under the plastic under the wiper blades.
    Other possible problem if the speedo is a cable type. It may be dying. My GM did the same thing when it was cold. The square cable is wearing threw the outer casing. If it's brand new what the problem could be is the speedo cable is not running as strait as it should be.
    Oh and behind the glove box. Check for uncut tyraps rubbing on stuff. Maybe add a few. There is a post here about that somewhere. Trim the ends off if they have not been already cut. There is a thing also about the airbag passenger side. A label is left there and it rubs. I think that is a dealer fix only though. That should be something they have already fixed. Was a problem in the past.
  3. Aug 25, 2010 at 2:26 AM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    My friend at work just got a 2010 and said the same thing- at highway speed he hears a whirring noise from behind the dash. Sounds like something to do with the air intakes/ dash fans?
    Wait a minute- Tim, is this you? Or is this another BC 2010 with the same problem?
  4. Aug 25, 2010 at 2:31 AM
    Trap
    Indego Ink TRD OR
    On my truck the cabin air filter was inserted incorrectly so it was folded up and doing squat. I ripped it out tried to fix it. impossible, Threw it away and made my own permanent washable one from the MOD here. You want to check that filter once and awhile. You would be amazed at how much big stuff ends up on top of the filter.
  5. Aug 25, 2010 at 3:05 AM
    84Hilux
    Gary
    Vancouver, Canada
    Also note, there has been a recurrent problem with wind noise causing a loud humming at highway speed since 2005.
    Does not sound like what you are describing, but you might want to check it out anyway.
    Search under TSB (technical service bulletin) nv006-07
  6. Aug 25, 2010 at 4:12 AM
    SManZ
    SManZ el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
  7. Aug 25, 2010 at 11:56 PM
    84Hilux
    Gary
    Vancouver, Canada
    Bump- does anyone have any input on this subject? Ran the thread pretty late last night.
  8. Sep 4, 2010 at 12:41 PM
    willy2010
    bc
    2010trd offroad
    Thanks for the replies and sugestions,went on road test with toyota mechanic,and at around 110k noise started he prest on the windshield just behind mirror.the bussing noise would stop and start.the problem is with the seal around the window(TSB)
  9. Sep 7, 2010 at 10:19 PM
    84Hilux
    Gary
    Vancouver, Canada
    Glad you were able to find a solution. I am amazed that there are still trucks with this problem 5 years after it was first discovered!
  10. Sep 7, 2010 at 10:22 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
