2010 Needs TSB for rear Springs??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by testedone, Oct 16, 2009.
  1. Oct 16, 2009 at 7:41 AM
    testedone
    testedone [OP] Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    So my truck has 498 miles on it now and wouldn't you know when you have a truck you have friends :)
    I went to Home Depot last night with my brother to get supplies for his fence building project..
    In the bed
    • 21 bags of Quickcrete (50 pounds each) = 1050 pounds
    • 2 8 foot 4x4's ?? 30 pounds??
    • 3 25 pound bags of pea gravel = 75 pound
    • Misc screws and junk = 10 pounds
    Total Weight = 1165
    Truck payload rating fro a 4x4 short bed DC = 1295
    no one is in the truck in these pictures and nothing else in the truck
    Should I have been sagging like this???
    Oh..and remember the little yellow stickers on the 2009 and below???
    here is the little yellow sticker on my 2010
    Only 4 pounds...the part numbers on my springs are the same as the ones that say are the bad ones in the TSB???
  2. Oct 16, 2009 at 7:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Were you on the bump stops? Keep in mind, with you in the truck, you were over the rating......
  3. Oct 16, 2009 at 7:54 AM
    testedone
    Rick
    U.S.A.
    the picture was taken with no one in the truck, but I think what you were saying is that ONCE we got into the truck we were over the rating correct?
    with the bed loaded the way it shows in the picture I then climbed on the rear bumper and jumped up and down and I still had room to play..I just would have thought it would not have sagged as much...
  4. Oct 16, 2009 at 7:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, I meant After you all got in the truck. Seems normal to me.
  5. Oct 16, 2009 at 7:57 AM
    testedone
    Rick
    U.S.A.
    ok, cool
  6. Oct 16, 2009 at 7:57 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I would get Timbrens.
  7. Oct 16, 2009 at 8:14 AM
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
    x2
  8. Oct 16, 2009 at 8:19 AM
    testedone
    Rick
    U.S.A.
    why Timbrens? This isn't going to lift the vehicle is it? I am planning a rear AAL and front 5100's,
    I just wasn't sure if the sag was normal, I rarely haul anything..
  9. Oct 16, 2009 at 8:26 AM
    aces2
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Timbrens are nice for loads like that because they're going to give you a smoother ride on the road when you're nearly bottomed out like you were. The truck doesn't crash/smack-down as hard as it would on the stock bump stops which are shaped like little rock hard pyramids. The Timbrens are shaped similarly to truck airbags installed in the rear end and are more durable AND more cushy.
    No they will not lift the vehicle.
    An AAL will help with heavy loads too. But I'm sure you know that those WILL lift the rear end.
    Sag is "normal" because you have 1,000 lbs. of shit in the back. Put that much on your back and your bound to sag some too! If this were an F-250 would it have sagged this much? No, probably not, but that's a full size pickup DESIGNED to carry 1,000+ lbs. regularly.
  10. Oct 16, 2009 at 8:30 AM
    testedone
    Rick
    U.S.A.
    LOL, I regularly carry 70+ pounds on my back and yes I do sag....
    yeah while I was loading there was a F250 SuperDuty loading up to, he didn't even blink with all the crap he had in the back...
    Thanks for the advice folks, this is my first PU in 14 years, always had jeeps so never hauled anything and don't know what normal sag is and isn't
    Peace
  11. Oct 16, 2009 at 10:27 PM
    RWS_350MAG
    RWS_350MAG Well-Known Member
    Don
    Wisconsin
    2010 TRD Off Road 4x4 AC
    Toytec Ultimate lift, Tailgate anti-theft mod, 265/75-16 Goodyear Duratrac tires on stock rims, Lakeland Predator Cap, Rear seat headrests removed, Husky Floorliners
    The yellow sticker on my 2010 Access Cab has the same numbers as yours.
    How does Toyota determine how much of a reduction in carrying capacity a Tacoma has?
    I haven't had my truck loaded up yet, to see how much it sags.
  12. Oct 17, 2009 at 9:30 AM
    Tacomzz09
    Tacomzz09 Well-Known Member
    Calgary
    09 DBL CAB TRD Sport Towing
    so the maximum is all different for all new Tacos?
  13. Mar 1, 2011 at 2:54 PM
    JBRICENO
    JBRICENO Member
    2009 TACOMA TRD SPORT SHORT BED DOUBLE CAB
    Certainly not! I've had as much as 1,500 lbs in the bed of my 2-wheel drive TRD Sport and did ride quite as low. Close, but not quite. I think some springs are just weaker than others. It's a defect, in my opionion. Adding overload or those leaf spring add-on helpers does help, but heck if Toyota is at fault, I don't care how old your Taco is, they should make good on the Free replacement they are doing for folks.
