2010 Supercharger "odd" sound?
Discussion in 'Performance and Tuning' started by usmctopgun, Apr 8, 2010.
  1. Apr 8, 2010 at 5:23 PM
    usmctopgun
    usmctopgun [OP] Well-Known Member
    GA
    2010 TRD Sport 4x4 S/C
    TRD Supercharger, TRD CAI, Borla Cat-back, 3" Toytec Ultimate, LR UCAs, 18" ATX Artillery, 285/65/18, Bakflip HD w/ LED lighting, Katzskins 2 Tone Leather, JBL w/ Bluetooth and XM, WeatherTechs, 55w HIDs, 35w Fogs, Redline Tuning Hood Struts, Viair 480c /3 gallon tank OBA setup, Avid Sliders and Light bar
    Anyone had any problems with S/C on their 2010? Mine is making an obnoxious squeaking/squealing sound? Before anyone chimes in and says this is normal, IT IS NOT. Sound wasn't there until after about a month after install. Dealer has had it for several days, but it has them somewhat baffled. It appears to be coming from the big pulley on the lower portion of the engine that drives the S/C. Only starts sounding funny after running for a minute or so, but then it is continuous until shutdown. Ideas?
  2. Apr 8, 2010 at 5:34 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Have they attempted to replace the pulley?
  3. Apr 8, 2010 at 5:40 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    sounds like a bad pulley to me?
  4. Apr 8, 2010 at 5:54 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    The lower pulley they put on has no bearings in it. It has a groove that lines up with the existing crank pulley. If its in fact coming from that they either installed it wrong or its not tight enough. There is a small idler pulley right next to the crank that has a bearing which also could be a problem. Mine on occasion when I start it up makes noise, but goes away after a few seconds.
  5. Apr 9, 2010 at 5:00 AM
    usmctopgun
    GA
    They took off all pulleys, hand spun them, nothing. Sound occurs at idle, worsens w/ acceleration.
  6. Apr 9, 2010 at 5:07 AM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    the bearing wont make any noise unless it is loaded, hand spinning them may not tell you anything unless they are really toast
    I would just change the idlers and see if that fixes it
    there really are not that many components that can be causing your problem
    Justin
  7. Apr 9, 2010 at 6:10 AM
    jandrews
    Agreed, hand spinning doesn't tell you shit about bearing/belt/pulley interaction under load/tension...since it worsens with acceleration/engine load, it sounds either belt or bearing related. Something in there doesn't like to move faster.
  8. Apr 9, 2010 at 8:31 AM
    Jap
    Jap Loving this
    TRD supercharger, extractors, 7 psi pulley, Interceptor ECU
    Could be a couple of things, i've run into a similar issue on another vehicle.
    1. Could be the tensioner assembly squeaking as the arm moves.
    2. Could be a faulty bearing.
    The sound will be a dead give away.
    Is it a constant 'howling' or 'squealing' sound or does it change in relation to load on the engine?
