2010 SR5/4x4/DC/LB/ No RECALL, NO TSB recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco4x4NC, Mar 3, 2010.
  1. Mar 3, 2010 at 1:57 PM
    Taco4x4NC
    Taco4x4NC [OP] Well-Known Member
    David
    Western North Carolina
    2010 4x4 DC/LB "Pytrite Mica/Katzkin leather
    3m clear bra or Venture, stant locking gas cap, Shield, front windows tinted, weathertechs, ARE "Z" topper. Sockmonkey decal, Billy 5100's x 4 corners, Eibach coils, Toytec 1.5 AAL. Michelin 265/75/16 MS2's, Grillcraft MX series/TOYOTA badging. FJ/SE TRD Anthracite gray wheels. Katzkin leather/heated seats.
    Went by Toyota of Gastonia, NC today and pulled my truck in the service bay. Service rep came out I asked him if he would check and see if my truck was on any recall or TSB list. My truck was build date is Dec 7th 2009. I now have a little over 650 miles on my truck. And I specifically asked about the driveshaft recall.
    He took down my VIN number and verified using my VIN that there are no recalls or TSB's of any type on my truck. Provided a copy of this info to me in writing. This copy goes in the vault.:cool:
    So then went and drove to the ARE store and ordered my "Z" series ARE topper which will be here 15 March.
    Life is good.:D Now stop the insanity! hahahaha!
  2. Mar 3, 2010 at 2:00 PM
    rc51ny
    rc51ny Well-Known Member
    Mine has a build date of 12/09. I had the dealer check it when I pick it up last week--same thing--no recall. Hope he's correct!
  3. Mar 3, 2010 at 2:03 PM
    Taco4x4NC
    David
    I am sure he is. Did you get anything in writing? Not a bad idea to have it in print for the vault/file.
    Just sayin....
    I am not the least bit worried and drive my new truck with total confidence. Owned Yo's since my first new one in 1989. Best trucks on the planet.
  4. Mar 3, 2010 at 2:06 PM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    So the rear leaf TSB doesn't apply to your truck?
  5. Mar 3, 2010 at 2:32 PM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    raskal311 is right, Keep in mind that a tsb is not a recall, you need to complain about something specific for them to look into it, other then that, they won't tell you there is a tsb. Your rear springs do apply!!:)
  6. Mar 3, 2010 at 2:35 PM
    godofspeed
    godofspeed Washington State.
    Skagit Valley
    2010 4x4 TRD OR DC
    Body Armor front bumper Body Armor rear bumper Procomp 7089 16x8 285/75/16 BF MT Camburg LT Fox coilover All Pro 11 pack leaf Fox rear shock with DSC Allpro frame slider Smittybuilt 9500 winch Cobra CB w/firestick antenna. Hi-lift Smittybuilt air compressor
    my build date is DEC 17, 2009 and I had them check the driveshaft and I had the TSB performed for the rear leaf spring. But I don't qualify for the Transmission TSB.
  7. Mar 3, 2010 at 3:17 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Would like to hear where your 2010 Tacomas were built?
    I got mine in Dec. 2009, and it comes from the Baja California plant.
    The springs are stiffer than my '05, only 3 leafs but wouldn't bottom out like the '05 did with passengers or cargo. No recalls on mine either... that I am aware of.
  8. Mar 3, 2010 at 3:37 PM
    b4odcmpc
    b4odcmpc Member
    Louisiana
    TRD 4x4 SR5
    Mine is from Baja, Oct 09. Its about three weeks now that I've purchased it. Had the trans tsb performed monday, it needed it... Researching the leaf spring tsb, havent had the chance to load it yet.
  9. Mar 3, 2010 at 5:46 PM
    Taco4x4NC
    David
    According to the service tech at Gastonia Toyota who pulled my VIN and told me that my truck is clear and good to go, No the TSB does not apply, If I learn different, than he and I will have a chat.:)
    And I just have to say, my truck is running smooth as silk....no issues what so ever. And I am enjoying it as much if not more than all the other YO'S I have owned. For what its worth....
  10. Mar 3, 2010 at 5:53 PM
    dv8_taco
    dv8_taco Member
    Chattanoonga
    2010 TRD
    On the leaf spring is it possible to visually look at the springs to see if the are the new ones? Other than than loading the truck down?
  11. Mar 3, 2010 at 5:54 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Mine is from Baja and was built in Oct. '09, and the dealer said nothing applied in terms of TSB's, which the rear leaf obviously does...
  12. Mar 3, 2010 at 5:54 PM
    Incognito
    VA
    You should have 4 total under there.
  13. Mar 3, 2010 at 5:59 PM
    DeathBound
    DeathBound Well-Known Member
    Jay
    Mississippi Gulf Coast
    2010 Tacoma SR5 4X4
    Mine is Oct. '09, didn't ask the dealer about the rear suspension. I told him about the TSB and that when I loaded my toolbox it squatted a little too much. They ordered the parts today and will fix it Monday. All done on the phone. (This is not a truck toolbox, but the one I unloaded and use at work)
  14. Mar 3, 2010 at 6:00 PM
    kulitxplod
    kulitxplod Well-Known Member
    Middle TN
    2010 DC PreRunner
    Mine too. Built in Cali. 10/09, I purchased in 01/2010. It doesn't have TSB, I haven't noticed any issues, it has 3 springs. Check the door jam on the driver's side of the vehicle, there should be a label there with plant #, mfr date, other stuff.
  15. Mar 3, 2010 at 7:27 PM
    David K
    You say "Mine too", but then you say Cali..
    California is not the same as Baja California... not just a different state, but a different country!
    FYI: Baja California (where mine was built) is part of Mexico, just south of USA's California... which originally was 'Alta California' before we took it from Mexico, and shortened the name. Baja means 'lower' and Alta means 'upper'.
    Does the door jam lable say Toyota de Baja California ('de' means of)?
  16. Mar 4, 2010 at 5:29 AM
    kulitxplod
    Middle TN
    2010 DC PreRunner
    Thank you for the geography and history lesson. Not sure it was necessary though. I happen to call "lower" California "cali" but I don't think there's anyway someone here would know that unless they did so for the same reasons I do.
    As far as whether my label indicates Mexico or USA I will have to check.
  17. Mar 4, 2010 at 6:53 AM
    David K
    No worries... typically we call it 'Baja' for short and Mexicans call it 'La Baja' for short. Canadians often call it 'The Baja', like the way we might say The Congo, The Sudan, The Sahara...
    It is Baja California, and was originally just California, with the area that is our state called Alta California.
    The history was just for fun, and others who are reading this and might enjoy it.
    Look in the door jam and see where your Tacoma was made.
  18. Mar 4, 2010 at 7:01 AM
    SmoothFox
    SmoothFox Well-Known Member
    DFW TEXAS
    2010 TRD OFFROAD 4x4
    CBI Sliders,PIAA Lights, 5100's, 4 leaf pack.
    3 is Mexico, 5 is USA (first number of VIN) Right??
  19. Mar 4, 2010 at 7:07 AM
    kulitxplod
    Middle TN
    2010 DC PreRunner
    Yeah, I was about to post that my vin starts with a 5, so that means "upper" cali not "lower" cali. So, it's made in USA.
    My truck pretty much completely level. Although I haven't loaded it down yet, but I can state that there doesn't appear to be a ride quality issue right now.
  20. Mar 4, 2010 at 7:11 AM
    ComeOnToIt
    ComeOnToIt Member
    Northern New Hampshire
    '10 DBL.CB. TRD OR & '07 DBL.CB. SR5 4X4
    Bilstein 5100's- front, Rear spring TSB, Toytec 1.5" AAL, Goodyear Duratracs, Extang Trifecta Signature Series Tonneau
    I have an awesome service manager who has always been proactive in getting stuff done on my Toyotas. He is a Tacoma owner as well, so that helps! He ran the VIN on mine, which was built Dec. 09 and nothing came up for recalls yet
    He told me to call any time to schedule getting the rear spring TSB done and he will put the Bilstein 5100s in the front and align it under my free alignment you are allowed within the first 12,000 miles. Guy is awesome and has done the spring TSB on my '07 SR5 and the '07 I traded for my new one.
    It really helps when you have a true Toyota fan as your service guy and you can get good relationship with him.
