2010 DC Audio upprade questions.
Discussion in 'Audio & Video' started by Ken14, Oct 27, 2010.
  1. Oct 27, 2010 at 6:37 PM
    Ken14
    Ken14 [OP] Active Member
    10 PreRunner Speedway Blue
    As Ive been lurking for s dsy or two..thought Id jump in and register and ask a few questions about an upgrade on my 10 Double Cab
    I have a 2010 Double Cab with the standard unit but the six disc changer, I had to have the dealer install the Toyota accessory XM unit...well the whole recieve is weaker than well water...it sucks bad. Id like to know a few things from the fella's who have done more than I
    Other than size and display is theer a huge difference in a double DIN and a single unit?
    When I upgrade recievers Ill add a Sirius unit..can I utilize the color matched sat antenna that exists on the truck already?
    Im quite sure Ill come up wih more questions, but want to thank everyone in advance for answering these to the best of their ability.
  2. Nov 16, 2010 at 9:23 AM
    vr6pilot
    vr6pilot rather be dubbin'
    Dan
    Viva New Mexico!!
    2016 Quicksand SR5
    I too have a '10 DC.
    Double vs. Single DIN...well, like you said: you get a larger faceplate which usually affords better button spacing and sometimes a larger display but these things are not to be discounted too quickly as they can make working with the unit while driving a whole lot easier.
    You may find double din's with multi-disc loaders but, with iPod being the medium of choice these days, fewer of these are on the market anymore.
    As for power and sound quality...no difference. Double din's aren't being utilized to stuff twice the amp power in there.
    Probably the most significant difference between the two is that your choices of models is more limited if you insist on going Double. That can, however, be a blessing as it can take considerable time trying to sift thru the mass of single-din units out there.
    As for the antenna...it is not a 'made by toyota' antenna and will probably work with any Sirius or XM unit you buy.
  3. Nov 16, 2010 at 12:27 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    On the Sat antenna, search around a bit more, I recall that there was an adapter talked about that allows the stock Sat antenna to plug into a new HU. Was expensive though,,, I think.
    Double DIN vs. single DIN, depends on what you plan to use it for. If you do video or nav, double should be a requirement. If only radio, CD, sat, mp3, then you can definitely get by with single, double will just add to usability.
  4. Nov 16, 2010 at 12:53 PM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    tss radio sells the antenna adapter
  5. Nov 16, 2010 at 1:12 PM
    &erson
    &erson Well-Known Member
    Sunshine State
    4x4 SR5
    Wet Okoles, Weathertechs, All-Pro Rear Bumper/Hitch & Sliders
