2010 Oil Leak at 73000 miles
Discussion in '4 Cylinder' started by TacoTime10, Jan 24, 2021.
  1. Jan 31, 2021 at 6:24 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    a good mechanic has NO brand loyalty
    the dealer no less owes U nothing.................he is simply a middle man to the prev owner & U
    find U a damn good mechanic in a damn good shop if U are NOT
    going to do things as simple as an oil change
    line mechanics everywhere have fooookd up quite a bit
  2. Feb 7, 2021 at 7:17 AM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Just so you know the oil dipstick on the 2.7 is kinda wonky, to check it good the engine needs to be off for several hours or overnight. Or it gets oil smeared all down it if you check it hot. Also mine reads dead on full with 5.5 qts and a filter change even though the capacity says 6.1 qts or whatever.
    Sounds like you got the leak fixed, but if it's still there it could be coming from the valve cover in that area also. Might try washing the engine down with degreaser, if you keep the truck along time you'll thank yourself when you can work on it and not get completely covered in grime.
    Laser and TacoTime10[OP] like this.
  3. Feb 7, 2021 at 7:27 AM
    ROAD DOG
    FEW
    everyone should swipe the dipstick for a reasonable / accurate read
    no less the residual oil left in the upper engine is minute
    cut an engine off................minutes later most is back n sump
    unless there is varnish / sludge blocking return passages
    most engines have adequate upper engine drain or essentially one couldnt drive down the hiway !!!!
    no less many are sooooooo ‘ anal ‘ over the tenths of oil in various locations
    anything more than a whole quart is basis for concern
    most designs have at least the same amount oil in sumps that is circulating in the engine
    to cool & reconstitute an adequate amount of lubricant
    TacoTime10[OP] likes this.
  4. Feb 7, 2021 at 7:40 AM
    toyodajeff
    jeff
    06 reg cab sr5
    I think the problem is with the shape of the dipstick tube on the 2.7s when you pull the dipstick and wipe and and stick it back in oil can sometime be several inches over the fill mark due to it getting all in the tube and then all over the dipstick from pulling it out the first time. Maybe the 2.7 dipstick tube is better on 3rd gens but that how my 2nd gen and the other 2.7 2nd gen I've worked on are.
