2010 ECU only allows 4 TPMS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JapanScratchy, Jun 10, 2011.
  1. Jun 10, 2011 at 2:58 PM
    JapanScratchy
    JapanScratchy [OP] Scratchy
    Kevin
    Ridgecrest, CA
    '10 Tacoma OR
    TW,
    Here's the deal, i bought a matching wheel so i can add my spare in the tire rotation. I took the truck to the dealer and "they" are telling me that the ECU is flashed for 4 (and only 4) so i can't add the 5 sensor. The print out from the diagnostic computer said that they can't add more.
    Anyone heard of this?
    Are there any work arounds? (besides putting an 05-08 ECU in.)
    (2010 DC TRD Off Road)
    thanks,
    JS
  2. Jun 10, 2011 at 3:00 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    just dont add the spare in the normal rotation :notsure:
  3. Jun 10, 2011 at 3:02 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Correct, computer did not have enough memory for 5 sensors and atrac (installed on newer trucks) so Toyota ditched one sensor to free memory and install ATRAC. You can''t have 5 sensors in 5 wheels
  4. Jun 10, 2011 at 5:09 PM
    JKD
    JKD Well-Known Member
    OP, it may be that the dealership computer can't add the fifth sensor. It may even be that the firmware in the truck can't handle the fifth sensor in '09+.
    If I were you, I would just check that tire normally, and go ahead and put it into rotation. If I had a fifth normal wheel that's what I'd do.
    [Citation Needed]
    The amount of memory needed to enter such a code is trivial.
  5. Jun 11, 2011 at 7:06 PM
    blatant
    blatant Well-Known Member
    never gave the taco thought but my fj has 5 wheels, 5 sensors, as well as atrac, which all seems to jive and work together.
