2010 rear suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GT150, Nov 12, 2009.
  1. Nov 12, 2009 at 7:12 PM
    GT150
    GT150 [OP] Well-Known Member
    Blairsville Ga
    2010 Prerunner V-6
    Is there still a problem with the rear suspension on the 2010 Tacoma Prerunners.
  2. Nov 12, 2009 at 7:14 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    r u referring to the tsb aal?
  3. Nov 12, 2009 at 7:16 PM
    GT150
    Blairsville Ga
    2010 Prerunner V-6
    Yes, guess I wasn't to clear. Was curious if the problem was solved from previous years.
  4. Nov 12, 2009 at 7:35 PM
    08pretaco
    Oliver
    az
    thats an interesting question id love to know the answer to this? id figure they would spend the extra minute to through the extra leaf on instead of taking the time later on
  5. Nov 12, 2009 at 7:39 PM
    Steeler
    Steeler Member
    Yep, my 2010 has the same rear spring as the 09`s.
  6. Nov 12, 2009 at 7:51 PM
    60guy
    60guy BADASS
    Dustin
    Maryland
    2017 Limited Double Cab
    My DC 4x4 off road has the same part numbers leafs as the TSB. I'm currently in the process of trying to get the TSB done. I have noticed a rougher ride when pulling a trailer even w/ the trailer empty and it seems to get worse the more weight I put in the trailer. :mad:
  7. Nov 12, 2009 at 8:20 PM
    magneticnick
    magneticnick Well-Known Member
    Nick
    Orange, CA
    2010 DoubleCab TRD Sport
    None Yet
    YES the 2010's have the same issue, I am getting mine done at my local dealer tomorrow. If you do plan on towing or hauling with yours you should do it too. However when you call your dealership they will probably tell you that "your truck does not fall under the TSB as that was for 05 to 08's"
    That being said you'll have to battle, call Toyota Corp at the 800 number and start jumping thru hoops....just be persistent polite and patient. You can get it done. I'm living proof.
    Find the TSB on here and look at the part numbers they are in the first few pages, then go out to your truck and make sure your leaf part numbers are the same.......and if they are, follow the steps above.
